What Is Your Favorite Operating System(opinion poll):
Reply 60 of 77, by Sabina_16bit.
leileilol wrote on 2025-03-01, 01:37:
I'm serious with the ME response BTW. I'm not part of the 'me suck's bsod all time install Xp luna is the best' brigade. It's so good it doesn't even need a "service pack" made for it. Like what are you going to do, put Me dlls into Me? The problems it has are mutual with the whole 9x lineup. The 'new annoyances' are also found in beloved Windows 2000 and XP.
I was over pure dos gaming by the time I mained Win95 in ~96 anyway, so the boot-to-dos loss is nothing.
Do not feel alone advocating for ME.
I also plan to install it,when I select an era correct PC for it.
Reply 61 of 77, by oldhighgerman
I love the compactness and simplicity of NT 4.0. Perhaps a not so attractive OS if you're a hc gamer. But it comes stock with PINBALL. Can't remember if XP included it or not. Vista definitely didn't. As I recall anyway.
Reply 62 of 77, by Sabina_16bit.
oldhighgerman wrote on 2025-03-01, 03:47:
I got an original installation CD of Windows NT 4.0,thus also when I select an appropriate computer for it,I will install it,simply because I collect Legacy OSs.
The games & some small apps included in Windows can be copied(yes,just copied) to newer versions of Windows & will run.
Not vice versa,Windows will refuse to execute a file with a higher version number than its own,if the program is using same version numbering as Windows itself,but if the version number of the program is lower,than that of Windows,it will work.
I tested that with these(working on all Windows versions equal & higher,than the program version number):
•Minesweeper.
•Character Map.
•MS Paint(brush).
•MS Write.
•MS Wordpad.
•Notepad.
These worx in any directory of its own & newer Windows & does not conflict with the native version.
I use to associate the extensions PCX,RLE & WRI abandoned in later versions(or redirected in case of WRI) to the Paintbrush & Write from Windows 3.x ,which I copy to newer versions or in case of multiboot I just point to the files on Windows 3.x partition.
Of course 16bit versions do not work on 64bit Windows,but U can for example use XP or Vista versions on Windows 7,of course U can use 9.x or 4.0 versions on all newer Windows.
I guess,U may by successful with copying Pinball to newer Windows too.
Reply 63 of 77, by Sabina_16bit.
Admin is about to delete all my topics,I will probably even have no time for back it up,count votes & so,if some1 will be able to count votes,be4 the topic will disappear, please let me know via e-mail.
Reply 64 of 77, by oldhighgerman
Sabina_16bit. wrote on 2025-03-01, 13:05:
I got an original installation CD of Windows NT 4.0,thus also when I select an appropriate computer for it,I will install it,sim […]
•Minesweeper.
•Character Map.
•MS Paint(brush).
•MS Write.
•MS Wordpad.
•Notepad.
Yes Pinball was a particularly nifty little addon. And yes works wif later versions of Winderz. Every OS should come with 2 or 3 crazy games. Not Solitaire, God how many brain cells were put to death. W/o so much as a trial. Chess should be a standard. I became hooked to online chess and had to quit cold turkey.
Reply 65 of 77, by Sabina_16bit.
Yes,chess should be a standard,it would stimulate persons' thinking,very useful game.
But it should be online chess for 2 players,because playing Chess with comp is not very fair play for an ordinary human.
Reply 66 of 77, by Qbix
Rank DOSBox Author
DOSBox Author
I deleted your signature as it was claiming something along the lines that we are hating you or something like that. Which is something unfounded.
Your posts are hard to read as there is a lack of paragraphs and it jumps from one topic to the next.
Please consider using the preview button so you can see what your post look like and how to make them more easy readable.
I am surprised and puzzled that you seem to know what I will do to your account (banning ? Deleting your posts) , as I haven't even given it any thought yet.
Water flows down the stream
Reply 67 of 77, by Sabina_16bit.
Qbix wrote on 2025-03-02, 20:34:
I deleted your signature as it was claiming something along the lines that we are hating you or something like that. Which is s […]
Greetings.
An another admin is about to delete me-the DOSFreak is after me,he never expressed,what particular reason he has against me,he & 1 ordinary user was offending me & accussing me also unfounded of trolling,exploiting data for third parties & scattering the forum,I did not yet meet another admin,thus I thought, he is the local god(boss,forum owner...) here,as he behaved so.
He is that admin,who most probably is about to delete me,I am still convinced,he will do so,I also thought, he deleted my signature.
