Data Delivery Board
First post, by raymv1987
All,
I'm currently trying to bring this old EISA data delivery board back to life. I am curious if anyone recognizes what drivers/.cfgs it may need based on
Reply 2 of 91, by raymv1987
wierd_w wrote on 2024-12-22, 02:41:
Eisa has a digita board ID, like pci or mca does.
See what the bios says that ID is, and I'll look for you.
I'm newer to EISA. Just connecting the board and checking the BIOS should tell me?
Reply 3 of 91, by wierd_w
You will need an eisa config utility, and a .cfg for that card.
This setup program may or may not work...
http://www.vogonsdrivers.com/getfile.php?fileid=746
You'll find a large collection of .cfg files here
https://web.archive.org/web/20190521043143/ht … /~mR_Slug/EISA/
Reply 5 of 91, by raymv1987
Will give the scanner a good look. I've got the utility and configs for the motherboard in my machine. Hopefully they point me to a board ID for this board and I can find out what files it needs. I do not have a .cfg for this specific card.
Reply 6 of 91, by PC Hoarder Patrol
raymv1987 wrote on 2024-12-22, 05:36:
Try running the Board ID app (boardid.exe) in this Micronics EISA package... http://66.113.161.23/~mR_Slug/pub/EISA/source … ICS/MICRECU.ZIP
Reply 7 of 91, by raymv1987
Tried both of the suggested utilities. Neither detected anything. However, there are lights on the board that come on when the machine powers on and I'm able to plug in another pc via serial to that 3rd serial port that has the cable connector and get a program to communicate with it.
Reply 8 of 91, by the3dfxdude
That's likely a data acquisition card. You'll need drivers to use it. So you'll need to identify the card and figure out if it required proprietary modules to get any use anyway. I would not treat those as typical rs232 ports.
Reply 9 of 91, by Horun
Exactly ! Will need the drivers/interface software too.
Being made of three very large scale field programmable gate arrays and with two bios chips (most likely one for the 80188 cpu, the other to program the fpga's) it will be near impossible to figure out.
Do you have a eeprom reader ? The bios chips may give a hint as to who made the adapter or who used it.
Eisa .cfg's for Xilinx and Altera products are very hard to find as they are somewhat specific to each special adapter and their bios's...
Reply 10 of 91, by BitWrangler
the3dfxdude wrote on 2024-12-23, 03:44:
Aquisition cards tended to favor the bus type serial protocols, like RS-485 or something. Or they went for distance/speed with RS-422... RS-232 still possible though.
Reply 11 of 91, by raymv1987
So the serial port connected to the cable can connect via rs232. The 2 fastened to the board are rs422.
I have had the chips dumped and just need to find a hosting spot for the .bin files. This board was made by Scientific Atlanta and used to broadcast data for the Sega Channel game service.
Reply 12 of 91, by raymv1987
I'm actually working on a project to revive the service at least at a kiosk level. I've got all the appropriate gear and most of the software. The general flow is that the end user inserts a cd containing that month's games into the game server. A series of .exes run that copy the data from the CD to the hard drive, set a run schedule, and then push the data to the board. Board then pushes to some RF modulators via rs422 and then to a combiner and to the Sega. This .cfg conundrum I believe is the only prospective blocker.
Reply 13 of 91, by Disruptor
During bootstrap your EISA BIOS will complain about changed or incorrect hardware.
The next step is to run an ECU:
When you (re)configure your system with an ECU (Eisa Configuration Utility) it will ask for the driver. It will say which !XXXYYYY.CFG file it needs. XXX = Manufacturer YYYY = Device
Reply 14 of 91, by raymv1987
So when booting my system, I'm not seeing any missing hardware complaints. When running my machine's ECU, it doesn't even show a board detected in that slot.
If anyone wants to see if you can make heads or tails of this, I've dropped them here:
https://www.dropbox.com/scl/fi/lq69dfogtld3sv … t=igczl9az&dl=0
https://www.dropbox.com/scl/fi/4u3tos4fn6qhx1 … t=v2a2vw7k&dl=0
Reply 15 of 91, by BitWrangler
Sounds like you're talking about something more like a primitive cable modem rather than a normal RF modulator as we know them for hooking up TVs, though modem of course means modulator and demodulator.
Edit: So that makes me think you might need something more like a network card driver, than a port driver. Where earlier OS tended to ignore network cards until you told them they were there.
Reply 16 of 91, by raymv1987
Interesting note. The rough setup worked like this
However, the data board in question can connect directly to the 2 RF modulators. This was allowed for localized demos. I've got the specific models outlined in the documentation along with frequency instructions. If I can get to a point where my server picks up this board and the .exe says the broadcast is good rather than timing out I should be able to get this rebuilt at a local level.
Reply 17 of 91, by weedeewee
an EISA card with jumpers to set IRQ & DMA.
How odd.
raymv1987, Do you have the software that supports this card ?
Do not ask Why !
Reply 18 of 91, by raymv1987
weedeewee wrote on 2024-12-23, 18:15:
How odd.
That was my thought. I've never seen anything like it. This is the exe that pushes data to the board itself.
https://www.dropbox.com/scl/fi/o5k9pcoim7rkax … t=uijsoydz&dl=0
Reply 19 of 91, by weedeewee
raymv1987 wrote on 2024-12-23, 19:20:
How odd.
Is that all the software you have, a 32Kb executable?
Also, do you have more hardware for the transmission and reception parts ?
Do not ask Why !
