Reply 100 of 458, by DustyShinigami
- Oldbie
chinny22 wrote on 2024-10-15, 22:40:Not sure what you mean by tower deck Do you mean the case? […]
If yes then you have lots of choice as you can choose a modern ATX case with better airflow and if you wanted a window to show off the old hardware.
Or you can get something Beige and period correct, It's all just personal choice.You'll probably want a case with 2 front panels though, for a FDD and CD drive. If going modern it'll be hard to find a case with a 3.5 drive bay for the fdd but you can use adapters if needed.
CRT monitors are big, heavy, fragile and expensive to ship. I'd be looking whats available locally rather then specific models.
The case, yeah. I'd probably go for something beige and period correct. But due the vast choice, I just wondered if there were any specific models that were recommended. 😀
CRT monitors are going to be tricky. I can always check on Facebook Marketplace, but even then, I doubt there's going to be much near me. And many don't post/ship, but expect you to pick up.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
