Reply 29181 of 30161, by Thermalwrong
Tiido wrote on 2025-02-06, 03:10:
That was some repair effort you did to that card 🤣
Cumulatively, yeah. But today it was maybe 30 minutes of troubleshooting... how did I miss this the last time I was looking at the card? Also looks like *I* didn't damage those vias, the jumper pins had all been removed on this scrapped card since the scrapper saw gold and took those too, from looking at the archived auction pictures.
CT1350s are pretty rare though and I've wanted a proper CT1350 again for a long time, this broken one is what I ended up with so it's cool it's working again. I mean I've got at least one clone card but CT1350 is what I had long ago.
Anyways, so glad it's done! Now I've got the card working and OPL2 sounds great on it - it does seem to be a bus noise listener card though 😁
Reply 29182 of 30161, by Nexxen
Checked what's wrong with my Voodoo2 I just bought.
Many pins are disconnected, but aligned, on a 500-0010, and one pin needs to be bent back but soldered.
There is some oxidation but overall looks nice.
With my other V2 (green one).
I guess Bits und Bolts was right about "always check the corners". 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 29183 of 30161, by PcBytes
Finally restored Windows ME on my Toshiba Satellite S2800-100.
file.php?mode=view&id=211768
I know the 2805 would be more desirable however I think the 2800 is good too.
Reply 29184 of 30161, by amadeus777999
I installed a SCSI card in the PackardBell P60 I got today and checked if this would yield some performance gains compared to the IDE controller - it did but it was a "µ-improvement".
In DOS, DOOMII / demo3, the SCSI's fastest time to the IDE's slowest time was 4522 to 4525 realtics - so less than 1/10 of a percent.
Reply 29185 of 30161, by AGP4LIfe?
Continuing with my theme of getting bolder and replacing the Factory TIM on my Slot A CPU's. I decided to really up the level and replace the gunk on my T-Bird 900Mhz.
Its getting easier and easier and I feel more comfortable each time. Its very obvious on the test after completing the new paste, how much better it is than before. The aluminum plate gets hot fast.
I was in for a treat this time as my 900Mhz - TBird has a 1Ghz core!!. Pretty sweet. If I can't get ahold of a Golden fingers device over the next couple months. I am going to move some resistors around on the board and turn it into a 1000Mhz T-Bird permanently. Its already running at 1.75V per the current resistor layout, which is more than enough to run 1Ghz stock.
Fun times! 😊
The attachment PXL_20250207_222322827.jpg is no longer available
The attachment PXL_20250207_222357210.jpg is no longer available
The attachment PXL_20250207_222340273.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 29186 of 30161, by PD2JK
Good for you man, after that you only have to get a dead 1GHz Tbird and swap the black cover. If you ever going to sell it, don't forget to mention it in the ad. :p
I'll never going to open mine, too afraid to damage it.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 29187 of 30161, by PcBytes
Having fun with a GA-6BXDU, 2x Katmais and a 9GB IBM DNES-309170 SCSI drive.
file.php?mode=view&id=211888
file.php?mode=view&id=211889
I have some more stuff on the backlog though - namely testing out a Tualatin SL5ZF, a Chaintech 6BJM0 I just recapped and an Acorp 5ALI61 (since I'm highly curious to find out about how good is the Aladdin V, rev E.)
Reply 29188 of 30161, by PD2JK
I've been busy with this MiniScribe 8425XT drive. Replaced the two stepper motor IC's, but the motor won't do anything. Spindle is spinning, error code 8 and 9 from the LED. That makes sense since the stepper doesn't work. So I'm still thinking what is going on here... When I move the interrupter/shaft by hand its going quite easy.
The attachment DSC_3132.JPG is no longer available
Reply 29190 of 30161, by PD2JK
Tiido wrote on 2025-02-08, 13:57:
Maybe the drivers are not receiving power ?
If I remember correctly, the chips are getting warm a bit. I guess I could check the input or other pins with a scope? See if it's getting signals.
Reply 29191 of 30161, by Tiido
If you have a scope you check check all kinds of things. I assume original motor was seized and that perhaps ended up killing the drivers, or their current limit (fuse somewhere perhaps). It is definitely worth to check the power paths and any drive signals.
