Reply 80 of 88, by DesktopDynamite
Hello, stumbled onto this since I cannot get working 2x gravis gamepad and the gravis gamepad pro with the Logilink Gameport to Usb adapter.. On a YouTube video I found that switch has to be set on 3 for gravis gamepads, however only left and right directions work..
I have a Win 10 PC... Would this work?
If so I'm interested in purchasing.. As for soldering I am good at it 😀
Reply 81 of 88, by 1541
The "Logilink Gameport to Usb adapter" is the same as the original "Rockfire Gameport Adapter".
It supports only analogue gameport joysticks whereas the "Necroware gameport adapter" implements own logic to also support Joysticks & gamepads in digital mode.
It is also OS independent, so you can even plug it into the USB connectior of your phone and play with a Gravis Gameport gamepad like this
https://m.youtube.com/watch?v=bDuXLQjaocE
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 82 of 88, by DesktopDynamite
1541 wrote on 2025-03-24, 20:38:
The "Logilink Gameport to Usb adapter" is the same as the original "Rockfire Gameport Adapter". It supports only analogue gamepo […]
Thanks for the detailed reply. Will check out the videos.
As for buying the kit, do I need to preorder from here?
I'm from Malta EU.
Reply 85 of 88, by Lostdotfish
I have some spare, fully assembled adapters available if anyone is interested?
I did a minimum order of PCBs so thought I may as well build them all up. USB C Pro Micro.
Selling for BOM cost plus postage plus a beer for my solder and time .
3 available, 1st come 1st served.
The attachment PXL_20250718_125914561.jpg is no longer available
Contact me on [insert email]
Reply 86 of 88, by vetz
This goes into the no marketplace rule, so some posts are removed.
VOGONS is no marketplace!
Lostdotfish: I understand you're selling an assembled community project for the cost of BOM and beer, but we have to put the line somewhere. I'd accept if you mentioned in your post you had a small surplus and to contact you outside the forum for details, but making bumps and everything is too far.
Your post is way border-line on the rule, so this should not be seen as a set policy on VOGONS going forward.
Reply 87 of 88, by Zawa
Lostdotfish wrote on 2025-07-18, 13:12:
I have some spare, fully assembled adapters available if anyone is interested? […]
Lostdotfish,
Could you contact me directly ?
Thank you
Stefan
Reply 88 of 88, by jimavagianos
Hello,
I would like to purchase one if are still available. Please contact me directly also. I stay in Greece. Also inform me what is the total cost for an adapter with shipping cost in Greece.
