Reply 1200 of 1892, by LSS10999
esher wrote on 2024-10-29, 19:47:Well, i'm not using the bracket at all,my plans is to route Picogus audio out to CD line in @SB16, and the MIDI port to custom bracket with mini DIN which Creative use in SB Audigy 2 ZS with 5.25" module.
Anyway, i recommend to build a custom bracket with 2xRCA stereo out, as i did to SB16 before. Just take one of the dummy bracket from the PC case and drill the holes for RCA.
My card is already installed on the system, with its modified bracket. Just that I need to run pgusinit twice.
I don't use its MIDI output so I used "/mpuport 0" to disable it. For MIDI on that system, I'm using a Raspberry Pi 3 with a MT32-Pi hat connected to my AWE64 Gold using an external MIDI cable. It works in the same way as the WavetablePi module. Sadly AWE32/64 don't have wavetable headers like SB16...
I'm curious about the SB16 RCA mod, however, as I don't know if ordinary SB16 PCBs even have rooms for such a modification. After all, AWE64 Gold is the only RCA-equipped ISA Sound Blaster I know.
