Reply 2580 of 3485, by robertmo3
disconnect windows drive
Reply 2581 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 12:45:
I've had enough. I set it to boot off the USB. It reads it for a few seconds and then boots into windows. I enabled csm as well.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 2582 of 3485, by robertmo3
if you disconnect ssd with windows 11 it cannot boot into it
if you talk about win98 than hit f8 during boot and choose "boot to command line" from the menu
Reply 2583 of 3485, by robertmo3
you can also force always displaying menu at start on your p4
Reply 2584 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 13:02:
My ryzen based machine reads the flash drive for a couple of seconds and then boots into windows. I need to test the flash key on my win98 machine to see if it works there.
It's entirely possible the key's not bootable
Reply 2585 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 13:04:
To get the p4's results I had to boot straight into dos. The benchmark locked up after restarting in ms-dos mode.
Reply 2586 of 3485, by robertmo3
don't restart in msdos mode, just choose boot into command line
you can even just have norton commander (nc.exe) in autoexec.bat before "win"
Reply 2587 of 3485, by robertmo3
you can also add these lines in msdos.sys:
BootMenu=1
BootMenuDefault=1
BootMenuDelay=3
Reply 2589 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 13:13:
I'm familiar with the f8 menu and back in the 90s made my own.
But it's a distant memory now.
Reply 2590 of 3485, by robertmo3
you don't need to remember anything. everything you need i just posted
Reply 2591 of 3485, by robertmo3
it is a know problem that bios somehow sometimes chooses the latest os even if you force it to run older one
that is why you have to disconnect ssd with windows 11
Reply 2592 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 13:25:
I'm a bit beat at the moment. Will try it first thing tomorrow.
Reply 2593 of 3485, by BEEN_Nath_58
For me a bootable FreeDOS flash drive did it.
The only new issue was rendering VGA modes and the older ones, but obvio that's not the point here
Reply 2594 of 3485, by robertmo3
and where are your dhrystone results 😉
Reply 2595 of 3485, by sharangad
Updated the post with the Ryzen FreeDOS score:
Re: RReady (Rendition Verite wrapper) Test Build (Alpha 1)
The problem was that my flash drive registered as a USB HDD and not a flash key (unless this is something different).
Pentium 4 3.4 GHz MS-DOS(Win98)
Microseconds 1 loop:          1.06
Dhrystones / second: 939794
VAX MIPS rating: 534.89
Ryzen 2700X Dosbox (cycles=max 105%)
Microseconds 1 loop:          4.36
Dhrystones / second: 229555
VAX MIPS rating: 130.65
[EDIT] FreeDOS Ryzen 2700X (native)
Microseconds 1 loop:          0.17
Dhrystones / second: 6015038
VAX MIPS rating: 3423.47
[EDIT2] Ryzen QEMU (WHPX)
Ryzen 2700X QEMU (Windows Hypervisor Platform/WHPX)
Microseconds for one run through Dhrystone: 0.13
Dhrystones per Second: 7424594
VAX MIPS rating = 4225.72
[/EDIT2]
Reply 2597 of 3485, by sharangad
robertmo3 wrote on 2025-03-31, 15:35:
accidentally while looking for houston i found this reliant park track:
https://www.icr2.net/forum/showthread.php?tid … ht=reliant+park
which may be nice for testing cars as it looks to be simplest track so far
Thanks. Qemu looks nice. Do you know whether it has support for pentium dma, for Rendition transfers.?
Reply 2599 of 3485, by sharangad
Also, the memory access in dosbox is fairly optimal, I don't know how it can be made any faster. The cpu code is fairly rock solid. There are sleeps in there to control timing. I don't know whether they could be eliminated and whether that'd mess up the sound.
