Reply 60 of 472, by Kahenraz
igna78 wrote on 2024-12-25, 00:30:
MK1869 Extreme is amazing, the only thing I wish was different is the ability to use memory SIMs (I don't like soldered memory on sound cards) 😉
I prefer the opposite. The Orpheus II was so large that I had to cut a hole into my case for it to fit.
The attachment 20240904_203012.jpg is no longer available
The attachment 20240904_202837.jpg is no longer available
Reply 61 of 472, by igna78
I think Orpheus II is so long because the card is the set of multiple devices in one (just think about how much space the PCMidi part takes up).
In my humble opinion, if MK1869 Extreme adopted the layout of the Gravis UltraSound PnP Pro (substantially shorter than a SounBlaster 16) could have sockets for memory SIMs, having a card slightly longer than the ISA slot 😉
Let's be clear, I find the work done on MK1869 Extreme exceptional, I think it is more practical to have sockets for memory only to more easily maintain the card in case of memory failure, differently from what would happen with soldered chips 😅
I reiterate my idea, not to create controversy, but only to clarify the concept, certainly not correctly stated in the previous post.
I would like to thank the guys from the Orpheus team for this new and extraordinary card, for the commitment and passion they put into their work. Thank you sincerely ❤️
Reply 62 of 472, by Kahenraz
mockingbird wrote on 2024-12-24, 22:29:
Kahenraz wrote on 2024-12-24, 20:27:
I have been casually looking out for these for the past couple of years and have only ever found one, so they do exist. They are just exceedingly rare.
Care to back that up with a pic? I have never seen one, and I have seen pics of many variants.
I'm not concerned about Win 3.1... For Win 3.1, build a 486.
Here go. YMF724F-V with SB-LINK and Waveblaster expansion-header. I've only ever seen this one. Picked it up on eBay years ago. It pairs well with the DreamBlaster X2GS. Genuine Yamaha OPL, Yamaha XG, and Roland GS, all on one card. Use the SB-LINK for DMA in DOS.
I'm not sure what the unpopulated spot is for on the right. The YMF724 already has GeneralMIDI built into it.
The attachment 20241225_004257.jpg is no longer available
Reply 63 of 472, by keropi
as a sidenote the length of OrpheusII was because it needed to support full-size wt boards (like the old roland/yamaha ones)
the problem with angled 30pin simm sockets is availability - there will either be too few available and/or ultra-expensive at this point...
getting dram chips is actually preferable
Reply 64 of 472, by Kahenraz
The plastic clips on my Orpheus II RAM slot make me nervous. I understand that you had to go with what stock was available. They probably don't even make the ones with metal clips anymore.
This is not a problem with soldered memory.
Reply 65 of 472, by mockingbird
Kahenraz wrote on 2024-12-25, 05:55:
You just blew my mind.
(Decommissioned:)
Reply 66 of 472, by Shponglefan
Kahenraz wrote on 2024-12-25, 13:02:
SIMM sockets with metal clips should be available. Mouser has about ~1500 in stock.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 67 of 472, by ltning
Wow, that Extreme could actually replace some of my real Extremes.. At least one of them has broken down and even with professional help I haven't been able to figure out what's wrong with it.. :(
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 68 of 472, by Rawit
I own 2 Extremes and even with that I'm keen on getting a MK1869 XTREME. How is audio routed? Interwave part goes through AUXB on the ESS? How is the wavetable header audio routed? And can the Interwave and a wavetable be active at the same time (I see a Wavetable Selector jumper).
YouTube
Reply 69 of 472, by keropi
Both IW and WT header are routed through AuxB and ofcourse they can work at the same time (ie have sfx via iw and music via wt in Doom)
The midi-routing jumper block is the same as Orpheus, only relevant if there is a pcmidi addon installed
Reply 70 of 472, by Rawit
Sweet! Is there any chance that a hole will be added to secure a wavetable daughterboard with one of those pins? Half sized daughterboards will sit a bit more securily in that case.
YouTube
Reply 71 of 472, by keropi
Rawit wrote on 2024-12-29, 11:41:
the only possible place is on the right side of the wt header so not that useful IMHO
Reply 72 of 472, by Rawit
That might actually help a bit with heavier & not tight fitting boards but does that throw off the design/costs a lot?
YouTube
Reply 73 of 472, by keropi
Cost is nothing, it's a hole
We'll see if we can implement it at least on the black card - I cannot tell currently if there is space on the xtreme to move things around in order to create the space needed
Reply 74 of 472, by Kahenraz
What good is a hole? Aren't all wavetable boards uniquely sized?
Reply 75 of 472, by Rawit
The newer ones are so small they don't have any need for mounting holes. But the older ones are full sized or a variant of half sized and can use those for support pins. Some have a lot of weight as well.
YouTube
Reply 76 of 472, by RetroGamer4Ever
mockingbird wrote on 2024-12-25, 13:51:
It's basically the earliest model, which is why they are so rare. Yamaha and the market decided that softy was a better way to do things, so the wavetable header was removed from future reference designs and with the decline of MIDI in games, there was never any push to bring it back, while those who needed MIDI for music stayed with softy or used the hardware modules.
Reply 77 of 472, by crusher
Woah that MK1869 XTREME looks like my dream all-in-one soundcard 😀
Can't wait to hold one in my hand...
Reply 78 of 472, by keropi
brackets arrived today , as always stainless steel ones 😁
Reply 79 of 472, by Kahenraz
Attaching the PCMIDI module like that looks like it's going to block larger wavetable boards from being used.
