Reply 29340 of 30568, by CMB75
- Member
oldhighgerman wrote on 2025-03-04, 07:40:O NO. They do not work perfectly. In fact it may be that if you actually accessed them once, it could have been the FINAL TIME. This isn't said often enough. Upon finding an old disk, do NOTHING with it prior to reading it into an image/file. You may live to regret it otherwise. Do not try to determine its contents (if it's unlabeled, mislabeled). Don't do a directory scan. Just hit it with whatever people are using these days. I used to use ImageDisk by Dave Dunfield.
I took have had lots of success with old floppies. But often times I've found they're only good for 1 access. Then it's bye-bye. For the rest of eternity.
You're probably right, either way, in this case it wouldn't really be a loss because they are all labeled properly and I do have images of all those disks. I'm going to give those drives a proper cleaning tonight to minimize the risk. If I do stumble upon a data disk I'll image it first *if it does indeed work.
