First post, by TheMobRules
I have this SiS471-based VLB motherboard from MSI, according to the date codes on the components it should be from early/mid 1994:
The attachment MS4132G.jpg is no longer available
My initial tests revealed a poor performance when compared to other SiS471 boards even when setting the tightest timings for the cache and DRAM. After a bit of research I concluded that the main problems are:
  • Very slow L2 cache speed, barely faster than the main memory even with the 2T/1T setting (with more relaxed timings the L2 isn't even detected)
  • L2 cache dirty tag set to "always dirty" by the BIOS, and no option to change it (common issue on boards with this chipset), which prevents L2 Write-Back mode to work properly
So, given that the solution to problem #2 was figured out by user GigAHerZ in this thread and it involves setting a couple of bits on a chipset register, I decided to start with that...
Roadblock #1: this board uses an AMI BIOS for which there are no tools like Modbin to easily mod it, so I had to use AMISetup which can update the registers on the CMOS settings, but it must be set again if the CMOS is cleared for some reason. Annoying, but OK.
Roadblock #2: setting the bits on register 72 didn't do anything... after fooling around with AMISetup for a while I noticed that most of the chipset register numbers are completely different from the ones mentioned on the chipset datasheet, and almost by chance I discovered that the bits had to be changed on register '5B' for some reason... no idea why it's like this, with an Award BIOS and Modbin the register numbers match those in the datasheet!
OK, so now I have L2 Write-Back working properly and memory bandwidth on SpeedSys is good, but L2 speeds are still abysmal. I tried updating some other registers but with AMISetup it's just impossible, settings that are part of the same register according to the datasheet are in different registers in the AMI config, and the bits are also in different locations, which makes it an exercise in frustration.
By this point I decided that the BIOS was setting incorrect register values for the cache timings (and who knows how many other things) and I wouldn't be able to fix that due to the limitations of AMISetup. Then I stumbled onto this:
SIS 486 SI3Green Motherboard
A motherboard from an "unknown" manufacturer, with a layout that is identical to the MS-4132G! But with an Award BIOS , and the BIOS string according to that site is 04/26/94-sis-85c471-I486sv2g-00... that's the ID of the well-known ASUS VL/I-486SV2G(X4)! Initially I thought this was probably a mistake, but what if...?
So, I flashed the ASUS BIOS, put the chip in the MSI board and bam! It works perfectly as it is, and not only that, but the performance is now almost equivalent to the ASUS board (which is known to be one of the fastest VLB boards), and on top of that I get LBA support that the AMI BIOS didn't have! I know using another BIOS usually works on most 286 and earlier, and even some 386, but I never imagined it would be the case for a 486! It's almost as if the MSI board was a clone of the ASUS but with different layout!
I'm glad this worked, but I cannot understand how they messed up so much with that AMI BIOS.
TL;DR: if you have this board, replace the BIOS with the ASUS VL/I-486SV2G(X4)
Reply 1 of 27, by Tigre978
Hello, I have a board similar to this, an MSI MS4132G (VER. 2), does this board also have the same problem as that one? How can I check it? I have tested this board with CheckIt and when the memory test passes the computer hangs, the icon is still there as if it were reading or writing but it does nothing and other times it restarts directly, why could that be ? Any cache memory or a bad ram module?
Reply 2 of 27, by PcBytes
BIOS-from-another-board thing works as far as 478, from what I've been experimenting over the years.
Reply 3 of 27, by akimmet
If you have an EEPROM programmer, I highly recommend upgrading to the ASUS BIOS. The stock BIOS is that broken.
This board also has some memory configuration jumpers that need to be set correctly. You will have problems if they are wrong.
I'll try to post some more info when I get time.
Reply 4 of 27, by Tigre978
And what programmer should you use? I have been wanting to get one for a while but between the fact that I don't know which one and that it won't be used, I haven't bought any. I want to get the bios of other boards that I have but of course I don't know which one to use.
Reply 5 of 27, by TheMobRules
In the time since I made this post, another vogoner kindly provided a dump of a slightly newer AMI BIOS (A75B as opposed to the original A75A) which fixes the issue of the dirty tag, among other things. However, the obnoxious L2 speed problem remains in that BIOS.
Later I performed an analysis on the AMI BIOS code and found the bug that prevents the L2 Cache Burst Read timings to be set correctly, so I was able to patch the BIOS to get full performance out of the board. Full details, including the patched A75B BIOS are in this post.
My personal speculation about this is that AMI/MSI just half-assed the whole thing by tweaking an older BIOS core (most likely from the SiS460) with very little effort in the way of QA.
Also, keep in mind that using the ASUS Award BIOS is still a valid solution, especially if you want LBA support.
As to how to program the chip, you'll find that the popular TL866 programmer is extremely useful for retro purposes at a relatively low price so that would be my recommendation.
Reply 6 of 27, by Tigre978
I have seen that on the retro web (https://theretroweb.com/motherboards/s/msi-ms … -ver.-2.0g#bios) there is a phoenix BIOS, but it is not here, that may be the bios that It will probably fix that problem.
If you say that the original patched bios fixes it but not completely, then I will put the Asus BIOS.
To the CheckIt question, could it be because of the bios or some cache or ram module?
I doubt it is something from the jumpers because the tower has not opened in the years it is, I had to fix the exploded bios battery and luckily the board is fine
With the issue of the programmer I will see if I can get one, here in Spain they cost 80 and 90 euros (I don't know what the prices will be in other countries) and for an 18 year old kid it is expensive but I will have no choice and I will have to buy it as soon as possible, I hope they come with manuals or something because I don't know how it works.
