First post, by John Allen Mills
I'm trying to play Blood with CD music, and while it works fine in version 0.74, the music doesn't loop. In SVN, the music loops, but the sound quality is poor. If I reduce the sample rate to below 48,000 (even 47,999), the music sounds fine, but the sound effects become distorted.
I've tried ripsaw8o8o's fix (bcdfix.com) for version 0.74 regarding this issue, but since he said he only tested on v1.11, I presume it doesn't work for v1.21, or at least I can't get it to work. I also tried his other fix (ctrloop.com), but that didn't work either.
How can I either improve the CD audio quality in SVN or get 0.74 to loop the CD music correctly?
The threads I got the fixes from:
Re: Blood CD-Audio doesn't loop in DOS
Re: Carmageddon music (CD Audio) not working
-J.A.M.
PS - I'm ashamed to admit I don't know how to rename links. <deep sigh>
