Reply 29080 of 30568, by PTherapist
Today I did something that I've never attempted before - desoldered & resoldered an EPROM DIP chip.
I bought an old French Thomson TO7/70 micro computer back in November/December. It didn't come with a BASIC cartridge, so the computer was essentially useless. However, it did come with the "Colorpaint" cartridge, a particularly useless drawing/painting program.
So I opened up the cartridge today and desoldered the EPROM chip and then put it into my programmer to back it up - just to ensure it was working correctly mostly, since the ROM is widely available online.
After backing it up, I put the EPROM into my UV Eraser to blank it and then I wrote the BASIC ROM, downloaded from the internet, onto the EPROM.
Soldered the chip back in, as there was no room inside the cartridge to add a socket.
All working great, I now have a usable working computer. My mediocre soldering skills are definitely improving. 🤣
Reply 29081 of 30568, by Daniël Oosterhuis
PTherapist wrote on 2025-01-15, 17:09:
I've heard people talk about recapping the CD & power boards too, but in my case everything seems to work fine now, so I'm leaving it be until it breaks haha.
Mine came from Japan, and I have noticed that devices with known bad caps do tend to be worse over there.
Some first gen PowerMac stuff I got from Japan also had massively leaky caps, even though all the first gen PowerMac stuff in the West generally hasn't really started leaking yet, or is just starting to.
Don't know if it's humidity or storage conditions, but the ones on the power board were super crusty and nasty too.
I did find it wasn't the source for my lack of video, it was actually on the "tree house" oscillator board, as frequent desoldering and resoldering from when I was trying to fix the original board (it overhangs the ASIC) had weakened a through hole.
Bodged it and I'm now getting good video + audio, though the CD drive still isn't fully operational.
I'll finish the recap this weekend, and give the CD drive some fresh lubrication too, which'll hopefully get it fully operational.
Reply 29082 of 30568, by H3nrik V!
vutt wrote on 2025-01-14, 15:39:
There is however one concern - CPU SL52Q VCORE suppose to be 1.75V but Bios/win tools are showing 1.8V. I need to find my multimeter...
I wouldn't worry too much about those 50 mV over voltage ...
Reply 29083 of 30568, by PcBytes
Recapped two of my recently bought mainboards and diagnosed two PA-2013s as being dead.
Mobos recapped:
-1x FIC PA-2013 - the first sample I got in fully functional state (as in cache working properly) - recapped using Panasonic FL and FJ series
-MSI 815EM Pro ver 5 - replaced 2700uF Teapos with 2200uF Nichicon HZ.
Reply 29084 of 30568, by ChrisK
What will you do with those dead PA-2013s? Planning to invest some more effort in resurrecting them? Or letting them go?
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 29085 of 30568, by PcBytes
ChrisK wrote on 2025-01-16, 08:49:
I'll keep them as I have a semi-functional one which needs a cache transplant. The semi-functional one has had a thread here, and basically freezes with a blinking cursor in the upper left corner inbetween the Energy Star POST screen and the PCI/ISA device lisiting.
Reply 29086 of 30568, by ChrisK
Alright, just wanted to be sure they aren't getting to waste until it's clear they definitely can't be safed 😉
Don't know their exact state but according your picture they are looking quite a bit "used", even besides the dust.
Sometimes it's just some minimal failure that prevents showing some signs of life. Anyway, you'll do the right thing 😀
Reply 29087 of 30568, by PcBytes
ChrisK wrote on 2025-01-16, 09:11:
I did test them (they were the first to be tested) and so far the only one working was the Winbond cache one (how ironic considering the semi-functional one is also Winbond). Both boards with TMTech cache chips do not work - one powers up but no POST, the other won't even turn on and has a nasty gouge across several traces.
I recapped two of them - the first TMTech that powers up got polymers, and the working Winbond got a full Panasonic treatment.
Reply 29088 of 30568, by Ozzuneoj
I've been tinkering with some random video cards today and I am being reminded of yet another reason that I don't spend much time with ATi hardware before the R300\RV350 era.
