ASTRA - Advanced Sysinfo Tool for DOS
Reply 60 of 102, by a2kkv
zuldan wrote on 2024-09-28, 02:54:
I'm trying to get this to run on one of my machines but it sits at "Reading MSR Registers" and does nothing. If I use the /nMSR parameter then I can run the software.
Thank you for the report.
Fixed in the latest beta version.
Download link:
http://www.sysinfolab.com/files/beta/astrabet.zip
I've attached a couple of report files. I also noticed on the main system info screen the 2D card info is mixed in with the Voodoo card
Fixed
I'm also wondering if it's possible for the software to show the 28MB of memory on the AWE64 Gold card?
ASTRA should detect memory size on AWE64. The sound card should be initialized properly (for example by Unisound).
ASTRA32 - Advanced System Information Tool for Windows
Reply 61 of 102, by a2kkv
New ASTRA 7.11 beta has been released.
New in this beta:
- Added support for EISA devices (detailed information about EISA motherboard and external devices)
DEC PRIORIS MTE (EISA):
The attachment MB_2K.jpg is no longer available
The attachment summary.png is no longer available
The attachment EISA.png is no longer available
The attachment EISA2.png is no longer available
ASTRA 7.11 beta download link:
Reply 62 of 102, by Agent of the BSoD
Confirmed on that beta that all of my Virge GX2 cards now show the correct clock speeds. The Voodoo Rush is now shown as AT3D + Voodoo Rush, however the program is still hard locking when generating a report with the Rush installed.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 63 of 102, by PC@LIVE
I'm working on a PCCHIPS M550, and I loaded it on a CF Astra 7.10 memory card, the software with an Intel Pentium MMX 233 works, changing CPU with an AMD K6 233, instead it crashes (see screen), I don't know if the problem is due to some storage problem, but I don't think so.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 64 of 102, by a2kkv
PC@LIVE wrote on 2024-10-21, 19:54:
Try to run the latest beta version.
It should work.
Reply 65 of 102, by a2kkv
Agent of the BSoD wrote on 2024-10-21, 19:02:
Try to use /nDBG command line switch (astra.exe /nDBG)
Reply 66 of 102, by Agent of the BSoD
That worked. Got a report with the Voodoo Rush here.
Reply 67 of 102, by konc
Thank you for this tool and for being free for hobbyists. The amount of details it produces is amazing, I haven't seen it elsewhere.
Reply 68 of 102, by a2kkv
New in this beta:
- Added detection of motherboard model by BIOS ID for AMI and Award BIOS motherboards.
See the Board Model (BIOS ID) field in the screenshot.
The attachment MB.png is no longer available
Reply 69 of 102, by PC@LIVE
a2kkv wrote on 2024-10-24, 20:33:
Try to run the latest beta version. It should work. http://www.sysinfolab.com/files/beta/astrabet.zip […]
It should work.
Ok Thank you very much
I'll try the latest beta version (7.11), maybe it works
Reply 70 of 102, by DOSJunkie
Now that the BIOS ID is used for mainboard detection, you could also evaluate the BIOS ID completely, since it consists of several parts, all of which are documented. Do you have plans in this direction?
Reply 71 of 102, by Nemo1985
Hello, I tried Astra on this motherboard: https://www.ecs.com.tw/he/Product/Motherboard … s/specification
I don't know if it's right but on Audio Codec Name, it says Unknown (00000000h:0002h), the codec is the ac'97 and the chip is C-Media CMI9738.
Here is the compressed report.
It's a very useful utility, thank you for you work!
Reply 72 of 102, by PC@LIVE
Hi and thanks the beta version works
Reply 73 of 102, by a2kkv
DOSJunkie wrote on 2024-10-26, 06:51:
This was done in 2000.
Award BIOS
  BIOS
Motherboard Vendor: EPoX Computer Co., Ltd.
