First post, by bloodem
I've recently got my hands on this beautiful Batman's Revenge motherboard (see attached pic), and I'm itching to use it for a Win95 neo-retro/reverse-sleeper PC build.
Unfortunately, I ran into a roadblock that I did not anticipate: as far as I can see, the board doesn't seem to have a PS/2 mouse header, but it does have unpopulated PS/2 keyboard & mouse connector pads under the 5 pin DIN keyboard connector (apparently some OEM boards actually came with the PS/2 connectors instead of the 5-pin female DIN).
Now, of course, it would be very easy for me to just remove the DIN connector and solder the missing PS/2 connectors, but I really, really want to keep it as original as possible (well, almost, I obviously had to add a socket for the Dallas chip, no way around that).
So, has anyone found a good solution to add a separate PS/2 mouse header on these boards? I don't want to use a serial mouse... 🙁
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 1 of 17, by keropi
the only solution I can think of is getting a ps/2 mouse bracket and solder it's wires directly on the underside... perhaps if there is space solder some angled pins on the mobo and plug the bracket connector there
this way all mods are on the backside and not visible
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 2 of 17, by bloodem
keropi wrote on 2025-03-19, 09:16:
This also crossed my mind, but I can't think of any way to make it look acceptable. Even if it's the backside, my OCD would kill me. 😀
Reply 3 of 17, by keropi
well since the mouseport is under the AT keyboard connector there is really no other option
also it seems there are some missing passives behind the keyboard connector, at least 3x ferrite beads - perhaps they are related to mouseport and perhaps there are some more passives missing so it's another thing to investigate
Reply 4 of 17, by bloodem
keropi wrote on 2025-03-19, 10:38:
Yeah, I was affraid of that... Damn it, in that case I would much prefer to simply remove the DIN-5 keyboard connector and add the two PS/2 connectors.
Regarding those passives, good catch, will check if there are more besides those FBs! Thank you!
Reply 6 of 17, by PC@LIVE
bloodem wrote on 2025-03-19, 07:55:
I've recently got my hands on this beautiful Batman's Revenge motherboard (see attached pic), and I'm itching to use it for a Wi […]
Ciao
I have a similar motherboard, it should be a hendix or mercury, I don't remember exactly which one it is, but I can start it and see if it's prepared for the PS/2 port.
Recently Tony359, worked on an MB equal to yours, here if it is possible you could save a copy of the BIOS, and put the file here, you could give him a hand to solve it, there is a suspicion that the BIOS he tried, are defective, while yours would remove the doubt, if it does not work then there is a hardware problem, somewhere.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 7 of 17, by bloodem
auron wrote on 2025-03-19, 19:16:
already made a topic about this: Intel Batman's Revenge/Plato AT to dual PS/2 port conversion (SMD component list required)
the alternative is to use one of these ps/2 isa adapters that people have been making in the last few years.
Thank you. Yes, I saw the topic, but the linked "mod guide" refers to the socket 5 Intel Plato, which is not really comparable. As far as I could see, those ferrite beads are the only missing components on mine.
I've ordered 10 x PS/2 connectors from China, because I only have combined keyboard + mouse PS/2 connectors in my stash. Will keep this thread updated with my progress.
PC@LIVE wrote on 2025-03-19, 19:35:
Ciao
Ciao! I know, I am a big fan of his channel! 😁
All BIOS files are available on TheRetroWeb.
The problem is that this board has a soldered BIOS chip, so if recovery mode via the boot block does not work, then the only solution is to desolder the chip and try to flash it with an external programmer.
Reply 8 of 17, by PC@LIVE
bloodem wrote on 2025-03-20, 19:12:
Thank you. Yes, I saw the topic, but the linked "mod guide" refers to the socket 5 Intel Plato, which is not really comparable. […]
Thank you. Yes, I saw the topic, but the linked "mod guide" refers to the socket 5 Intel Plato, which is not really comparable. As far as I could see so far, those ferrite beads are the only missing components on mine.
Ciao
Yes Thank you ☺️ a thousand
I follow Tony359's channel, which I found by chance, on one occasion I contributed to the resolution of an ASUS P2L97, it can be found here:
https://m.youtube.com/watch?v=bXaMuqUzV8g&t=2552s
As for its Batman motherboard, the BIOS chip was originally soldered, but it was later removed, and a socket was soldered, because there was probably the doubt that it did not work, and to be able to program it easily, since the card does not work.
The problem from what I understand, is that on the "RetroWeb" there are files for floppy recovery, and there is a somewhat complicated procedure, so the idea was to duplicate the BIOS of an identical working motherboard, and then reprogram the BIOS chip, in this way it would be safe, that if it doesn't work it's not the BIOS' fault. If I had time to make a copy of the BIOS, it could be useful as a backup copy, lately working on various non-working motherboards, I found a BIOS chip not working, luckily 😰 it is a card that has some BIOS available, otherwise 😥 I should have tried BIOS of similar motherboards.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 9 of 17, by bloodem
PC@LIVE wrote on 2025-03-20, 19:39:
Well, I just spent an hour trying to save the BIOS but was unable to. 🙁
Uniflash crashes and causes a system reboot, while all other AMIFLASH utilities that I tried output the same message: "System BIOS does not have Flash support".
The only thing that "works" is the Intel Flash Memory Update Utility (fmup.exe), which is found in the BIOS update archives, however this utility creates the same type of files as those you see on TheRetroWeb (.BIO & .BI1).
So... I think the only possibility is for him to try the recovery procedure, as mentioned in the manual. If that doesn't work, there is probably another hardware related problem that he needs to deal with first...
Reply 10 of 17, by PC@LIVE
bloodem wrote on 2025-03-22, 09:20:
Well, I just spent an hour trying to save the BIOS but was unable to. :-( Uniflash crashes and causes a system reboot, while all […]
Thanks a lot
I thought it was like in other PCs, all in all quite simple, but maybe in PCs quite dated like these, it is not possible to make a copy of the BIOS, at least as you would usually do.
So I think, if on "TheRetroWeb" there are no .bin files or similar, it's because they can't be extracted (?), the thing I don't understand 😐, because you need two files, in this case . BI0 and BI1, so I would say, as you suggested, if you can't do the Floppy Recovery, it's because there must still be a hardware problem.
Thank you for your cooperation, and if there is any news, I will let you know.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 11 of 17, by bloodem
PC@LIVE wrote on 2025-03-22, 14:02:
Thanks a lot I thought it was like in other PCs, all in all quite simple, but maybe in PCs quite dated like these, it is not pos […]
Thanks a lot
You're welcome. 😀
It's not due to it being an old (dated) motherboard. It's because we're dealing with an Intel motherboard, which tends to have all sorts of proprietary bullcrap, similar to many system integrators. 😀
But they are sturdy and good looking boards, I'll give them that, with high quality components & Japanese capacitors.
Reply 12 of 17, by bloodem
Well, I've received the PS/2 connectors and can confirm that, besides the actual connectors, the Batman's Revenge board only requires those 3 x ferrite beads, which are needed for the PS/2 mouse voltage, clock and data lines (personally, I went with 3 x Murata 30 Ohms impedance @ 100 MHz, because that's what I had available and it works flawlessly). Btw, the physical size of the FBs is 1210.
Not that happy about doing this mod, I would have preferred a mouse header, but thanks to Intel, I had no choice. 😀
Some pics:
Reply 14 of 17, by bloodem
keropi wrote on 2025-04-09, 12:53:
nicely done!
but these ports don't create an issue where AT cases won't be compatible? you will use some ATX one with custom backplate?
Yes, modern ATX with a blank backplate - RGB and all! 😀 I have big plans! 😁
Reply 16 of 17, by maxtherabbit
bloodem wrote on 2025-04-09, 11:56:
Well, I've received the PS/2 connectors and can confirm that, besides the actual connectors, the Batman's Revenge board only req […]
Some pics:
Well I think it looks nice, and you can find some AT cases which will accommodate this port layout. I have one myself
Reply 17 of 17, by bloodem
maxtherabbit wrote on 2025-04-09, 15:54:
Thank you!
I have quite a few period correct AT cases in my collection, but none with this dual PS/2 port layout.
Either way, not a problem, I want to do something very different/extreme with this one: a Reverse Sleeper in a very modern case, especially since it will probably be the last full retro PC I build (at least that's what I promised my wife 😁 ).
