First post, by User5518
Hello,
I have an ESCOM Paradigma with a 486 DX2 66MHz, 4MB RAM, and a 340MB HDD (Toshiba MK2326FCH) running PhoenixBIOS(TM) A486 Version 1.03.11:
The attachment 1_boot.jpeg is no longer available
Apart from the fact that the power plug is defective and I have to power the device via the battery pins using a 16V IBM power supply, it actually works quite well.
However, it has one issue that I'm not sure how to fix:
Every time I start up the device, I am greeted with this message:
TOSHIBA MK2326FCH
Fixed disk 1 failure
Invalid configuration information - please run SETUP program
Press the F1 key to continue, F2 to run the setup utility
This is extremely annoying because I can't just turn on the notebook and use it. 🙁
I'm wondering what causes this, as the internal HDD is recognized without any problems, and if I proceed with "F1," I can boot from it.
However, if I "misconfigure" the HDD in the BIOS so that it is no longer recognized at boot, I then get this message:
Fixed disk 0 failure
From this, I conclude that "disk 0" is the internal HDD because "disk 0" does not appear in the error message when the "TOSHIBA MK2326FCH" is correctly detected.
But what is "disk 1"? The PCMCIA Slot? The floppy drive?
I have an identical black version of the same notebook here (which does not boot), so I have been able to swap and test various components, including the floppy drive, but this has not helped – the error "Fixed disk 1 failure" keeps appearing.
I have tested and replaced the following parts:
Floppy drive
Hard drive
BIOS chip
In all cases, I always got the same result: "Fixed disk 1 failure."
These are the "details" for this issue:
The attachment 2_message.jpeg is no longer available
Here are the laptop's BIOS options:
The attachment 3_bios_1.jpeg is no longer available
The attachment 4_bios_2.jpeg is no longer available
Of course, I have already tried many different settings, but without success.
Has anyone encountered this issue before? Or if anyone has an idea... I'd appreciate any help.
Edit: This is the solution: Re: "Fixed disk 1 failure" on ESCOM Paradigma 486 Despite Working HDD, thanks to mkarcher !
Reply 1 of 16, by st31276a
I only have an idea 😀
A fixed disk is an IDE hard disk in this case, not a floppy drive.
You are right in that fixed disk 0 is the working hard disk.
Somehow it has a primary slave configured too, which it does not seem to find.
Perhaps clearing cmos confoguration data or reloading bios defaults might clear that.
Reply 2 of 16, by 8bitbubsy
Sounds to me like you need to replace the CMOS battery inside the machine (assuming there is one).
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates, 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0
- ISA PS/2 mouse card + ISA USB-stick card
- MR BIOS v1.65
Reply 3 of 16, by DaveDDS
8bitbubsy wrote on 2025-03-12, 11:38:
Most BIOS will issue an error if the CMOS is corrupted (checksum fails usually = bad battery)...
But I don't see anything like that. (still worth trying if reset doesn't work)
I agree that it seems to think there is a slave HD. Normally you would see this in the system
configuration ... but that fact that it shows "INT HD" suggests to me that this BIOS has been
adjusted specifically for a laptop, and might be doing the user a favor by not showing information
about a slave if there "would never be one" or "the slave caddy is not detected"
Restoring BIOS defaults would be the first thing I'd try!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 4 of 16, by 8bitbubsy
Hm yeah, maybe it isn't related to the CMOS battery after all. It probably needs replacing anyway!
I also agree that resetting the CMOS/BIOS settings is worth trying. If you can't do it from the BIOS setup screen itself, you could maybe try different CMOS resetting tools for DOS.
386:
- MR BIOS v1.65
Reply 5 of 16, by User5518
This is interesting. I'll need to take a closer look at it this evening. I'm currently using a CR2023 battery with a Schottky diode as the CMOS battery, but I suspect the original was actually a 3.7V battery. I'll use my lab bench power supply as a stand-in for the CMOS battery so I can simulate a 3.7V battery, and I'll report back this evening.
Resetting the BIOS to its default settings didn't help—I tried it several times. As I mentioned, I also tried a second BIOS chip.
Another thing I noticed is that in 'fdisk,' there's an option under menu item 5 to switch to a second hard drive (if one were present). However, when I try to switch, it says that the drive wasn't found. I've never seen that before, and I'll post a picture of it later.
The notebook has several DIP switches located behind a service panel. Maybe one of them is set incorrectly, causing the notebook to think there's a second hard drive. That might explain why I'm seeing the same behavior even after resetting the BIOS settings and replacing the entire BIOS chip.
Here you can see the switches (some are behind another cover):
The attachment IMG_5295.jpeg is no longer available
(Of course, I don’t have any documentation for these switches… 😒)
Reply 6 of 16, by st31276a
Ah, the pleasure of mystery switches!
If various combinations of them dont make a difference, and resetting bios in various different ways dont make a difference, mayyybe a bit in the cmos ram could be bad? Quite a long shot, not as if it is escd flash that we have some cases on here that went bad.
Reply 7 of 16, by User5518
My Test Results:
The DIP switches did not change anything except for the FSB and the inversion of the pixels:
The attachment IMG_5299.jpeg is no longer available
A fully charged CMOS battery was not the solution either. I also had a new 3.6V Ni-MH battery (with a modest 700mAh), but even this CMOS battery made no difference.
