You are probably referring to the  EXP4349 motherboard. I have one of those boards and it isn't all that pleasant to work with, perhaps due to the Phoenix BIOS.  I could not get stable 80 MHz operation out of that with a PGA168, even up to 4 V, which, for the most part, limits its usefulness. This board also sometimes contains a PGA132 socket, for which I think I was able to get 80 MHz working stable. However, if using the PGA132 socket, you just as well use any other 386 motherboard.
Assembling a few extra PGA132-to-PGA168 units is still on my list. I had hoped to get to it before starting my summer works projects at home, but it just fell short. You can check back later, or maybe if we get a week of rain and there's enough interest, I could find time sooner.  Are you interested in a unit that runs just at the motherboard's 5 V rail, or with variable voltage (3-4.85V), or a unit with an external VRM run from the 12 V rail, which would allow you to run the CPU at over 5 V if needed, but also permits usage in the 3-5 V range? Do you prefer the Alpha1 or Alpha2 PCB?  Would you provide your own SXL2 CPU, or do you need one included?  What is your target operational speed, e.g. 66 Mhz, 75 Mhz, 80, MHz, or 85 Mhz?
Anything I send would be on a donation basis, with proceeds going to charity, that is, no funds would funnel through me. You can claim the charity write-off on your taxes. I have a charity preference, but its not rigid.
