daniil1909 wrote on 2024-11-04, 01:01:
I really dont want to lose it so can i disassemble it? (have an experience, risky because of dust)
Tricky, normally you would want a "clean room" - but I have disassembled a couple of drives over the years (I don't have a clean room),
and making sure the area(&me) was clear of dust etc. managed to not kill the drives
** Most impressive story was I had a 3.25 IDE that wouldn't spin up - taking it apart the heads were "stuck" to a very fine bit of corrosion
on one of the platters... wasn't trying to recover data, just wanted to look inside the drive and see what happened, then decided to see if I
could "make it better". I managed to free the head, clean it, polish the platter - after reassembling the drive, I gave it a clean format - NO
ERRORS*** - Trying to see "how long it would last" I put it in a non-critical system where it ran for a few years before the system got taken
out of service. - but don't expect this to be a common result!
*** There likely were some errors, but drive internal firmware is often "smart" enough to re-map bad sectors to spare good ones!
never looked into it further!
But you may not be able to identify/fix the source of the sound.
If it's working with no bad sectors, and since it only makes the sound on spinup/down, there's a good chance that
what's making the noise isn't contacting during operation ... If it contains data you care about, I'd make a full backup
NOW (before problems start showing up) - once you have the data saved, you can try whatever you want with the drive!
(and good luck)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
