First post, by Dimos
Greetings to all! I am writing this short guide in order to help anyone that wishes to install Ahci drivers and enable Ahci mode to a Windows Xp OS that has been already installed and is running in Ide mode.
I myself have spent a lot of time and effort trying to get the proper drivers installed and Ahci mode to work on my existing Windows Xp build and after unsuccefully trying every method posted online i finally had success with the following method, (found here: https://www.os2museum.com/wp/booting-windows-xp-or-not/) which i think is going to work on every pc already running Windows XP.
Diskclaimer: the drivers provided in step 2 are for an Intel based Sata Controller, but the procedure remains the same for any other type.
So here it is:
1. Boot normally in IDE mode
2. Unpack this WinRar file anywhere you like (which contains the best Achi drivers package for Windows Xp and covers almost any Intel based Sata controller, found here: https://winraid.level1techs.com/, if you have another type of Sata controller search the same site for it):
3. From the contents of the unpacked archive copy iAstor to: Windows/System32/drivers
4. Execute the following CMD command:
5. Add the following string to the registry (save the text document as a .reg file type and execute it to add it to your registry) :
6. Reboot your Pc, enter BIOS and change your boot option from Ide to Ahci mode
7. Manually add the Ahci driver through Device Manager in Windows
Done!
I hope this little guide will be helpfull and save anyone interested in the subject from unnecessary trouble, frustration and hours searching for the proper way to manage this.
Cpu: Intel i5 3570k
Gpu: Gigabyte GV-N970IXOC-4GD
Ram: G.Skill Ares F3-2133C11D-16GAR
Mobo: Asus P8h61-m LX R2.0
Hdd: T-Force Vulcan Z 512 gb Ssd
Psu: Thermaltake Hamburg 530w
Soundcard: Creative SB Audigy RX
Os: Windows XP Sp3 x86