I have two 8MB ATi Rage Pro cards that look nearly identical, except one is a "Rage Pro Turbo PCI" with 8MB onboard and the other is a "3D Rage Pro PCI" with 4MB onboard + a matching 4MB expansion and TV outputs. When I ran some games on them I noticed the one with the expansion was HORRIBLY slow. Like, it felt like a first gen S3 Virge, even at 640x480. The other card ran significantly faster. Not great, but far far better than the other card... certainly decent enough for a 2D\3D accelerator from 1997.
The attachment ati_Rage_woe.jpg is no longer available
The BIOS chip on the slow one is marked RAGEPR PQFP 41904 107, the faster one is RAGEPR PQFP 41902 106.
I decided to check their clock speeds with PowerStrip and... whelp... I think I found the problem!? According to PowerStrip the faster one is clocked at 75Mhz Core, 100Mhz memory (higher than it seemingly should be, but correct for the 10ns SGRAM). The slow one? 36Mhz Core 48Mhz RAM!! What gives? Why is it clocked SO low??? Even the RAM is massively underclocked, since it also has 10ns SGRAM like the other card.
PowerStrip calls the faster one an Xpert 98, the slower one is an XpertPlay 98 or something like that.
I don't get this since everything I can find online says that the a Rage Pro is a Rage Pro, and any variations were just rebadge attempts by ATi to get people to take another look at their cards after they improved their drivers.
Also, the one with the memory expansion has a label on the back that says "NON-UPGRADEABLE" ... @_@
ATi was just such a baffling company back in those days. They had ~10 years more experience in this industry than most of the other companies that were succeeding in 2D+3D in the late 90s, their hardware was very well built (tantalum caps, nicely built boards, efficient and low heat output), most of their products were entirely first-party... but there was so much of this just inexplicable weirdness from them that just exacerbated their driver woes.
I am going to pop the BIOS chip out of the fast card (the OLDER version as far as I can tell) and drop it into the slow one to see if it "magically" turns it into a useful card with no other drawbacks. I bet it will. I will post back later once I have done this.
EDIT: Forgot to mention, they're using the same installation of the 2474 Rage driver.
EDIT2: Well, I didn't have to swap the BIOS chips. Inexplicably both cards are running fine now after some reboots and swapping cards back and forth. Powerstrip still detects the 4+4MB card with weirdly low clocks, so that appears to be wrong.
I also checked the clocks with SIV and the 4+4MB 3D Rage Pro shows 75Mhz core and 75Mhz memory, which is actually accurate. SIV also says that the 8MB Rage Pro Turbo is 200Mhz core, 100Mhz memory... which is clearly wrong. So, yeah, these cards must just be hard to measure the clock speed on. I haven't looked for an ATi Rage specific overclocking tool yet.
I haven't run any benchmarks to see if either is faster than the other, but I don't think it matters much at this point. They're probably decent cards for games up to 1998 or so.
Reply 29089 of 30568, by DarthSun
Ozzuneoj wrote on 2025-01-17, 01:05:
I've been tinkering with some random video cards today and I am being reminded of yet another reason that I don't spend much tim […]
I decided to check their clock speeds with PowerStrip and... whelp... I think I found the problem!? According to PowerStrip the faster one is clocked at 75Mhz Core, 100Mhz memory (higher than it seemingly should be, but correct for the 10ns SGRAM). The slow one? 35Mhz Core 58Mhz RAM!! What gives? Why is it clocked SO low??? Even the RAM is massively underclocked, since it also has 10ns SGRAM like the other card.
I have PQFP 41901/107.
The attachment 225621_irajzc2lgoi2vle9_atiragepro_pci_4+4m.jpg is no longer available
The attachment 225621_wnmds7h4p0qjitat_3800x2_rage_2800.jpg is no longer available
The attachment 225621_niqfetkhxmtcviqo_sst_memmax.jpg is no longer available
The attachment 225621_qovviywqfpp0dmkb_a64800speedsys.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 29090 of 30568, by Ozzuneoj
DarthSun wrote on 2025-01-17, 01:35:
Sorry, I don't see anything in those screenshots that shows the clocks on that card. Do you know what the core\mem clocks are on yours?
Reply 29091 of 30568, by DarthSun
Ozzuneoj wrote on 2025-01-17, 03:34:
I don't know and I'll write it down next time I use it.