The attachment IMG_5305.jpeg is no longer available
Still the same issue:
The attachment IMG_5306.jpeg is no longer available
It is highly unlikely that a bit in the CMOS chip has flipped, as I get the exact same error when using the chip from the other notebook.
(In the meantime, I switched to a Seagate ST9655AG with a 524 MB HDD, but of course, that made no difference either.)
Reply 8 of 16, by DaveDDS
User5518 wrote on 2025-03-12, 20:06:
...It is highly unlikely that a bit in the CMOS chip has flipped, as I get the exact same error when using the chip from the other notebook.
I agree, unlikely - and a bad bit would be caught by the CMOS checksum.
But to confirm:
Change some odd-but-identifiable setting in BIOS. (depends on your
BIOS) something that won't kill BIOS entry, but also isn't normally set.
Power off/on - verify that your "odd" setting is still there.
(to confirm that you didn't pick something BIOS would reset)
With the CMOS battery in place, verify there is voltage on the CMOS ram chip.
(while the system is powered off - this is mainly to confirm that you know the
right pins to test)
Then remove the battery - confirm that the CMOS is NOT getting power
(due to capacitance in the circuit it may take a few seconds to drop - You can
help it with a 10k or so resistor: VCC->Gnd. Leave the CMOS
unpowered for 10 mins - this should be long enough for it's internal
capacitance to discharge - reconnect battery and power up.
See if you get a "configuration bad" error message of some sort from BIOS.
If so, your CMOS is good.
If not, go into BIOS and see if you "odd" setting is still set.
- if it is, then maybe you have the wrong CMOS RAM chip, or there
is some other power source for it. (Repeat above but let sit unpowered for
a couple days)
- If it is not, looks like your BIOS detects the checksum fail and
resets to defaut without telling you!
Reply 9 of 16, by mkarcher
The CMOS configuration of the primary two hard drives is quite universal, as many vendors just copied the IBM layout of CMOS memory. Try some generic AT setup utility like GSETUP and check whether it reports a configured slave drive. If yes, try setting the slave drive type to "not installed" with that tool and hope that the mainboard BIOS picks up the change without resetting the whole BIOS settings.
Reply 10 of 16, by User5518
The BIOS is behaving as expected:
I set the HDD to "manual" and entered "0" for each field. Additionally, I assigned a drive to the external FDD port, even though no such drive exists:
The attachment IMG_5322.jpeg is no longer available
Both settings were displayed as expected after a short power-off:
The attachment IMG_5323.jpeg is no longer available
Reply 11 of 16, by User5518
Here is the FDISK view with the 5th option that I mentioned earlier:
The attachment IMG_5312.jpeg is no longer available
The attachment IMG_5313.jpeg is no longer available
The attachment IMG_5314.jpeg is no longer available
The attachment IMG_5315.jpeg is no longer available
When I try to create a partition on this "second" harddrive, FDISK freezes.
@mkarcher I will try this and will report back, thank you.
Reply 12 of 16, by Deunan
Was this HDD working properly in this machine before, or did you add it yourself? In the latter case did you set the master/slave jumpers properly? Some older IDE drives have a separate master and master with slave settings, and wrong setting can lead to bad PDIAG behaviour, which in turn can sometimes fool the BIOS/HDC that there is a second drive connected. So make sure you got the jumpers right.
Reply 13 of 16, by User5518
@mkarcher THANK YOU!!!
gsetup solved my issue, it is working!
The attachment IMG_5325.jpeg is no longer available
I was able to disable the second HDD using this handy tool:
The attachment IMG_5326.jpeg is no longer available
My BIOS accepted the change, so I no longer receive that annoying message. Additionally, FDISK no longer detects the "second" HDD. 😀
Now, I just need to 3D-print a small cover for this, and then the notebook will be complete!
The attachment IMG_5327.jpeg is no longer available
Reply 14 of 16, by User5518
Deunan wrote on 2025-03-12, 21:45:
I bought the notebook second-hand a few years ago, and it had been sitting unused in the closet for quite some time. I'm not sure if this issue has always existed. I only know that the problem did not occur with the black notebook when it was still working. Additionally, the HDD from the black notebook shows the same error.
I don't really have a way to set a jumper. But as I mentioned before, with GSETUP, I was able to disable the "second" hard drive, which the system had mistakenly detected. As long as my BIOS battery has power, the GSETUP setting will remain in place, so I won’t see this message—at least until the BIOS battery eventually runs out. With 700mAh, I hope that will take a while, even if I don’t use the notebook for an extended period.
Reply 15 of 16, by st31276a
I wonder how it got there. Garbage and corruption from being powered down for long? Does this bios even checksum the cmos memory? Or only some part of it? I doubt it ever had a 6 gigabyte hard drive installed.
Loading bios defaults probably only loads and overwrites chipset settings, it looks as if it does not touch the configured drives.
It seems as if this bios setup program has no way of setting those fields, but being a modified bios of something prior, it actually still has all the slave drive stuff still built in, just hidden from sight.
Reply 16 of 16, by DaveDDS
st31276a wrote on 2025-03-14, 06:40:
I wonder how it got there. Garbage and corruption from being powered down for long? Does this bios even checksum the cmos memory? ...
Most do .. The method I outlined a few posts back (remove battery - insure chip voltage go to 0)
would confirm that it does ... but since it's been solved now - I don't suggest messing with it!
