& yes,that is my concern,if the 512B sector emulation will be discontinued by all manufacturers except Enterprise drives,get any 32bit Windows alive on real HW will become the most expensive hobby & if it will be discontinued also for Enterprise drives,that will be to final end of 32bit era.
Interesting paradox is,if SD cards or flash drives(USB) will remain 512n/e,then 32bit era will be killed even sooner than 16bit era,as 16bit OS setups as DOS 6.22+Win.3.x can happily survive on SD card or USB flash drive,a Win32 will destroy such a drive very soon by consuming all E/P cycles very quickly,so we need HDDs for Win32 & if 512B emulation will be dropped for internal hard drives,we will still be able to have DOS+Win16 on SD card,but no way for installing a Win32.Those,who loves VMs,can sleep well,but for those loving running Legacy OSs natively the end of 512B sectors emulation is a nightmare,on the other hand,maybe we will run out of all Legacy & CSM supported MoBos sooner than we will run out of last 512e drives after they will be discontinued & true is,discontinuing of CSM support on new MoBos is greater concern,as without 512e/n HDDs we will lose the possibility to run natively 32bit OSs,while we will still be able to run 16bit OSs from SD cards,but with no MoBos with CSM we will lose both,but still Win16 & DOS may survive longer than Win32,because most of MoBos capable of running Win32 r RoHS & BGA & will fall apart much sooner,than old good MoBos with Pb,so when all P3/P4/C2D MoBos will be dead,P1 & older MoBos may still be functional,so even with all 512e/n hard drives dead @ a time,U will still be able to run DOS+Win16 via XT-IDE/IDE-CF/SD,so when all Win32 will be imprisoned in virtual machines,DOS+Win16 will still run natively.
For example I have a stuff o P4 MoBos as spare parts,also I have a huge stuff of spare HDDs(mostly IDE) & quite fewer older MoBos & for all the time,I am collecting old HW(25 years),2 of my HDDs died(2 oldest IDE),compared to MoBos quite good,because for the same time 8 P4 & newer MoBos died,2 P3 MoBos died,1 P2 MoBo died,1 P1 MoBo died,& none of my 486/386/286,nor XT died.
Moreover some guy from New Zealand is manufacturing NEW XT MoBos,the same guy,who invented the XT-IDE,so everything,which can run on XT is saved from ending up in oblivion,thus the result is,Win32 platform is now more endangered than DOS...
Thus when U pointed to the same danger,as I feel-the EoL of 512B sectors emulation, probably we shall stuff as much 512e/n drives as possible & those more ritch should staff even more drives,then they need & when manufacturers discontinues 512B sectors emulation,those,who saved more drives,than they need,may sell it to others,who r restoring Legacy systems.
& y I 1st confirmed these laptoP drives?
Because some goes into laptops & some into compact desktops,yes,to a regular desktop I put 3.5" HDD,but I also collect laptops & compact desktops.To some compact desktops 3.5" drive do not fit at all,in other cases there r no space left around the 3.5" drive for air flow,causing insufficient cooling,which is a great HDD-killer,or the construction of the case is totally absurd,like the HDD caddy touching the PSU or even the CPU cooler,so if I used that original stupid construction,HDD would be fried,thus I mount the disk elsewhere in the case,where the thermal conditions r better for the longer survival of the HDD as priority,which U confirmed by confirming manufacturers' plans to move to 4Kn only,so I will not fry a 3.5" 512e HDD in compact desktop in a caddy directly touching the CPU cooler with 2x3GHz C2D touching that cooler from other side,when I have an option to mount the 2.5" 512e HDD elsewhere,with good passive cooling to the case far from processor+good airflow,to which it is on its beginning,so the air sucked from outside not heated by any other component,cold metal on 1 side,cold air passing by other 2 sides-this is the reason,y I put WD20SPZX into a desktop,because it is a tiny compact desktop with critical flaws in case construction,which I compensated for maximizing the longevity of the system-it is meant to the living room,to be connected to TV,because it has nice front panel design to reside near the TV & it will be filled with my favorite sci-fi movies & series,most of them also retro,the oldest I have from 1950 & 1963(yes,I have even something older than Star Trek TOS-The Cage...with Leonard Nimoy & William Shatner 6 years be4 they became Spock & Kirk...U may guess,what it is...),I plan to entertain my visitors by the best sci-fi...in addition to DOS games,including a TrekFest Free for best friends & this piece of Legacy HW loox best for this particular purpose,sadly the good design is counterweight by stupid internal case design,thus I must mod the layout of essential parts.The hard drive is selected regarding the conditions of the surrounding HW & case layout.
When I will buy a 3.5" HDD for a standard desktop or rather tower,I will notify about the disk model & compatibility,but for now all the standard desktops & towers,I was (re)building/restoring,was much older machines,to which I put IDE drives,which r all 512n.& from newer machines I yet constructed rather obscure form factors,but I will build a backup server & that will have new 3.5" HDDs & Windows Server 2008 Enterprise 32bit,the machine is from this era & designed for this OS & this OS will be the best for it,as it will have 8GB RAM & this is the only 32bit OS able to handle 8GB RAM in my collection & has also high historical value,as it is the last 32bit Windows Server OS,I saved that server from scrapping,but with most HW missing,most complicated was to replace the CPU cooler,as it is a BTX & sadly I did not had replacement Xeon,so it has non-original processor now,it will be used for intranet backup of other PCs & here I will try a new 3.5" HDD,because here it will have sense.
& about SMR:
Is it only weaker in performance,or is it also unreliable?
Because performance is irrelevant,the host is SATA 2,so the drive will work @ half of the transfer speed or less & I archive movies & series in SD or LD,mostly DivX,not in HD/FullHD/4K,so I do not need turbo read speeds for playing 350MB DivX episodes or 700MB DivX movies,pretty much of my archive r so old,they was even filmed in SD.Do U remember the analog TV resolution...this will be the load for this drive...
...All old Good Things...
