First post, by Dimos
Greetings to all! I am writing this short guide in order to help anyone that wishes to install Ahci drivers and enable Ahci mode to a Windows Xp OS that has been already installed and is running in Ide mode.
I myself have spent a lot of time and effort trying to get the proper drivers installed and Ahci mode to work on my existing Windows Xp build and after unsuccefully trying every method posted online i finally had success with the following method, (found here: https://www.os2museum.com/wp/booting-windows-xp-or-not/) which i think is going to work on every pc already running Windows XP.
Diskclaimer: the drivers provided in step 2 are for an Intel based Sata Controller, but the procedure remains the same for any other type.
So here it is:
1. Boot normally in IDE mode
2. Unpack this WinRar file anywhere you like (which contains the best Achi drivers package for Windows Xp and covers almost any Intel based Sata controller, found here: https://winraid.level1techs.com/, if you have another type of Sata controller search the same site for it):
The attachment Generic 32bit Intel RST AHCI driver v11.2.0.1006 mod+signed by Fernando.rar is no longer available
3. From the contents of the unpacked archive copy iAstor to: Windows/System32/drivers
4. Execute the following CMD command:
The attachment Execute This On CMD.txt is no longer available
5. Add the following string to the registry (save the text document as a .reg file type and execute it to add it to your registry) :
The attachment Add this to the registry.txt is no longer available
6. Reboot your Pc, enter BIOS and change your boot option from Ide to Ahci mode
7. Manually add the Ahci driver through Device Manager in Windows
Done!
I hope this little guide will be helpfull and save anyone interested in the subject from unnecessary trouble, frustration and hours searching for the proper way to manage this.
Cpu: Intel i7 4790k
Gpu: Gigabyte Xtreme Gaming 980 ti
Ram: G-Skill Trident X F3-2400C10Q-16GTD
Mobo: Gigabyte Z97x Gaming 5
Hdd: T-Force Vulcan Z 512 gb Ssd
Psu: Corsair CX650
Soundcard: Creative SB Audigy RX
Os: Windows XP Sp3 x86
Reply 1 of 17, by RetroPCCupboard
Nice first post! Welcome to the forum.
I've just been considering how I can do this exact thing on my Z77 board for installing XP. I currently am in the process of installing the OS (again, after it somehow got corrupted)....
Reply 2 of 17, by Dimos
Thanx!
Well, it's another (simpler) procedure if you want to do it during XP installation, the tricky part is to somehow enable ahci mode if you didn't install XP in ahci mode in the first place. You can use the driver i posted above during the os installation (the F6 method) and Windows XP will be installed in Ahci mode.
P.s. Make a backup of your system regularly, trust me, saves you from a lot of trouble!
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 3 of 17, by RetroPCCupboard
Dimos wrote on 2025-01-15, 14:32:
Thanx!
I tried that, but it insisted on loading the driver with F6 method from a floppy disk, but this motherboard has no floppy disk controller on it. Nor IDE for that matter.
Reply 4 of 17, by Dimos
It's not necessary to have a floppy disk drive, you can slipstream the necessary drivers into a Windows XP installation cd/dvd via nLite or you can try to install the os from a usb drive together with the Ahci drivers: https://www.prime-expert.com/articles/b02/ins … omISOWithoutDVD
If this seems too much of a hustle, install Windows XP normally (in Ide mode) and then you can try the post installation process i described in my post.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 5 of 17, by RetroPCCupboard
Dimos wrote on 2025-01-15, 16:59:
I followed your instructions and it worked great. The only thing I changed was I used the sata drivers that I downloaded from Asus website, rather than the ones you provided.
Prior to doing this XP would just crash on boot if I enabled AHCI on BIOS.
Reply 6 of 17, by Dimos
That's great! I too had the same result with every other method i had tried, and trust me, i spent a lot of time trying to make it work till i followed this exact procedure.
Glad you had successfully done it!
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 7 of 17, by Opualuan
Thanks for putting this together! I also have a Z77, worked well for me after I substituted the iastor drivers from the asus site. Crystal diskmark reads went up substantially.
Thanks for saving me from reinstalling!
Reply 8 of 17, by Malik
Actually you don't need to enter command line or even touch the registry manually.
All you have to do is to get the Intel Rapid Storage driver for your current chipset.
Just for an example:
I recently got a used HP 8770W workstation laptop which comes with the i7 3920XM processor. It comes with the QM77 chipset. The corresponding IRS driver will be the Intel 7 series chipset SATA AHCI driver (not the /216 that also comes with the driver).
1. Install XP with IDE mode in BIOS. After installation, expand the downloaded Intel Rapid Storage driver. (Mine is downloadable from HP website. But it can also be downloaded from Intel website or corresponding motherboard maker's website.)
Note: the exe file can be extracted with 7-zip. The files will be extracted into DRIVE:....\Intel Rapid Storage Technology Driver\Drivers\x32
2. After running XP for the first time, go to Device Manager.
3. Expand IDE ATA/ATAPI controllers
4. Click on the 4-port SATA driver. If not available choose the 2 port SATA driver. (It may differ from system to system.)
5. Upgrade that driver and point the windows :
a. Install from a list or specific location (Advanced)
b. Don't search. I will choose the driver to install.
c. Have disk
d. {Point to the above location where the IRST driver is extracted.} Choose iaAHCI.inf file
e. Depending on your system, you need to choose the correct driver. In my case, it is the Intel(R) 7 Series Chipset Family SATA AHCI Controller. Beware, that there is also the similar looking
Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller which won't work.
