Reply 55960 of 57169, by dionb
- l33t++
Trashbytes wrote on 2025-02-03, 05:34:[...]
Viable is debatable but I guess it depends on what you are doing at home, if its email, youtube and word then sure its viable but anything modern and PCie 2.0 is showing its age hard, and DDR3 is slower than molasses. You will also have issues with modern UEFI GPUs which will likely not work or only work partially in a PCIe 2 board.
For high-end gaming Sandy Bridge is showing its age badly, but for general office work it's more than good enough. I only decommissioned my son's i7-2600 because it didn't have an M.2 NVMe slot and I had a bigger SSD (and faster GPU, but that would have worked) for him when his brother upgraded from i5-7600 to Ryzen, so just gave him the whole system.
The only issue is Windows 11 compatibility, but (for now...) you can circumvent the TPM2.0 check using custom install media and it runs as well as on modern systems (I am not a fan of Windows 11 UI).
myne wrote on 2025-02-03, 07:52:Ok cool.
What runs on xp that absolutely can't run on modern hardware?
Well, 32b Windows XP can still run 16b code, so you can run things like Civ II, Colonization for Windows and BI3 on it at higher resolution than would be feasible on your average WIn3.11 system...
