Reply 120 of 281, by DustyShinigami
- l33t
megatron-uk wrote on 2024-12-17, 15:38:Simon the Sorcerer actually has an odd MIDI soundtrack - with functionality for both GM (i.e. SC-55) and Roland MT-32 - an earlier device than the SC-55, and something that isn't really replicated correctly by any other hardware MIDI device. Often games with MT-32 optimised soundtracks actually programme new sounds into the device when the game loads... you won't find a similar playback on anything other than an MT-32 (or equivalent Roland device: https://en.wikipedia.org/wiki/Roland_MT-32).
My guess is that you've played it with the GM soundtrack using a cut-down version of the Roland soft-synth previously. It won't sound massively different on a real SC-55 in that case. Perhaps you've heard the MT-32 version elsewhere? It would sound quite a bit different to the GM mode.
Yeah, I’m aware of the differences between the two; I’ve given them a listen. Well, the MT-32 briefly. I also tried the MT-32 emulation on the SC. I’ll have to attach a video of the two soundtracks I’ve heard. I’m just a bit unsure why I got the correct SC version on my Windows 10, but not the 98. Unless you need to have basic GM to begin with…? My 98 sound card doesn’t have any at all as it’s an ISA card with only MPU-401 support
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
