Reply 240 of 261, by 0xDEADBEEF
weedeewee wrote on 2024-10-26, 14:01:
0xDEADBEEF wrote on 2024-10-25, 23:37:
Aww, did I miss it? My searches show nothing.
It's item number 135316842371 . If that means anything to you.
Yep, it didn't show up in any searches because there is no shipping option to USA.
Reply 241 of 261, by weedeewee
0xDEADBEEF wrote on 2024-10-26, 14:57:
Odd, I checked shipping details, and there it mentions
Ships to Worldwide
Oh well 😀 Glad you found it.
Do not ask Why !
Reply 243 of 261, by dreamblaster
I made a special edition PicoMEM Audio Edition", with the PCM5102A stereo DAC integrated on the PCB
https://www.serdashop.com/PicoMEM
61.27 KiB
Thanks for your support !
Reply 244 of 261, by NightShadowPT
dreamblaster wrote on 2024-10-30, 07:39:
61.27 KiB
This looks great.
Any chance of a version that will be compatible with the old systems that have an external ISO expansion (like the Ollivetti PC1 or the Schneider EuroPC)?
This model will most likely not fit the expansion due to the support for the bracket.
Cheers,
NightShadowPT
Compaq Deskpro M 486/66 - 64MB Ram - Compaq QVision 1MB - Orpheus II Sound
Card - 4GB SCSI HDD + 4GB CF Card - SCSI CD-ROM Plextor PX-32TSi - Adaptec WideSCSI AHA-2740W - 3COM Etherlink III Card
Reply 245 of 261, by amateus
I have bought this and it's amazing. I do have a quick question, however.
I want to use a ps/2 mouse and if I connect it with a ps/2 to usb adapter, the mouse is not found. Any way I can get this to work? Or am I asking a lot?
Thanks
DOS Box 1: 486DX2 MHz, 8MB RAM, Cirrus Logic, PicoMEM
DOS Box 2: 486DX4 100MHz, 16MB RAM, SB AWE32, S3 VIRGE GX2 + 3dfx Voodoo 1
W98 Box: P4 2.8MHz, 512MB RAM, SB Audigy 1, GF 6600 GT
XP Box: P4 3.20 MHZ, 4GB RAM, SB X-Fi, GF GTX 28
Reply 246 of 261, by weedeewee
amateus wrote on 2024-11-18, 16:56:
Hi, […]
Thanks
Your PS2 mouse likely does not support USB, thus usage of a passive adapter will not work. You will need either a USB mouse or an active USB PS2 adapter which most often can be found in the variety that has two ps2 connectors, one for keyboard, one for mouse.
Do not ask Why !
Reply 247 of 261, by amateus
weedeewee wrote on 2024-11-18, 18:26:
Hi, […]
Thanks
Understood, thank you for the quick reply.
Reply 248 of 261, by amateus
Another issue came up. Mouse is working fine on DOS but not on windows 3.1
I see we have an OPEN issue on github (https://github.com/FreddyVRetro/ISA-PicoMEM/issues/47), but did someone managed to make this work?
Thanks.
Reply 249 of 261, by amateus
Also, another issue: It appears Adlib support is not fully working? For example, on Bumpy I can hear the music, but not the sound effects, if that makes sense, or I am missing something?
Reply 251 of 261, by douglar
ychh0 wrote on 2024-12-01, 11:09:
I wonder someone tried GB size HDD image on PicoMEM. It seems PicoMEM can handle 4 disks then 8GB (2GB * 4 drives) can be used?
Volume size depends on the int13 handler in the bios and the version of DOS you are using. PicoMem includes an int13h handler from DoSbox, so the BIOS shouldn’t be a problem. If you are using FreeDOS, you should be able to mount some large img files. The main problem is that sometimes slower CPU’s are not always powerful enough to make navigating large FAT volumes pleasant. If you try to use a 2GB volume on an XT, you might find yourself wishing you kept it under 200MB.
Reply 252 of 261, by matze79
i installed Picomem in my Schneider Euro PC and it just works fine.
Thanks for making this.
Reply 253 of 261, by Caligula
I just saw that freddy pushed some commits to his git repo, including a big one with a lot of new source code: https://github.com/FreddyVRetro/ISA-PicoMEM/c … 24e85871e030db1
Changes according to readme:
### PM_W_Jan1: Various improvement in the RAM emulation, Corrections
- New: PSRAM Code improved (DMA Added): PSRAM based RAM and EMS is 30% faster.
- New: 5ns faster ROM/RAM Read cycles.
- New: Access to BIOS Memory doesn't add delay anymore. (Faster BIOS)
- New: Improved BIOS RAM Test, to detect RAM/ROM conflict.
- New: Added detection of cache enabled in the BIOS Address space.
- New: Disk infos now show the Head/Sector/Cylinder.
- New: Display why the EMS can't be enabled in the BIOS.
Reply 254 of 261, by dukeofurl
I am curious, there are some PCs, like Packard Bell 486s, that use varta batteries soldered to the board, and if the batteries are dead it will not let you boot from either a floppy or HDD until the battery is replaced.
Assuming the board has a dead battery but is still functional enough to post to the error, would picomem's bios serve to potentially get past that limitation of the motherboard bios?
Reply 255 of 261, by douglar
dukeofurl wrote on 2025-01-04, 16:08:
Seems like the systems that can’t boot without a battery halt during the power on self test. PicoMEM bios works like an option rom, no? It wouldn’t take effect until after the power on self test completes.
Reply 256 of 261, by FreddyV
No, it can't
Reply 257 of 261, by FreddyV
Just saw that someone published the news on the latest Firmware.
I also published a new PM2000 Driver. (Wifi network packet driver)
It can now work for machines with a CPU > 80186
The problem was the "fix" I found here (Vogons) for 8bit card.
This fix was working for 8086/8088, but not for machines with 186 or more.
Also mtcp author did a fix in mtcp preventing the Wifi based network card to stop working after a timeout (Without trafic)
This new mTCP and pm2000 should solve some problems then.
Reply 258 of 261, by Opualuan
Just received this great device. Another request for usb keyboard support, as i’m using an At&t 6300 (Olivetti M24) that uses a proprietary keyboard and mouse interface. I need to buy a stock keyboard for testing now, but hopefor a solution that will work with my usb kvm….
Reply 259 of 261, by Caligula
Opualuan wrote on Yesterday, 01:39:
I'm not sure if the PicoMEM (or PicoGUS) can emulate a keyboard in parallel to the original keyboard controller.
But there is a project for connecting a standard DIN keyboard to an Olivetti M4: https://forum.vcfed.org/index.php?threads/oli … emulator.67339/ and there is also a project to convert a USB keyboard to a PS/2 keyboard (PS/2 and DIN are electrically compatible, so you can simply connect CLOCK to CLOCK and DATA to DATA): https://github.com/No0ne/ps2x2pico
With some effort it should be possible to connect the Pico directly to the 74LS07 (skipping the Levelshifter and the Arduino completely).
