First post, by Blavius
Hi all,
I got a POD83 without a fan, and wanted to make something that matched the original and didn't modify the POD.
It's a model in FreeCAD that takes a 5Volt 40mm fan and connects to the POD with a set of pogo pins. The POD is aware of the fan because of a 1kOhm resistor.
The model consists of two parts; the main mount, and the pogo-pin holder.
The attachment model.png is no longer available
The attachment model2.png is no longer available
This is what it looks like assembled and on the POD:
The attachment IMG_7911_small.jpg is no longer available
The attachment IMG_7915_small.jpg is no longer available
Parts list:
-1x Noctua NF-A4x20 5V
-3x pogo pins 5mm long, 1.5mm diam (https://nl.aliexpress.com/item/1005006095992803.html)
-1x 1kOhm trough-hole resistor
Build instructions:
1. Mount the fan with the screws included in the Noctua kit.
2. Clip the wires. Be careful to keep enough length to assemble easily.
3. Strip the red and black wires. Not yellow- not used in this project.
4. Solder pogo pins to red and black
5. Solder the resistor to the pogo pin with the black wire. Then solder another pogo pin to the other side of the resistor.
6. Use pliers to press the pins in the pogo-pin holder. Use schematic below, this represents the pads of the POD as seen from the top. Be careful not to bend them or break the wire off-you cant solder once they are in the holder, it will melt!
7. Press the pogo pin holder in the main model.
8. Click on POD. Might need to trim a bit with an x-acto here and there.
| BLK(gnd) Fan(1k resistor to gnd)
| RED(5V)
I hope this is of benefit.
FreeCad projects and STL files for printing:
The attachment 3d_models.zip is no longer available
Reply 1 of 4, by cloverskull
Wow, this is great. I have the original fan, etc., but am wondering now how this performs in comparison. Very nicely done.
Reply 2 of 4, by H3nrik V!
Double post
Reply 3 of 4, by H3nrik V!
You may want to post that here: Retro 3D print topic as well
Reply 4 of 4, by Horun
Nice ! I have a POD83 (or 486 ODP as some call it) and did not know the cpu had a fan sensor pin. Guess old dogs do learn new tricks 😀
