First post, by Renaissance 2K
Hey, everyone.
1. I'm using an Orpheus II in a case with a full-size PC speaker. Ideally, I'd want the PC speaker output on my motherboard to be connected to both the case's PC speaker for general use, and to the Orpheus for audio capture.
I found what look like jumper wire splitters on Amazon. Is it safe to split the two PC Speaker signals like that? Is there an easier/safer solution I haven't thought of, other than "Dear God, you maniac, just pick one or the other"?
2. In other PC, I'm using an Audigy ZS 2. The gameport on this Audigy is broken out from the main card on its own rear bracket.
My case/motherboard is using an I/O shield that happens to have an unoccupied gameport space on it that I could punch out. Has anyone been in a similar situation and been able to remove the gameport from its bracket and attach it to a similar rear panel? The port detaches from its bracket easily enough, and fits inside the I/O shield, but there's nothing there to hold it in place. The other ports - parallel, serial, etc. - have the motherboard itself to keep it in place.
Thanks.
Reply 1 of 4, by nhattu1986
for no.1, i'm not sure but i don't think it will cause any problem.
for n0.2, you can add some washer between the bolt and the back-plate, it should be able to hold the port in place, but if your i/o shield is just a thin piece of metal then it won't feel secure when insert the gamepad for sure.
Reply 2 of 4, by konc
2. No you are not supposed to screw connectors that are not part of the motherboard on the I/O shield. You can of course "put" it there as it physically fits, but it'll never be sturdy enough to plug and unplug joysticks. You will be putting force on the I/O shield itself and most of them bend easily, that space is intended for the gameport of an on-board sound card. AT cases had places on the case where you could do that, some ATX cases that support AT motherboard had them too, but later purely ATX cases don't.
Reply 3 of 4, by wbahnassi
Splitting the PC speaker signal from the motherboard header to two outputs will work, but the volume will be lower on both outputs. Not sure how low though.
But I would not go with this setup as it would drive me crazy to hear the beeps simultanesously from the PC speaker in addition to the speakers from the sound card.
Also, I never liked the sound of PC speaker square waves routed through a sound card. It hurt my ears, and adds things like bass/treble boost to the signal... bleh.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 4 of 4, by Renaissance 2K
I bought and used the y-cables, and nothing caught fire, so great success, I guess.
I agree that listening to PC speaker output through both the case speaker and desk speakers would be maddening, but I'd only be using it for capture. The desk speakers would be muted during play.
