mateusz.viste wrote on 2024-09-20, 12:37:
vetz wrote on 2024-09-20, 09:20:
1. Can it run in a DOS window under Win9x?
I doubt it. ETHFLOPD for DOS requires a packet driver to send/receive Ethernet frames. I do not think that Win9x provides such interface. A quick web search tells that there is a thing called WinPKT, but it's only for Win 3.x, apparently.
Unfortunately it is missing from this list of network shims maintained by another member of these forums, but I remember using NDIS3PKT for this sort of thing - I ran ETHLOAD under Windows 95 using it in the past, I think as per these instructions.  This thread talks about a registered version of NDIS3PKT, but I don't recall the version I used needing registration; it had this license:
NDIS3PKT is licensed free of charge for personal and internal
business use only.  NDIS3PKT may not be distributed for profit,
no […]
nor may it be included in products or otherwise distributed by
commercial entities to their clients or customers without the
prior written permission of the author.
which didn't negatively affect my use.
If you (vetz) can't find a version of it online that works for you, let me know and I can look around some more, or upload the version I have.
Additional compatibility information:
Ndis3pkt.386 is a Windows VxD (Virtual Device) which provides a packet
driver interface on top of NDIS version 3.0 or 3.1.  It a […]
driver interface on top of NDIS version 3.0 or 3.1.  It allows packet
driver applications to be used under WfWG 3.11 and Windows95 without
loading any real-mode software components.
I probably used it with Windows 95 RTM and/or OSR 1.
