Reply 600 of 651, by Skalabala
Its awesome that the PPro had up to 1024kb cache. I always dream of an engineering sample of AMD K6 that was native 133x5.5 extra instructions and 512Kb LOLOL.
I mean I can run NFS Most Wanted at 50FPS on my K6. I want to see a P2 Celeron do that!
Reply 601 of 651, by RayeR
About CPU ID, you can try my CPUID utility:
http://www.rayer.g6.cz/programm/programe.htm#CPUID
the DOS and WIN32 version was silently updated. It's not well tested on AMD CPUs as I have only few ones. Mostly tested on intels. It can also read & write MSRs for various testing...
Reply 602 of 651, by brain_recall
Just wanted to share that I successfully modded a 500MHz ACZ core. Those seem to be the only ones left on eBay.
IHS came off easy enough with a razor blade. I went slow, did a little bit on a corner and went to the next, and did several rounds of that, then it popped right off. Just a little cleanup and it was good.
I left the IHS off. I added some rubber strips at the corners that were about 0.7mm thick. They work a lot like the later Athlon pads. I was able to push it to 600MHz at 2.4 volts stable with an hour of Prime95.
Reply 603 of 651, by analog_programmer
brain_recall wrote on 2024-08-12, 21:48:
I have one of those AMD K6-2+/500ACZ (still unmodified), but isn't 2.4 V too high for core voltage as this CPU runs on 2 V at stock 500 MHz?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 605 of 651, by brain_recall
Yeah probably too high. It's stable for Prime95 but was giving me trouble in some games. I dropped it down to 550MHz which it can do at the stock 2.0V with no issues.
Reply 606 of 651, by gmaverick2k
think i done f*ed up. Was trying to take off the lid using a steel ruler and managed to snap of a pin on the opposite side of the inserted keyed edge. Put it into the mother board and it still posts. Does anyone know if that pin has any significance?
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Reply 607 of 651, by analog_programmer
gmaverick2k wrote on 2024-11-24, 13:22:
Seems like it's AN37 pin - Vss i.e. connection to ground. One of many others, so no problem.
Reply 608 of 651, by gmaverick2k
....and its dead, janky soldering resitor blob, suspect overheating 500c solder iron....
Reply 609 of 651, by analog_programmer
gmaverick2k wrote on 2024-11-24, 14:36:
Looking at last picture it seems like you chipped the crystal.
Rust in pieces K6-2+.
Reply 610 of 651, by gmaverick2k
analog_programmer wrote on 2024-11-24, 14:54:
-_-'
damn...
tried to resus it... cpu down... RIP
I cant solder for sh**..
Reply 611 of 651, by RayeR
Uh, not much comfortable seeing the CPU execution by bad work, I'm still looking for K2+ but they are not available for reasonable prices as in the past, an couldn't find any in my country...
Reply 612 of 651, by gmaverick2k
RayeR wrote on 2024-11-24, 15:05:
had to import it from the US for a decent price. well thats money down the toilet... wanted this to be a DOS/98 PC. ah well, k6-2 500 or pentium 166 mmx?..
Reply 613 of 651, by RayeR
In my case the shipping from US is no-go, many times higher than eu...
If you have K6-2 500 it's still good powerfull CPU if you have 100MHz FSB capable MB...
Reply 614 of 651, by Sphere478
Heating the cpu first like with a hair dryer or a heating bed helps.
Yeah, there is a lot to go wrong when doing this. Be careful.
Indeed that lost pin is a power/gnd pin so not super critical. Who knows what else it may have broke though.
And as others said, chiped die. 🙁
There are people selling modded ones if you look around. Or you could try again. Sorry.
Sphere's PCB projects.
Reply 615 of 651, by gmaverick2k
Sphere478 wrote on 2024-11-24, 21:37:
Heating the cpu first like with a hair dryer or a heating bed helps. […]
Nay worries, had some luck getting my new used cars mpg up by 10 by cleaning MAF sensor and changing air filter. Thought I was on a roll. You win some you lose some...
Reply 616 of 651, by H3nrik V!
gmaverick2k wrote on 2024-11-24, 22:02:
Lots of gas savings to buy retro computer hardware, then 😁
Reply 617 of 651, by BitWrangler
Yah, there's only two things I would recommend for getting the heatspreader off, disposable razor blades or dental floss, and very light leverage along a broad edge when the corners have been well cut.
What about...
Chef's knife? NO!
Meat Cleaver? NO!
Splitting Maul? NO!
Two handed axe? NO!
Hatchet? NO!
Carpet Knife? NO!
2" Chisel? NO!
Any other random edged or vaguely pointed implement that isn't a razor blade? NO!
Reply 618 of 651, by gmaverick2k
Just purchased another for 25 quid from china, K6-2+ 500 ACZ... Hopefully it arrives before xmas. May not mod it, just use the stock cache available and software underclock feature
