Reply 1260 of 1356, by feipoa
- l33t++
Wtih 32 MB installed, 3.9 fps is also what I get in Quake 1.06 at 90 MHz, but only with 11.25 MHz ISA.
It is good to know that the peltiers helped nil. However, I did notice some thermal factor involved because if I removed my fan and ran the unit with just the heatsink at 80+ MHz, it would start throwing Windows errors. Also, I could run 90 MHz in the winter stable at 5.25 V, but not in the summer. I've had to take it down to 87.4 MHz and 5.05 V until I can investigate this further.
You noted that the BL3 at 110 MHz on the same Symphony motherboard yielded 28.3 fps, yet the SXL2-90 (22.5 MHz ISA) yielded 34 fps. What ISA frequency was that BL3-110 running at?
If you take the SXL2 down to 80 MHz and run the ISA at 10, 13, 17, and 20 MHz, what DOOM scores do you receive? Is the system stable?
Peering thru my notes, I have the following written down:
SXL2 at 80 MHz
10.0 MHz ISA = 3607 = 20.71 fps
13.3 MHz ISA = 3396 = 21.99 fps
16.0 MHz ISA = 3268 = 22.86 fps
20 MHz ISA = 3164 = 23.61 fps
From 10 to 20 MHz ISA, I'm noticing a 14% improvement.
At 90 MHz, you noted DOOM = 23.97 fps at 11.25 MHz and 33.9 fps at 22.5 MHz. This is a 41% improvement just by doubling the ISA speed, but it is far from the 14% I'm seeing at 80 MHz. Are you able to verify at 80 MHz?
I also have in my notes that at 20 MHz ISA, Windows 3.11 could not load, and that was without my NIC installed. Notes indicate that max ISA my NIC can run at is 13.3 MHz.