He never explained, what I do wrong by his measures,he just blowed accussions to me,suggested,I am creating bad treads or so.
His expressions r harder to understand than my,also to some others.
Many of my topics,he suggested being inappropriate, looks to be liked by other users,which shows the opposite.
Look to the "Miss Laptop..." tread,if it still exists to know more.
His behavior looked like he is hating me & that he is determined to get rid of me,then I had to guess the reason,also based on my experiences from WinWorldPC.
So by 2 aggressors I mean him & 1 user,who very despectfully atacked me in my tread about SMR HDDs.
I was sure,DOSFreak also deleted my signature, because it was about him & it was a part of my evasive maneuver attempting to move my topics to e-mail discussion due to awaited deletion by Mr.DOSFreak.
It is logical to assume,that if someone dislike me & he can delete me,y he would not do so...
Thus I prepared to withdraw & move to my own means,where r no admins.
It is clear,an ordinary user cannot win a conflict with an admin,as a game-creature cannot bite me,when I have God Mode activated,thus it could only be solved by evasive maneuver & withdrawing from an area under his control.
Apologize for misunderstanding.
Reply 68 of 77, by chinny22
XP did, was the move to X64 OS's that killed Pinball. There is an interesting video here on the history
https://youtu.be/UTPTPJEVYlY?si=FatyZ7YDqtkUnHpx
and another video on how to get it working in modern OS's again
https://youtu.be/ThxdvEajK8g?si=pzn3kGs1jp8x8We1
Reply 69 of 77, by UCyborg
XP's Pinball doesn't suck 100% CPU all the time. 😀
I apply NoGDIHWAcceleration compatibility shim on modern NT versions because otherwise, ball just sorta fades at high speeds. There's something funky about desktop compositing + GDI on Windows 7+, you can see it in eg. file view in 7-Zip, Registry Editor etc. if you make a selection rectangle and move the mouse to change it, you can notice some sort of flickering.
Despite some flaws, I stopped worrying about them by the time Windows 10 was out for a couple of years. I guess it's Win10 for me when it comes to computers. Mobile...well, the only thing I really ever used was Android. Briefly tried Firefox OS, but it wasn't practical.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 70 of 77, by dionis32
I like Windows XP (32 bit) and Windows 7 (64 bit).
My interest does not extend that far back to the days of DOS/Win 9x. I have tried DOS and Windows 9x on various virtual machines but never felt a connection with them. I even tried FreeDOS on real hardware but had the same reaction, lack of enthusiasm, so I eventually deleted it.
I also use Windows 10 and Linux for modern programs and games.
Reply 71 of 77, by UCyborg
I guess 10 for me because it's well supported and just works...most of the time. And I was always more into stuff I can run on the OS rather than the OS itself.
Reply 72 of 77, by Errius
Harry Potter wrote on 2025-02-27, 12:58:
I personally also prefer Win7 over Win11: I find it to have a better and more functional GUI
Yep. Windows UI has gone to shit ever since Microsoft started selling tablets.
If I was a paranoid conspiracy theorist I would suspect MS are deliberately trying to make the desktop experience as frustrating as possible in order to drive sales of their Surfaces.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 73 of 77, by lepidotós
Honestly, I'm not sure, but it's probably Haiku. For vintage purposes, I guess Mac OS 9 and Windows NT 3.51, with 95 as a close second.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
Reply 75 of 77, by mombarak
my favorites are:
- Windows 98 SE
- MS-DOS 6.22 with or without Windows 3.1 (Workgroups fails to install on my P90)
What I find personally sad is that Windows 7 becomes more and more useless. While you can still use Windows XP very good as many of you mentioned. It plays 9x% of the old games and is stable if your hardware is. Lots of stuff still works great and people started filling gaps for software like browers with Supermium and so on. But Windows 7, for me the last good OS from MS, is losing more and more use cases because browers are not working anymore, software would not start due to missing libraries and dlls and so on. I have installed it on a computer and ran into so much trouble with software which would not work and updates not working correctly where Windows XP just keeps getting better and better. Maybe its because XP is the end of the 32bit and has the maximum of support for all the fun stuff and Win 7 is the first of the 64bit era...
And I do know that both had 64bit/32bit versions but I doubt a lot of people used them.
Reply 76 of 77, by Intel486dx33
Minimum system requirements….
It depends on your hardware and software compatibility.
Reply 77 of 77, by ElectroSoldier
Windows Powered. [Win2k]
