Reply 220 of 237, by Stretch
Joseph_Joestar wrote on 2024-12-07, 21:09:
Stretch wrote on 2024-12-07, 21:05:
Does the Audigy driver enable Soundfont 2.01 operators on the SBLive, or will the SBLive still be restricted to Soundfont 2.0?
I'm not familiar with the differences between these soundfont versions, so someone else will have to test that.
I forgot to post the instructions on how to check the SF support with Vienna Soundfont Studio:
Click Options, Preferences, Devices
The SF Support will be listed at the bottom
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 221 of 237, by Joseph_Joestar
Stretch wrote on 2024-12-07, 21:59:
Nice, that's easy to test then.
Unfortunately, I no longer have a SBLive card in any of my retro builds, having switched them for various Audigy models. But maybe someone else who's using this guide with an active SBLive can check this.
Reply 222 of 237, by DudeFace
yukboboyuk wrote on 2024-12-04, 16:56:
Hi...greetings joseph, i'm trying to install my first retro pc to play some sierra and lucas arts game. i have P1 166 Mhz , 80 r […]
i have P1 166 Mhz , 80 ram , Chipset: VIA Apollo VPX, WIn96SE
Sb Live Ct4760 + Front panel
i'm completely newbie with all the settings, but gladly found your tutorial
Tried to follow your instructions and all drivers already installed
Creative audio @port 6400 irq 5
Try to play Fate of Atlantis from pure dos there was no sound at all
Did i do something wrong?
Please advise....thank you
looks like something has gone wrong, as Joseph_Joestar said there should only be one SB16 entry in device manager, i also have a CT4760, i use the Liveware 3.0 cd drivers, it might be worth giving it a try just to make sure your system is working as it should before trying alternative drivers.
Reply 223 of 237, by matti157
1) If I run a dos game in win98 dos prompt, can I redirect the midi sound to my real sc-88 attached to the joystick port?
2) And a joystick attached to the joystick port is visible in the win98 dos prompt?
3)and in pure dos the midi out to joystick port and a real joystick works?
Reply 224 of 237, by Joseph_Joestar
matti157 wrote on 2025-02-03, 01:56:
MIDI out via gameport won't work in pure DOS on SBLive and Audigy cards. That's just how Creative coded their drivers.
As for the actual joystick functionality, I haven't tested that, but maybe someone else can offer more insight.
Reply 225 of 237, by matti157
Joseph_Joestar wrote on 2025-02-03, 07:29:
Thank you,
but at this point why install your modified CD and not from the original CD? What advantages do you get?
Reply 226 of 237, by Joseph_Joestar
matti157 wrote on 2025-02-03, 09:57:
Thank you,
Soundfont support while playing DOS games from within the Win9x prompt.
That's the main reason I made this guide back in the day.
Reply 227 of 237, by matti157
Joseph_Joestar wrote on 2025-02-03, 09:58:
Thank you,
But instead using one of the original CDs versus your modified one, what does that entail? Just asking out of curiosity
Reply 228 of 237, by Joseph_Joestar
matti157 wrote on 2025-02-09, 21:37:
With stock VxD drivers, you cannot use soundfonts for playing DOS game music on SBLive cards. Instead, you're limited to ECW sets. If you don't know what soundfonts are, I suggest you look that up.
As an example, a 50MB soundfont allows Duke3D to sound like this. For comparison, with an 8MB ECW set, Duke3D sounds like this. And before you ask, yes the SB128 PCI uses the same ECW sets as SBLive and Audigy cards.
Reply 229 of 237, by matti157
Joseph_Joestar wrote on 2025-02-09, 22:08:
Thanks!
This piece of your guide clarify all
Note that soundfonts only work when DOS games are running from within Windows 98/ME. If you go to pure DOS (by choosing Start > Shutdown > Restart in MS-DOS mode) then the card will use the (worse sounding) ECW sets instead. To my knowledge, there is no way to use .SF2 based soundfonts in pure DOS with an SBLive card.
Reply 230 of 237, by jami3rez
Had a nightmare with this one.
I followed the process for an SB Live! SB0100 and I'm now having to reinstall Windows.
The drivers failed to install properly, the Creative Media Interface had a ? over it in Device Manager and there were no references to Game/Joysticks in the Device Manager. I did however have sound.
Wanting to rectify the problems I used the installer to remove the Drivers. Now when I boot up Windows it just hangs with a mouse pointer over a blank, teal screen. If I Ctrl+Alt+Del it sayd Msgsrv.32 is not responding. If I do it again it says HIDserv is not responding and I can go no further. I can get into Safe Mode and have tried removing every shred of SB drivers I can find in Inf and nothing changes. Even if I remove the Sound Card from my machine it still happens.
This was on a fresh install of Windows 98 SE.
Reply 231 of 237, by Joseph_Joestar
jami3rez wrote on 2025-03-27, 18:51:
Sorry to hear that.
What were the system specs? While I have never experienced anything similar myself, I have heard that DOS and SB16 Emulation drivers for SBLive cards can have problems on nForce chipsets, and potentially on some later Intel chipsets (ICH10 and such). Certain VIA chipsets also have latency issues with SBLive and Audigy cards. In any case, I would recommend trying the official drivers from the SB0100 installation CD and seeing if they work better on your system.
Reply 232 of 237, by jami3rez
Thanks, that CD seems to have worked, everything has installed now!
My new issue is that my PC now hangs for ages on boot. After the Windows 98 splash screen has been up it reverts to this.
TGAztGP
If I wait long enough it does go into Windows and sound is fine.
I’m assuming it’s some sort of IRQ conflict. I’ve tried the card in a new PCI slot, disabled COM and Parallel ports, disabled plug n play, cleared ESCD… I can’t assign IRQ to devices manually, just mark it as ‘reserved’ or ‘PCI DEVICE’.
My PC boots fine if I remove the sound card.
Any ideas?
Reply 233 of 237, by jami3rez
Image link didn’t work, attached it here.
The attachment IMG_7795.jpeg is no longer available
Reply 234 of 237, by jami3rez
Oh and system -
Athlon xp 2400+
FIC AM39L mono
2 x 256mb 333 RAM
S3 Trio V2 PCI VGA
NEC USB hub
Tried swapping them all around and it hangs still.
Reply 235 of 237, by jami3rez
Tried switching slots again. Now when I reboot it runs scandisk which sticks on 20% and I have to cancel it, then it tries to install the SB16 driver and I get BSOD!
About ready to throw this out the window!!
Reply 236 of 237, by Stretch
My PC hangs on SB16 emulation if I have the parallel port disabled in the BIOS. Can you enable the parallel port again? Maybe that will let you boot into Windows 98.
Reply 237 of 237, by Joseph_Joestar
jami3rez wrote on 2025-03-27, 23:58:
FIC AM39L mono
That motherboard uses the VIA KM400/KN400 chipset, right? I haven't tried that one myself, but I had serious problems with an Audigy1 card on a motherboard with the VIA KT333 chipset. Random crashes and freezes during hard disk activity and such.
Try the VIA latency patch mentioned in this thread and see if it helps. But yeah, sometimes a certain hardware combination sadly just won't work.