Reply 29092 of 30568, by Kahenraz
The early Rage Pro is actually a great chip for its time when used in the appropriate context. It has good DOS super, accelerated 2D graphics, and is backwards compatible with Mach64 drivers in Windows 3.1. The 3D graphics support is very much a token gesture, but it's fairly capable in AGP form with a modest overclock. The Rage XL only improves on this with faster speed and additional blending modes.
It's not going to win any records, by the final drivers are excellent by the standards of the day and even include full OpenGL 1.1 support.
I'm pretty sure that the clock speed reported by Powerstrip is also wrong. I remember it being really messed up on my Rage XL, but dragging the slider still boosted performance considerably.
Why choose a Mach64 or Rage 2 over Rage 3?
What is the difference between the Rage Pro, Rage Pro AGP 2X, and Rage Turbo?
Reply 29093 of 30568, by Ozzuneoj
Kahenraz wrote on 2025-01-17, 07:12:
The early Rage Pro is actually a great chip for its time when used in the appropriate context. It has good DOS super, accelerate […]
Well, I didn't have to swap the BIOS chips. The "slow" card was actually so bad that the spinning Direct3D cube in dxdiag was choppy in software and hardware modes... which I've never seen before. But now, inexplicably, both cards are running fine after some reboots and swapping cards back and forth. Powerstrip still detects the 4+4MB card with weirdly low clocks, so that appears to be wrong.
Also, I just tested a couple of 3D Rage II cards and... WOW... ATi really made some massive improvements with the Rage Pro. In a pretty ancient game like Dark Forces II, the Rage Pro can pretty much play it fine at 800x600. The 3D Rage II, being only a 2MB card, is gasping for air at 640x480 even with the colored lighting turned off. The performance is passable (not great) with colored lighting at 400x300 though. Nothing like having a 3D accelerator and have to settle for 400x300 resolution. 😮
Reply 29094 of 30568, by lordmogul
More of a retro-ish activity:
Been testing cycle settings in DOSBox to see how close I can get to real hardware. Cylces are supposed to be KIPS (or rather 1000 cycles -> 1 MIPS), and the theoretical performance for many old CPUS is known, so I try to get presets that are as close as I can get in terms of performance, for speed-sensitive games.
P3 933EB @1035 (7x148) | CUSL2-C | GF3Ti200 | 256M PC133cl3 @148cl3 | 98SE & XP Pro SP3
X5460 @4.1 (9x456) | P35-DS3R | GTX660Ti | 8G DDR2-800cl5 @912cl6 | XP Pro SP3 & 7 SP1
3570K @4.4 GHz | Z77-D3H | GTX1060 | 16G DDR3-1600cl9 @2133cl12 | 7 SP1
Reply 29095 of 30568, by marxveix
Installing Windows 98 FDE with 39 disks and i am using gotek flashfloppy for it and you cant install it without real floppy or gotek,
like with Windows 95a or Windows 95b floppy disk edition it is possible to do. It takes more time than usual Windows 9x install.
Size of the Windows 98 FDE should be smaller than regular Windows 98 or Windows 98 SE, its smallest original Windows 98 OS.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 29096 of 30568, by dominusprog
Recapped this BEST UNION MF-719 sound card. Also replaced the transistor in the middle with a L7805CV regulator.
The attachment IMG_20250118_132458.jpg is no longer available
Reply 29097 of 30568, by smtkr
lordmogul wrote on 2025-01-17, 20:12:
There's a table online with this information. I'm guessing you are trying to be more precise, but it's probably a fools errand as the cycles number likely performs differently depending on the composition of the load. The rough guides in the table are probably fairly reasonable.
Reply 29098 of 30568, by MAZter
If anyone MSX, or MSX2 floppy drive fail, try this method:
The problem may be in the weakening of the spring that presses the head to the disk, because the head is too far away, the disk cannot be read properly (from time to time). For this, the manufacturer (Sony in this case) has provided different positions of the spring on the plastic part, if you move it to a higher level, the errors will disappear.
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
Floppy must be formatted before write image to it using command:
FORMAT A: /T:80 /N:9
Reply 29099 of 30568, by pan069
dominusprog wrote on 2025-01-18, 11:45:
Looks nice and clean. I think I have this card in a box somewhere... 🤔