After changing the driver, reboot into BIOS, change back to AHCI mode, and Windows XP supposed to boot normally.
If not, change back to IDE mode, and choose another port to upgrade the driver to AHCI.
By this method, you will maintain the actual compatibility with your chipset and motherboard.
I've done this before on my desktop when I was using the i5-2500K processor. I also have done it in my Thinkpads E530 and X230, and now the 8770W.
P.S. I'm writing all this in Windows XP 32-bit in the said 8770W laptop, with Supremium (Chrome fork for older OSs, with Panda Dome Security).
Reply 9 of 17, by Dimos
Well the truth is that it kind of works in that way. For many chipsets this will be (kind of) sufficient and will get mostly the job done. But...
This method, which is the one mostly reported online, (if you read the original post https://www.os2museum.com/wp/booting-windows-xp-or-not/ from which i mentioned that i got the proper method) does create a little mess. What it really does is forcing the Ahci driver onto an existing ide controller of your system. If, like in your's and many others' cases, you have the access to the correct driver for your chipset it may work and the system, after changing the boot parameter in bios from ide to ahci, will boot normally. But in many cases this will not suffice (like in mine) and as i said before it really messes things around cause you forced the ahci driver onto the ide controller. If you for example tried to boot again in ide mode you would find yourself unable to do so because of this.
The difference of the method i described is that it prepares the system to boot using the iastor.sys from the (compatible with your chipset) ahci package and by booting again (after you changed the boot parameter in the bios from ide to ahci mode) the ahci controller gets loaded and then you can update it in the device manager with the proper ahci driver. This way everything is installed the right way (ide controller stays untouched as it was, ahci controller gets updated with the proper driver), it is guaranteed to work in any system with any chipset (as long as there is a compatible driver for it! - try the https://winraid.level1techs.com/ that i already linked to in my original post and you will most probably find one) and you are also guaranteed that you will never experience any trouble, any shortcoming of any kind and you can freely boot in either ide or ahci mode whenever you like.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 10 of 17, by Malik
Not sure about the problems, but I've been doing this for quite some time (since the days of 2nd gen core CPUs), and I feel using the chipset's original drivers will give better compatibility without causing problems. Besides, it's a straight forward method. The main thing, is to choose which part of the IDE controller that you have to upgrade.
Reply 11 of 17, by myne
Seems like it's time for someone to build a more up to date slipstreamed iso
I built:
Reply 12 of 17, by Dimos
Of course if you have a cd or you can find on your motherboard' s site your chipset's original drivers that' s the best option with either method. The only difference between the two is that the one forces the ahci driver to the ide controller (which oftentimes will work fine) while the other enables you to boot with the ahci controller and install the driver to it. In my case, using the exact same driver, the first method didn't work while i had success with the second.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 13 of 17, by firefoxray
Bro, I've been fighting with XP trying to get ACHI working for about 7 hours now and this was the thing that finally fixed it. Thank you bro, saving and archiving this for the future for sure. Made building my xp/7/linux build so much easier.
Reply 14 of 17, by sabreu
Thanks for sharing.
There are videos recommending nLite to add the drivers, but it fails, is a lost of time!
Your information was precise and lovely useful.
Everything worked like a charm!
Regards
Reply 15 of 17, by C0deHunter
I can confirm that after hours of painful trial and error with numerous other methods, I tried your simple steps and it WORKED! Can't thank you enough!
My system:
ASRock B85 Killer MoBo
Intel B85 Chipset
Core i7-4790 3600MHz CPU
4GB (2X DDR3-1600 Kingston)
GeForce GTX 980Ti
Windows XP x86 SP3 Retail
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 16 of 17, by Dimos
Thank you all. It is a method that is guaranteed to work and also very useful when trying to migrate your existing Xp installation into a recent/not officially supported mobo chipset. If you already have followed the above steps and successfully enabled ahci support in an older mobo that supports legacy/ide mode then you can transfer your existing os to a newer mobo that only supports ahci (along with other potential necessary steps like a patched acpi). Thats what i did when i transferred my sandy bridge based os installation to a z97 chipset mobo.
Cpu: Intel i7 4790k
Psu: Corsair CX650
Reply 17 of 17, by dr_st
Very good guide!
I believe some early versions of Intel Matrix Storage Manager (the AHCI/RAID driver) shipped with an IMSM_PRE.INF and a pair of install/uninstall scripts to do just this.
You boot in IDE mode, install the AHCI driver, run the script that enables the service and puts it into the boot-critical list, then you reboot, enable AHCI mode in the BIOS, and Windows automatically starts the correct service.
I also seem to recall that in Vista/Win7 things were a bit simpler - one just needed to make sure that the service for iaStor/msahci is enabled for boot-start (Start=0). Of course, the very fact that they had the MSAHCI generic driver / iaStorV inbox driver already made them more compatible.
Conversely, you could run into an issue if you installed in AHCI mode, and then decided to switch to IDE mode. The driver is there, but PCIIDE might be disabled from auto-start, and you would get the same 0x7B BSOD. I had it happen to me once when I temporarily had to replace and ICH10R motherboard with an ICH7 one (no AHCI support).
