bestemor wrote on 2025-02-25, 20:09:Well, not 'bought' yet, but.... does anyone perhaps know how and where this contraption is meant to be installed ?? […]
The attachment Bridge Bracket Fan Frame.jpg is no longer available
Tried asking the sellers, but just getting the 'chinese' answer of look in the listing/picture nr 2, which does not help at all(!) .
(if your pictures made any sense, I would not need to ask, duh ... sigh...)
https://www.ebay.com/itm/126846094616
The thing to take note of is the size of the fans in relation to the screw holes. This is not for case intake or exhaust fans, this is for tiny 40mm fans for some weird cobbled memory cooling solution:
https://www.amazon.co.uk/Bracket-Cooling-Supp … B0DMP839WT?th=1
It has the exact picture and the same hardware shown and the listing is titled:
"4cm Bridge Bracket PC Memory Cooling Fan Support Bracket PC Case Fan Holder For Computer Mainboard CPU Cooling Rack "
In short: You don't need this. If you need this, you've probably bought the wrong memory and should have just got something that didn't need to be overclocked to the point of needing three tiny irritating fans.
If you aren't intending to OC your memory and the case has any airflow at all, save your money and don't buy that. 😀
EDIT: Also, to answer your question about how it is installed, I would say that it is the usual case of "show pictures of things that make people think this is useful, but in reality it isn't for 99% of people". There is probably somewhere to mount a bracket like that in very specific PC cases... or ... maybe there isn't. It could be useless without drilling holes in your motherboard tray to attach the bracket (so that the fans blow into the RAM from the front of the case).
It's so silly though, considering most modern cases have front-to-back or side-to-back airflow already, which will send lots of air toward the RAM already... and... ugh... it makes my head hurt. What good would it be to blast tiny fans at the side of one RAM stick? Actual RAM coolers tend to shoot down at or through the slots to cool ALL of the RAM, like this:
https://www.printables.com/model/696948-ddr4-fan-mount-340mm
https://www.overclock.net/attachments/scetch-2-jpg.2543215/
EDIT2: Think of that bracket kind of like this:
https://www.amazon.com/Znoogrn-Adapter-Monito … r/dp/B0CF8GY8SD
Why does this exist? Why are they still selling it if there is a big warning that pops up saying that it's a "frequently returned item"?
Whatever the reason, it's the same reason that fan bracket exists and why there aren't any pictures of them installed, and why the sellers can't help you. They have no idea what they are selling or if any of it has any real use for anyone.
