First post, by wkjagt
I recently got an old Pentium 2 laptop that came with a French version of Windows 98 installed on it. I just put a fresh English install of W98 on it, and noticed that the default drivers only allow the display to be used at 640x480 with 16 colors, which looks terrible on the 1024x768 screen. I haven't found the drivers for this laptop online but I did make a backup of the original Windows folder, so I have the drivers in there somewhere. Does anyone know how to locate them, and use them on my new install?
Stay at home dad playing around with 286-486. Programming C and assembly. Repairing old stuff.
Reply 1 of 5, by weedeewee
Haven't tried this myself but If I would look for it, I'd do something like this
Look for the .INF file that references the VGA card in the old windows backup
Copy all the files referenced within it, including the .INF file itself to the same location on your new windows install
remove the standard display adapter from the new windows & reboot.
Do not ask Why !
Reply 2 of 5, by PD2JK
Take a look in the windows\inf directory. Then scavange the missing driver files from the system32 folder after selecting the correct *.inf file.
has all kinds of stuff
Reply 3 of 5, by wkjagt
There are a lot of files in there! But I found one that references the Trident 9525 chip, and also references Toshiba (the laptop is a Toshiba Satellite 4060XCDT), so I am fairly sure I'm getting close. It seems to be the graphics chip that this laptop uses.
Reply 4 of 5, by chinny22
This looks to be the driver here
https://legacy.nroach44.id.au/machine-toshiba … e-4100xdvd.html
You can find the names of the driver files here, but the links seem to be dead.
https://support.dynabook.com/support/modelHom … 34&osId=3333623
entering the filename into google is probably your best chance
Reply 5 of 5, by wkjagt
chinny22 wrote on 2024-11-21, 04:00:
This looks to be the driver here https://legacy.nroach44.id.au/machine-toshiba … e-4100xdvd.html […]
Awesome thank you!
