First post, by bloodem
- Oldbie
I've recently got my hands on this beautiful Batman's Revenge motherboard (see attached pic), and I'm itching to use it for a Win95 neo-retro/reverse-sleeper PC build.
Unfortunately, I ran into a roadblock that I did not anticipate: as far as I can see, the board doesn't seem to have a PS/2 mouse header, but it does have unpopulated PS/2 keyboard & mouse connector pads under the 5 pin DIN keyboard connector (apparently some OEM boards actually came with the PS/2 connectors instead of the 5-pin female DIN).
Now, of course, it would be very easy for me to just remove the DIN connector and solder the missing PS/2 connectors, but I really, really want to keep it as original as possible (well, almost, I obviously had to add a socket for the Dallas chip, no way around that).
So, has anyone found a good solution to add a separate PS/2 mouse header on these boards? I don't want to use a serial mouse... 🙁
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
