First post, by marxveix
So far i have:
Socket 754 DOS/Win9x Machine
AMD Turion 64 ML-37 2GHz 1MB L2 35W (i want similar MT-37 25W)
1x512MB DDR400 SDRAM
MSI K8N Neo ATX (MS-7030 VER:1) Nvidia nForce3 250Gb (2.1 latest bios)
NVidia PNY Quadro FX 500 AGP 128MB DDR 3.6ns
ATX case 300W PSU
OS MSDOS/Win98SE
How to improve this system? I probably want to stay with Nforce3/FX or i go with Radeon 9600 Pro / 9600 XT?
What drivers are the best for Nforce3? I have sound problem with latest 4.27, but with 4.24 they work@Win98.
Why generic Realtek ALC850 drivers do not work, they have only Intel/Via/Sis support there, no Nvidia chipset.
Luckly SBEMU works with DOS sound.Why Realtek Win95VXD/Win98WDM drivers do not work with Windows98.
Upgraded MSI motherboard bios to the latest to support Mobile&Turion cpus.
I did take Sempron or Athlon 64 cover for Turion 64 and added some thermal
paste with mx-2@both sides to cover length differences at it, works now ok.
At the moment S754 cools ZALMAN CNPS7700-CU LED Copper CPU Cooler.
I dont like Led, but this is what i have, other stock AM3 coolers are not better.
There where no sound at first and i needed to add 2 jumpres to make it work.
Sound now works with Windows 98 and DOS, manual did not have this info.
just looked internet forum/pics and my MSI MB did not have these jumpers.
Do i need better soundcard or it can be without, any useful PCI add in cards?
NForce3 250Gb seems faster with FX cards, than other Socket 754 chipsets?
https://web.archive.org/web/20240518160944/ht … eforce-fx-6592/
I am using Omega 45.23 graphics drivers and 3DMark99 Max has 15730 points.
I would like to have bit faster videocard here, but without extra power needed?
Efficent as possible, for that i think ATi 9600 Pro with fast 2.8ns ram is better?
Maybe i just tune FX500 ram clocks to its normal clocks 3.6ns@275MHz speed?
If i installed Win9x PowerNow, then clocks went min.PowerNow vs CoolNQuiet?
Any help with 256MB Radeon 9600 Pro vs 128MB if memory speed is the same?
Slower than Turion64, i think of MobileSempron3400+ 256Kb L2, its 32bit cpu.
Mobile Semprons are also 24/25W items and up to SSE3, not 35W, like this T64.
Turion 64 MLs are 35w and MTs are 25W, my ML-37 voltage is low as it should be.
What you think, i stay with Turion 64 or downgrade to Mobile Sempron 3400+?
NForce3 chipset do not like dual core and Socket754 is single core machine only.
64 bit drivers i have for NForce3, but does it need 64bit at all with tiny max ram.
2x1GB@DDR400 or 3x1GBDDR333 is max what it can work with, 2x1GBDDR400?
Maybe its time to make DOS/Win9x/XP/Linux machine not just Dos/Win9x only?
If if go with 4in1 not 2in1 OS, what is better W2K or XPP, what Linux OS is good?
What videocard/cpu you would use here if efficency is crucial part of this build?
Also what PSU someone recommend, i have 20pin to 24pin adapter that i use?
Thats it for now 😀
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