Vendor URL: www.epox.com
BIOS Version: Award Modular BIOS v4.51PG
BIOS Type: Legacy BIOS
BIOS Model/SubModel/Revision: FCh/01h/00h
BIOS Date: 08/30/00
BIOS Copyright: Award Software Inc. - 04/23/90
Motherboard ID: 08/30/2000 For Apollo Pro-Plus/133 AGP/PCIset
BIOS ID: 08/30/2000-693-686A-2A6LGPAAC-00
AWARD BIOS Family: EliteBIOS v.4.5
Bus Type: ISA/PCI
Processor: 686
Chipset Name: VIA 693/596 or VIA 693/686A
Chipset ID: 693-686A
BIOS Revision: 00
PnP Version: 1.0
ACPI Version: 1.0 (VIA693)
MP Specification Ver.: Not Supported
DMI/SMBIOS Version: 2.1
DMI/SMBIOS Structures: 31
DMI/SMBIOS Address: 000Fh:0800h
APM Version: 1.2
AMI BIOS:
 BIOS
Motherboard Vendor: Hsing Tech Enterprise Co., Ltd. (PC Chips)
Vendor URL: www.pcchips.com
BIOS Version: AMI BIOS 07.00.10
BIOS Date: 10/07/03
BIOS Copyright: 04/02/01(C)2003 American Megatrends Inc., All Rights Reserved
Motherboard ID: For DeskNote BIOS
BIOS ID: 52-0620-001437-00101111-040201-TM5600
AMI BIOS Tag: 1ABMB002
BIOS Size: 256 kB
Processor: 586
Chipset ID: TM5600
BIOS Revision: 0620
PnP Version: 1.0
ACPI Version: 1.0 (AMI)
DMI/SMBIOS Version: 2.3
DMI/SMBIOS Structures: 25
DMI/SMBIOS Address: 000Fh:0690h
APM Version: Not Supported
Reply 75 of 102, by a2kkv
New in this beta:
- Added support for SiS 85C411 EISA chipset (memory controller mode, ISA and EISA bus speed, L2 cache size and type, etc)
The attachment 85C411_1.png is no longer available
The attachment 85C411_2.png is no longer available
The attachment 85C411.jpg is no longer available
The attachment 85C431.jpg is no longer available
The attachment 85C406.jpg is no longer available
Reply 76 of 102, by PC@LIVE
I have a PC on the bench with MB Olidata OLI-BX and P2 400 MHz, I started the beta version that you had advised me to use in the M550 K6 233 (i430TX), it works, but I noticed that the info of the sound card, are in the "Video Card" section, and those of the video card, we find them in the "Video Card 2" section, honestly I don't know if it's an oversight, or it's a coincidence that put them in this order, just to clarify, the video card is an AGP, the sound card instead is PCI.
I'll put the pictures where you can see what I described to you, I hope I was useful to you, greetings 🫡
Reply 77 of 102, by a2kkv
PC@LIVE wrote on 2024-11-02, 21:39:
Thank you for the bug report.
Please send the text report.
I can't reproduce this error.
Reply 78 of 102, by PC@LIVE
a2kkv wrote on 2024-11-19, 05:39:
Thank you for the bug report. Please send the text report. I can't reproduce this error. […]
Ok Thanks to you
Currently the PC is on the bench, because I made some changes, the CPU is now a Pentium III 500, the 400 will serve me on other Slot1 MBs.
I only need a few days (maybe more than a few), but as soon as I can I'll attach the file
Regards
Reply 79 of 102, by auron
on a 430NX system with parity RAM installed and parity enabled in BIOS, ASTRA shows [x] for parity but with "disabled" next to it. has the parity check been tested with this chipset? also, are the memory/cache timings it lists from a database or from an actual BIOS readout? and it's saying march 1993 for launch date, which should be for 430LX.
what is remarkable about this tool is it's the first one that actually shows SMART data for old IDE drives, for some reason i don't recall any other tool being able to do this.
edit: found that the tool has problems when two VGAs are installed, in my case an onboard ET4000 and a 4mb matrox millennium. information for the latter is mixed into the section of the former. it displays this in the system summary, although the issue is similar in the video section:
Video Card
Video Chip Vendor: TSENG Labs Inc
Video Chip: ET4000/W32P Rev C
Video Chip Type: Matrox Millennium (2064W)
VESA OEM String: Matrox Graphics Inc.
Bus Type: PCI
Video Memory Size: 2 MB
Video Card 2
Video Chip Vendor: Matrox Graphics Inc
Video Chip: MGA-2064W Storm (Millennium board)
Bus Type: PCI
and finally, a visual remark - it seems to me horizontal scrolling should be eliminated, it's a bit distracting right now. for almost all descriptions where scrolling is needed, there is enough space to move everything a bit to the left. and in the few cases where that's not enough, another line could be used without much issue.
