440bx chip swap with 440gx
Reply 20 of 25, by myne
So dimm 2 is B.
Dimms 0 and 1 are definitely both A?
I built:
Reply 21 of 25, by myne
Worth noting MAB12 is the 66/100 strap.
Here's the p2b net highlighted:
The zip might help too (kicad schematic WIP for p2b)
I built:
Reply 22 of 25, by dm-
yes, i have a p2b boardview and it is on my screen all the time.
Reply 23 of 25, by shevalier
dm- wrote on 2025-01-14, 05:20:
Hello community […]
Hello community
I was thinking to swap a 440bx chipset on my board to 440gx to get a 2gb of ram support.
according to datasheet, 440gx has a new signals MAA14/MAB14 (AE22/AE23) which is n/c on 440bx.
the question is, where to this signals must be connected on SDRAM side? some ppl thinking they must go to A12 signal lines of SDRAM, but they're already connected to MAA12 signals.
is there any boardview for 440GX boards available on internet?
I'm following your attempt with great interest.
Two questions:
1. Why not see how the memory is routed on the same VIA 694?
Re: Asus TUV4X and Pentium iii SL6BY 1.4GHz
2. Are there diodes on these address lines in the BX, or is it the NC?
Perhaps the GX and BX have the same die.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 24 of 25, by dm-
Update
Found semi-compatible gx bios and yes, 1gb stick has been detected.
Cuz this bios from industrial board it has huge amount of limitations.
So, looks like for proper work a bios patch required. some GX registers must be set.
The attachment 20251024_125055.jpg is no longer available
The attachment 20251024_125304.jpg is no longer available
upd2.
DRB[0:7]—DRAM Row Boundary Registers (Device 0)
Address Offset: 60h (DRB0) – 67h (DRB7)
Default Value: 01h
Access: Read/Write
Size: 8 bits/register
To specify a memory size of 2 GB, the DRB7 must be set to 00h. When this value is set, the
82443GX internally detects this value and sets the internal “2 GB system memory size” signal. It is
cleared otherwise.
Reply 25 of 25, by myne
Nice one!
Ask one of the bios mod guys if they can figure out what is different
I built:
