Reply 29440 of 29592, by Law212
Trying to get a 486 and a pentium 1 working that were given to me. Also worked on my daily use 486. The A and B and D drives were not working . WEll I Finally got them working again and played some indianna jones and the fate of atlantis.
THough i was looking at the mobo and noticed it has some what looks like cache memory slots available and I want to fill them but I dont know what kind id need.
Reply 29441 of 29592, by kingcake
Law212 wrote on 2025-03-23, 15:04:
If only there was a place where you could find old motherboard info, some sort of retro web.
Reply 29442 of 29592, by Law212
kingcake wrote on 2025-03-24, 02:24:
Theres always one in every forum
Reply 29443 of 29592, by kingcake
Law212 wrote on 2025-03-24, 22:05:
A guy who's not too lazy to lookup his own info?
Reply 29444 of 29592, by Law212
kingcake wrote on 2025-03-24, 22:58:
You dont think I looked? What else is a forum for if not to ask people who know more than you?
Reply 29445 of 29592, by darry
This might help you ID the motherboard and the cache type it needs :
https://theretroweb.com/motherboards/
Here is some background info on how it came to be :
The Retro Web project - a better stason.org/TH99 alternative
Reply 29446 of 29592, by luckybob
Law212 wrote on 2025-03-24, 23:03:
Now, now children. Play nice.
Reply 29447 of 29592, by GigAHerZ
@luckybob, that comic strip is... beautiful. Thank you. 😀
Reply 29448 of 29592, by ChrisK
We should admit this "hint" was maybe a bit too much between the lines.
Image a license plate "B-CU 911" (that's a German style one) ... on a BMW. May need some seconds to get the idea (for a native German speaker) 😉
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 29449 of 29592, by BitWrangler
ChrisK wrote on 2025-03-25, 12:58:
The closest I get is it's baysay oo, which is something like the root of own/owned not sure about U, so guessing something like "owned you 911" or "beat your porsche" but that's just guessing based off what German Ich gelernt im schule und so weiter.
Reply 29450 of 29592, by momaka
Linoleum wrote on 2025-03-20, 01:29:
I finished my refurbishing job of this filthy and rusty AT power supply. Happy with the results. Good for another 35 years!
Wow, nice work!
How did you get the metal looking nice and shiny again like that? Rust-converter paint? Or just regular paint + sanding?
I'm curious, as I've encountered a lot of rusty cases over the years... even have one in the basement waiting to decide what to do with it (it's seriously rusty!) Would be curious to know how you got everything nice-looking like that.
JustJulião wrote on 2025-03-15, 21:24:
Traveled 80kms to pick several CRT monitors for free.
Unfortunately, the bottom one, a 21 or 22", turns on but doesn't display anything.
The attachment IMG20250315221920.jpg is no longer available
Looks like a Sony Trinitron build (and FWIW, Viewsonic did use Sony as the OEM for some of their monitors, among others.)
First thing to check is for bad solder joints on the power board - particularly for the the heater, B+, and around HV-drive areas. Speaking of which, does the monitor make that "static electricity" noise during power up? If not, then that might suggest the high-voltage drive is not working. On late Trinitrons, HV drive is separate from HOT from what I remember.
On the other hand if you do get the static electricity noise to indicate the HV is coming up, then a missing heater voltage could be the source of no picture.
RetroPCCupboard wrote on 2025-03-14, 08:48:
MS Office peaked in 2003. After that it was just useless features and a more confusing interface. Haha. Give me back the menus over the ribbon interface any day. 😀
+1
Menus are more intuitive if you don't use Office too frequently and forget where to find stuff. Ribbons are quicker if you use Office daily *and* on the same monitor / PC.
FWIW, I remember when our university switched some of the PCs to Office 2007 (from 2003). Going between different classrooms with different size of monitors meant all of the ribbon buttons moved all the time. Moreover, different PCs had different ribbon button hidden and shown... not that this was any different in Office 2003. But at least in Office 2003, I could quickly find something within the menu if I couldn't on a ribbon button that was not in plain view. In Off.2007, good luck with that. It's like menus were a forbidden item or something.
I don't know what set off that trend, by I remember it as early as the first Chrome browser and some of the other 3rd part browsers in the late XP era. It's a fad I really wish to never have seen the light of day... but it did.
Menu systems are functional and most importantly, consistent.
Ribbon buttons are quicker *only* once you learn where everything is and *if* their layout doesn't change (which it often does.)
momaka wrote on 2025-03-11, 06:57:
The only thing I haven't tried yet is do both at the same time (OC and UV the V_core), but might do that later when I finish testing the board.
And now, to follow up on that...
I can indeed OC the CPU and under-volt it at the same time. I did reduce the OC a little, though - went with 115 MHz for the bus, mostly because the NB heatsink seems to run really hot with anything over 500 FSB and I didn't feel like modding it with a proper cooling. With 115 MHz bus, the resulting CPU frequency was 2.65 GHz - just a tiny OC over the stock 2.3 GHz (15%). Meanwhile, I lowered the CPU V_core even further, down to 1.325V. Had no problems running any benchmark or game... so, yay!
While at it, I decided to do test a good deal of the AGP cards I have acquired in the last 3-4 months. I tested the following:
* MSI GeForce 4 MX 400 SDR with 128-bit bus and 64 MB (I think?) of 5 or 6 ns RAM
* no-name GeForce FX 5200 with 64-bit bus and 128 MB 6 ns RAM (eww!! 😜 )
* no-name GeForce FX 5200 with 128-bit bus and 128 MB 5 ns RAM
* no-name GeForce 4 MX 440 SDR with 128-bit bus and 64 MB 4 ns RAM
* Sapphire Radeon 9600 Pro Advantage! 128-bit bus 128 MB "rare" 3.6 ns TSSOP RAM (nice!)
Compared to the Radeon 7000 64-bit 32 MB 6ns RAM video card I was using initially to test the system, all of the above were quite a bit faster - even the MX 400 and 64-bit FX 5200. That said, I didn't really test that many games... actually only two:
* Need For Speed High Stakes (full-grid race, 2 laps on Celtic Ruins, daytime weather, all graphics options set to max with D3D as the render, and tested under resolutions of 1024x768 and 800x600, both in 16-bit and 32-bit color modes.)
* Counter-Strike 1.6 (De_Dust 2, with 5 bots, both OpenGL and D3D modes under 1024x768.)
Honestly, though, that was more than enough to show the strengths and weaknesses of the above cards.
Well, the Radeon 9600 Pro clearly had no problems to achieve 60 FPS with any of the above settings and clearly outclassed all of the other cards. The 128-bit FX 5200 also did quite well, but not nearly as much as the MX 440. Now, I know that people here have mentioned it many times that the MX 420, 440, and 460 are all faster cards than the FX 5200. But for some reason, I was always left with the impression from back in the days that the MX cards were slow turds, so I had to check this for myself (perhaps because I probably only witnessed some gimped 64-bit MX with slow RAM??). To my surprise, though, even the MX 400 seemed to do better than the 64-bit FX 5200... well in more of the cases anyways (particularly under 16-bit color mode). With 32-bit color mode, the performance reduced quite a bit and the 64-bit FX 5200 came out faster. But between the MX 440 and the 128-bit FX 5200, I think the MX 440 came out as much faster in just about every scenario. In particular, the 128-bit FX 5200 performed quite well even in 32-bit color mode in NFS HS... but there were a few areas that did make the FPS dip just ever so slightly under 60... whereas with the MX 440, this didn't happen.
So for DX7 titles, I think the MX 440 brings quite a bang for the buck... and even the MX 400 is quite acceptable. That said, I wouldn't quite fully dismiss the FX 5200 cards - even the 64-bit one. After all, the above tests were done on a system with really fast (for the games I tested) CPU. For systems with much slower CPUs (i.e. Pentium II or very early P3 500 MHz or less), I think the difference in FPS could drop quite a bit.. so in such case, even the 64-bit FX 5200 may not be a terrible choice.
FWIW, I used the same (XP) drivers for the MX and FX cards, so overhead should be similar.
Anyways, I did the GPU testing over the course of several days. Also tested some IDE optical drives and floppy drives while at it. This also allows me to say that both IDE ports and floppy port on the motherboard were tested. Oh, and I tested most of the mice I've collected from the dumpster (and cleaned, of course) - a few needed their buttons opened and contacts cleaned, but no biggie. Finally getting through the piles of hardware I've been collecting over the last half a year... which is absolutely necessary, as I have even more stuff waiting to be diagnosed, fixed, recapped, and etc... then tested.
At this rate, I might need another lifetime to do it all. But at least everything tested really has been checked out thoroughly.
Reply 29451 of 29592, by Linoleum
momaka wrote on 2025-03-25, 19:18:
Wow, nice work! How did you get the metal looking nice and shiny again like that? Rust-converter paint? Or just regular paint + […]
Wow, nice work!
Thanks! Here's my whole process:
  1. After taking everything apart, I did a first steel brush session.
  2. Soaked everything in white vinegar for two days.
  3. Steel brush again, followed by sanding .
  4. Painted the inside with rust-oleum paint (black, I wish I had silver).
  5. Then, painted the whole thing with silver paint (didn't have enough to fully cover the inside).
I did another PSU two years ago with the same technique and it's still holding and looking good...
P3 866, V3, SB Audigy 2
P2 300, TNT, V2, Audigy 2 ZS
P233 MMX, Mystique 220, V1, AWE64
P100, S3 Virge GX, AWE64, WavetablePi & PicoGus
Prolinea 4/50, ET4000, SB 16, WavetablePi
486DX2 66, CL-GD5424, SB 32, SC55
SC386SX 25, TVGA8900, Audician32+
Reply 29452 of 29592, by BitWrangler
I don't know why, but every silver "rust paint" I've had never seems to fully dry, always seems a bit tacky and scuffs off easy, transfers to your hands when handling, leaves marks on paper if you rub it, etc. So be happy with the black.
Reply 29453 of 29592, by Aui
I finally finished my pre DOS 6.22 / Win 3.1 machine.
I explicitly wanted to get a genuine impression of how these earlier itterations feel
- real EGA
- DOS 3.3
- Win 2/386
- NC3
- original Paintbrush
- lots of other early windows stuff -fascinating!
Reply 29454 of 29592, by ChrisK
BitWrangler wrote on 2025-03-25, 14:20:
Right, "CU" is short for "see you" (the B is just the prefix for the city the car is registered here) and "911" refers to Porsche in general.
So literally meaning "my car (BMW) is faster than yours (Porsche) 😜😜😜" when seen from behind.
Almost an offence but only when you get it in an instant in some way 😉
Reply 29455 of 29592, by PcBytes
Rebuilt a rather classic PSU - a JNC LC-235ATX. For those in the EU region (including you, @momaka), you might recognize both PCBs used.
First off, the original had to come off. As much as I wish I could reuse it, the main transformer was not only fake, but too weak to put out 235W. It's not a 33 size trafo, it's a 28.
file.php?mode=view&id=215664
file.php?mode=view&id=215665
Fortunately, I had the original guts left from when I upgraded the Maxpower PL-400 PSU for one of my upcoming builds. A little bit of recapping, removing the 12v P4 header, and wiring it back, it looked like this.
file.php?mode=view&id=215666
It's by no means any more stellar, but at least it should do 235-250W without much issues.
Reply 29456 of 29592, by AGP4LIfe?
PcBytes wrote on 2025-03-03, 20:21:
Added a (what I presume is NOS?) Revoltec Air Guard fan to my recent Celeron 300A, and moved the old two wire fan to my Pluto based Athlon 600@800MHz (resistor modded).
I finally found a Gold Finger device on the "bay" for super cheap and am waiting for it to come in!! Really excited to do some overclocking without having to move resistors.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 29457 of 29592, by PcBytes
Installed Windows 2000 Pro on a Dell Latitude D630 w/ Core 2 Duo T7100 and GM965 graphics.
I'm actually surprised Dell has 2k support for it.
Reply 29458 of 29592, by yourepicfailure
The attachment P_20250326_225128.jpg is no longer available
I kind of don't know if this counts as "retro"
(had to use my camera as a monitor since my other CRT is on the fritz)
The attachment P_20250326_224213.jpg is no longer available
but I tried that "windows NT4 on Wii" drug
it performs just as good/bad as my T4400C cooking with a 25MHz UC'd PODP5V63 and 20Mb ram as you'd expect with NT4. Decent.
Just using some cheapo sd card is killing I/O.
PcBytes wrote on 2025-03-26, 23:27:
Please DONT remind me...
my NVS 110m D620 is beginning to die!
Reply 29459 of 29592, by PcBytes
Another classic Deer recapped, the F&C LC-235ATX. Funny how it's marked 240 on the PCB.
