Reply 360 of 528, by ChronoReaperX
BEEN_Nath_58 wrote on 2024-11-07, 09:45:
ChronoReaperX wrote on 2024-11-07, 06:54:
BEEN_Nath_58 wrote on 2024-11-06, 18:18:
I haven't got the time to test GBL for ChromeReaperX either. Anyways... […]
The game working fine after aborting a mission could be a sign of where to look. If you read some of the previous discussions on this thread, you will get comments on the game flickering unless the game is Aborted and re-run.
What I assume is, DxWnd isn't correctly hooking the game interface on the first run in mission. The mission window is a separate DirectDraw hWnd, forced to skip the DDSCL_EXCLUSIVE flag but keeping the game contactless from other apps through a modal window (which fails on the first run). On the Abort -> Replay Mission the Modal window was drawn correctly, and simultaneously your game doesn't get a memory leak.
You can continue to run the game in this fashion, and if the leak no longer happens, I think we found the issue
Ok I will try and test what you said. Start a mission then abort, after that, restart it back, right?
yes
Ok the result is negative... still the same. I've tested several times. Aborted the mission without exiting the game then re-enter the mission, and aborted the mission with exiting the game altogether.
Reply 361 of 528, by Nick Guts
I've installed successfully with the Easy Installation tool. I'm playing Mercs Titanium for dynamic salvage.
Everything runs well, but after an extended time in a mission I lose assets and sound. If I alt+tab, I get an in-game noticfication saying "Memory Low" and the assets drop again if I resume game.
Any way to fix this?
Thank you!
Reply 362 of 528, by Nick Guts
Now I'm getting this error when starting through the Easy Installer Link.
Reply 363 of 528, by CommanderHunter
Heyo! I'm interested in using your guide (namely via the all-in-one installer), but there's a problem...the installer only tries to look in the physical disc drive. There's no way to point it towards a virtual disc drive, which is a bummer.
Reply 364 of 528, by CommanderHunter
Nick Guts wrote on 2024-11-16, 23:10:
Also hi! Just a note, you don't need Titanium Mercs for dynamic salvage; the 1.1 patch for Mercs 95 is largely the same, including that.
Reply 365 of 528, by ChronoReaperX
Nick Guts wrote on 2024-11-16, 22:40:
I've installed successfully with the Easy Installation tool. I'm playing Mercs Titanium for dynamic salvage. […]
Thank you!
This my friend is what we called a MEMORY LEAK and this is also what I've experienced when playing the game. So far no fix for this. I hope there will be one soon.
Reply 366 of 528, by Nick Guts
I got Mercs 95 running with a manual install and moving DXWind files into the install folder. Even patched it for Dynamic Salvage.
Game runs really well, but after completing mission and clicking the "NEXT MISSION" or "STARPORT" button freezes my game.
Any ideas?
Reply 367 of 528, by BEEN_Nath_58
Nick Guts wrote on 2024-11-18, 03:47:
Any ideas?
If you can save the game and re-run it, that would be the choice for now. The heap issue is yet to be investigated in Mercs, but the person in charge of it doens't have the necessary system right now.
Reply 368 of 528, by Nick Guts
BEEN_Nath_58 wrote on 2024-11-18, 08:48:
Any ideas?
Thank you, this works!
I'm getting some DLL bug that happens on some missions. Have to resort to completing mission and using the Complete Mission cheat to bypass error. It happened on the Rising Sun POW mission, Medical Facility Terror Attack and a few others. I ran the mission fix script as well. Any ideas?
Reply 369 of 528, by Nick Guts
"DP DLL error
Bug - Negative Threads?"
This is what is occurring on these missions
Reply 370 of 528, by BEEN_Nath_58
Nick Guts wrote on 2024-11-19, 03:48:
"DP DLL error
This is (was) a Activision engine bug. It happens in other games like Heavy Gear 1 as well.
By any chance, are you running Battlepack (or SW rendered Titanium) since that's only where I got this error.
Reply 371 of 528, by Nick Guts
BEEN_Nath_58 wrote on 2024-11-19, 06:34:
"DP DLL error
im on Mercs 95
Reply 372 of 528, by Khoidoan1@hotmail.co
Windows update must have broken something because I keep getting
Getthreadcontext error = 5
Reply 373 of 528, by Khoidoan1@hotmail.co
As additional information. I get the error everytime I try to run Dxwnd and launch the mercswin.exe. It doesn't seem to matter what version of Dxwnd is used.
Reply 374 of 528, by BEEN_Nath_58
Khoidoan1@hotmail.co wrote on 2024-12-14, 18:45:
Try running the game without DxWnd and let me know if you get a 0xc000005 error
Reply 375 of 528, by Khoidoan1@hotmail.co
BEEN_Nath_58 wrote on 2024-12-14, 21:08:
I get some other kind of error running it without dxwnd
Reply 376 of 528, by BEEN_Nath_58
Khoidoan1@hotmail.co wrote on 2024-12-15, 03:01:
https://cdn.imgchest.com/files/4z9cvqrk667.png […]
Yes that's what I meant. This is an error, which comes from what's on your computer and not the game. Previously, some game gave me this error upon having the Logitech Control Panel, since which I never had the issue. Unfortunately I can't control or comment on what error is causing this
Reply 377 of 528, by Khoidoan1@hotmail.co
BEEN_Nath_58 wrote on 2024-12-15, 05:37:
I have no clue. I haven't installed anything new. Only thing that's happened is windows updates
Reply 378 of 528, by myne
I think someone has to figure out dxwnd properly.
I'm puzzled because I played it through a year ago without these issues.
Windows break something?
I built:
Reply 379 of 528, by BEEN_Nath_58
Khoidoan1@hotmail.co wrote on 2024-12-15, 06:40:
There is a very little I can control from Windows updates, since it is not reproducible either. Another user here tried MechVM to launch the game in the same fashion, but failed
myne wrote on 2024-12-15, 07:16:
Its not a dxwnd bug if the error isn't coming from here.