Reply 29192 of 30161, by H3nrik V!
AGP4LIfe? wrote on 2025-02-08, 03:17:
Fun times! 😊
I love that the aluminium plate on a tbird still has the dents, that were supposed to make contact with the external cache chips on the older core 😎
Edit: why does the wrong attachment show up in the quote, when I use PXL_20250207_222322827.jpg in the quote?
Reply 29193 of 30161, by StriderTR
Been re-capping some old parts recently, using mostly my YIHUA 948, and it works great. However, I have multiple options.
The other day I came across one of the best de-soldering tools I've ever used, but had completely forgotten about, and didn't know were still made.
Back in the 90's, I used to use one of those nasal bulbs people use on babies noses. I used it to either suck, or blast out, the solder from through-hole components and they worked amazingly well. The silicone ones held up really well to the heat for sucking.
Fast-forward to last week, and I ran across a few being sold on Amazon and those memories came flooding back. Well, I got one, one actually made for soldering work, and it's as amazing as I remember!
Now, back to re-capping! 😀
Builds: https://theclassicgeek.blogspot.com/
3D Prints: https://www.thingiverse.com/classicgeek/collections
Wallpapers: https://www.deviantart.com/theclassicgeek
AI: https://creator.nightcafe.studio/u/StriderTR
Reply 29194 of 30161, by Kahenraz
I've always found solder wick to be extremely underrated for clearing through holes. The problem often isn't the wick and less about technique as it is getting a high quality wick with embedded flux. There are actually a lot of counterfeits of name brand solder wicks too, which makes it very difficult to know what you're buying if it isn't from a reputable seller.
Reply 29195 of 30161, by Nexxen
Tested the V2 I bought and it's working.
Mojo just doesn't see the 2nd TMU, the one I have to reflow as 2 rows of pins are detached.
Win98 does load it and it appears as V2 8MB.
Now I have to build a SLI bridge.
Reply 29196 of 30161, by lti
While I was upgrading my modern system and had the new power supply on the table, I decided to dig out that dead Anigma 586 motherboard I've mentioned in a few other threads and do some troubleshooting. Of course, it works now.
First, I tried to power it on with only a CPU and RAM installed, and I was surprised by POST beeps. Then I smelled something getting hot, which was the FET in the CPU VRM. It's a switching VRM (a 1970s-style design with a discrete transistor oscillator and a shunt regulator as a voltage reference, even though controller ICs existed in 1997), and considering that the board was designed without a heatsink, I think there's something wrong with the gate drive.
I added a video card and a fan for the VRM, and it displayed the fancy Gateway 2000 animated splash screen. I didn't connect any drives to see if it would boot because of the VRM heating problem. I think that's good enough until I decide to build a full system around it. At the same time, I found that CR2032 battery holders have the same lead spacing as the oddball BR2335 holder.
I even reverse-engineered the VRM for all of you to marvel at. The designators in this schematic don't match the PCB at all, D1 is the closest thing in the LTspice database (the actual diode is an MBR1035), I left out some of the output caps, and some of the cap values are a wild guess (I didn't desolder and measure them).
I didn't notice how dusty my monitors were.
Reply 29197 of 30161, by Siran
Found father's old spare floppy for the Tandy TRS-80, still NOS:
Shugart SA400L with delivery note and test documentation:
The attachment 20250206_211032.jpg is no longer available
The attachment 20250206_211115.jpg is no longer available
The attachment 20250206_211259.jpg is no longer available
Also made a wireless mouse 😉 :
The attachment 1000011408.jpg is no longer available
Reply 29198 of 30161, by myne
That is a hate crime.
You should be banned for that abomination.
I built:
Reply 29199 of 30161, by auron
amadeus777999 wrote on 2025-02-06, 21:05:
doom won't really show much unless you test with only 4 MB RAM. while the game doesn't make perfect use of additional RAM to preload everything, the amount of data it loads on the fly will be small. i would test with some game running at just the minimum required RAM, so there will be some swapping and you can judge whether the drops are worse on SCSI than IDE. but this tends to be a bit of a wash because the drives themselves will be different.
alternatively, hdtach 2.60/2.61 or adaptec threadmark. these show best how poorly the RZ1000 performs after all the bug patching done to it.
