Monitor Utility for DOS
First post, by amontre
My CRT front face panel are not working and i cant adjust the geometry and Im too scared to open the monitor. It’s a 486 machine with built in Wingine DCX onboard display.
As you can see, its too squashed i cannot use the panel to adjust.
The attachment IMG_6231.jpeg is no longer available
However i tried using a utility from Trident VGA called TVGACRTC.exe which can adjust the geometry by Software. Since This computer are not using Trident card it doesnt save the settings.
The attachment IMG_6237.jpeg is no longer available
Is there other monitor utility i could use to adjust the geometry and probably load it in config.sys ?
#1 NEC Pentium 133 | 64mb RAM | 40gb HDD | s3 Virge DX | Voodoo 2 | SB AWE64 Gold
#2 NEC 486DX2 66 | 16mb RAM | 40gb HDD | SB AWE64 Gold
#3 Acer 386 SX 33 | 8mb RAM | 20gb HDD | PicoMEM + Adlib
# Amiga 1200 | MSX2+ | Roland MT-32 | SC 55MkII | YAMAHA MU80
Reply 1 of 9, by Grzyb
I think UniVBE/SDD included something called "UNICENTER"...
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 9, by amontre
Grzyb wrote on 2024-10-07, 10:54:
I cant seem to find UNICENTER
Reply 4 of 9, by amontre
kixs wrote on 2024-10-07, 12:15:
Should be included at least in SciTech Display Doctor 6.53.
Ok got it ! How does it work ? I made the changes and save the setting . Does it work as TSR ? How do i boot with the settings ?
Reply 7 of 9, by igully
Here you have the UNICENTRE utility with an explanatory text.
Reply 8 of 9, by amontre
igully wrote on 2024-10-07, 22:45:
Thanks. I did the the adjustment for all the modes and added univbe into autoexec.bat but once i exit to dos, the command prompt screen or Norton Commander itself are not adjusted as per what i did in Unicentr .
My guess is that those adjustment will only be applicable when the games utilize univbe but not others such as command prompt or Norton Commander
Reply 9 of 9, by Grzyb
I guess nobody expected that standard VGA modes might need adjustment.
Traditionally, only SVGA modes needed that.