Reply 7 of 27, by akimmet
The TL866 programmer has been discontinued, replaced by the T48. The T48 is currently the best choice that I'm aware of. Buying from Xgecu directly is recommended, that way you can avoid counterfeits.
While the fixed version of A75B exists, I still reccomend the ASUS BIOS. Specifically the L2 cache dirty bit fixed version available on this forum.
Reply 8 of 27, by akimmet
So far there has been no evidence of a Phoenix BIOS actually existing for this board. It may be incorrect information collected from stason or th99.
When I get home, I'll provide links to the BIOS dumps in question, and I'll upload A75N. A75N as far as I can tell is the latest official BIOS for this board.
Reply 9 of 27, by Tigre978
Can you send me the ASUS BIOS?
There are a few on the retro web but I don't know if all of them will work or it has to be the one you used.
Is the programmer valid for all bios chips or only for those listed on the programmer's page?
I'm sorry if I ask stupid questions, I'm new to the subject and I want to make sure of things.
Reply 10 of 27, by akimmet
Here are some links to various BIOS dumps that I have verified to work on my MS-4132G motherboard.
The fixed A75B retains the 1993 AMI color BIOS core. Hard drive size will be limited to 504Mb.
A75N is the later AMI WinBIOS core. This version supports up to 2 8.4Gb hard drives. Hasn't been patched to enable dirty bit in L2 write back cache mode.
SV2G4fix.bin is a patched version of the latest BIOS for the ASUS VL/I-486SV2G motherboard. Supports up to 4 8.4Gb hard drives. The patch enables the dirty bit in L2 write back cache mode.
I have attached A75N to this post since I can no longer find this version anywhere else.
A75B
Re: AMI Color BIOS (1993 and earlier) modification in hex editor
SV2G4fix.bin
Re: Evolution of a Socket3 System to a POD @100MHz
Reply 11 of 27, by Tigre978
If you say that the A75N version does not fix the dirty label then I will use the ASUS BIOS, thank you very much for everything!
Reply 12 of 27, by myne
It's odd, but the bios seems to be one of the least documented things there is.
In theory, they're modular, and should consist of a fairly generic core, module(s) for the chipset, module(s) for other chips like the voltage/fsb chips, and relatively custom configuration data.
In theory, it should be possible to update the core to a newer version (perhaps with features like usb/CD boot), and leave the rest alone.
In this case, it should be possible to pull the cache config data, and leave the rest.
Yet, the little documentation available doesn't go into such details. Even tools that do modify the bios are poorly documented. Wtf even is an acpi table anyway? Why are there a list of strings? What relationship does the menu have to the registers? What code changes them, and how is it read?
There's better documentation on literally everything else.
/rant
I built:
Reply 13 of 27, by akimmet
Tigre978 wrote on 2024-10-09, 10:14:
The dirty tag bit is a trade off. To oversimplify, enabling the dirty bit sacrifices half of the total cachable memory for an increase in efficiency. It is nice to have, but know that having the dirty bit enabled means having more than 32Mb of RAM installed will reduce performance. Even though 32Mb is already overkill for a 486 CPU.
Reply 14 of 27, by Tigre978
I don't plan to increase the ram memory, it has 16 Mb and I think it is enough.
So if you say that it is not fixed but it does not have a performance impact, I think I will put it because of the hard drive issue, if not, it will stay like this.
Reply 15 of 27, by akimmet
From my tests, performance differences outside of benchmarks was similar. A75A being the only version that was noticeably slower.
Advanced power management is broken in A75A, always disable it to prevent crashes. ISA bus speed is also locked to 7.159Mhz, despite there being a setting to change it. These are a few things I remember from using the original A75A BIOS.
Reply 16 of 27, by Tigre978
Now that I'm looking, I've seen that the version of the bios I have is the A75H, I don't know what improvements or benefits this model has, are you aware of this version?
Update:
I got a programmer and a compatible chip, I saved the A75H BIOS and tested it with the ASUS motherboard BIOS. The result: the motherboard works. I don't know how much performance it should have, but with a CL GD-5428-80QC VLB graphics card and all the BIOS parameters correctly configured, in the 3DBENCH test it used to give me 45FPS and now it has a slight increase to 5FPS. In addition, MS-DOS now gives me an error that says: HIMEM.SYS detected an untrusted XMS memory address at 0046C242h. Another thing is that now Checkit doesn't crash and passes the memory test perfectly without errors.
I'm attaching the A75H BIOS in case anyone wants to take a look:
Reply 17 of 27, by akimmet
I'll add A75H to my collection. This is one I haven't seen before. When I get a chance I'll have to see what BIOS core this one is.
Reply 18 of 27, by newbie1
Wonder if anyone can help me. I have an Ebay ASUS VL/I-486SV2G motherboard that I'm trying to setup. It has an Award BIOS chip v4.50G. I can boot into the BIOS settings OK and move around the various setup options. But when I went install DOS 6.22 I got an error "can't enable A20", and I also lost the keyboard control ...no response from the keyboard and the same from 2 other keyboards. So I tried a spare AMI 486 BIOS chip in the socket and was actually able to use the keyboard outside of the BIOS setup screens. I can't continue to use that BIOS chip because it's meant for a different chipset, but it seems clear that the problem is with the Award BIOS chip the board came with. Can anyone tell me what my options are to get this board working. Any help much appreciated.
Reply 19 of 27, by jakethompson1
newbie1 wrote on 2025-08-13, 01:14:
If the CPU is jumpered so that WB/WT# puts it in L1 write-back mode, but the other control lines related to L1 write back aren't jumpered correctly or wired correctly on the board, it can cause bizarre symptoms like that. Is yours a rev 1.x? See ASUS VL/I-486SV2G(X4) REV. 1.8 conversion and jumpers guide
