Asrock 775Dual VSTA & Core4Dual thread
Reply 840 of 860, by MadMac_5
Apollonios wrote on 2025-04-01, 06:40:
does anyone have 4gb under win 98 and a voodoo 5 pci running on the board?
i can confirm that the versions of the board without sata2 allow windows 98 to be installed via the sata 1 port. So you can avoid the use of adapters with ssds.
can anyone give me advice on overclocking a Q9550 on the board?
Aside from what other posters have mentioned, doesn't Windows 98 start to fall apart pretty fast when given more than 512 MB of RAM?
Reply 841 of 860, by agent_x007
Depends on patches, "stock" requires some tweaks - but it can make to work (either by 3-rd party apps, or simply limiting RAM size to 512MB and few other things).
Reply 842 of 860, by Apollonios
i can't get my Asrock 775Dual VSTA (sata1) to run stable with 4gb. i have tested 3 different DDR2 2x2 gb kits. All of them cause problems.
Which RAM can you recommend?
The errors manifest themselves with strart problems or that memresr86 freezes although it finds no errors.
With 2x 256MB DDR1 RAM there are no problems.
But I want to use Win 8.1 as well as Win98se, so I need more than 512mb...
Reply 843 of 860, by Apollonios
I have to revise my statement, memtest86 crashes after a while even at 512mb...
Reply 844 of 860, by Bruno128
Apollonios wrote on 2025-04-02, 19:57:
Those boards have RAM slots of subpar quality. I’ve seen user on this forum use rubber band to hold the clips firmly in place. As boring as this advice sounds consider cleaning RAM terminals with alcohol and re-seating known good modules until you get memtest86 pass.
SBEMU compatibility reports list | Navigation thread
Reply 845 of 860, by Apollonios
it runs, just with 2x4gb under win xp and i'm testing it with prime95. Thanks for the tip anyway. if it causes problems i will treat the contacts with isopropanol next.
Is it normal that the bios is so slow with pci express graphics cards?
edit:
prime is absolutely stable, I should try an older memtest86 version... I tested with 4.3.7.
Reply 846 of 860, by Apollonios
i don't understand this board, constantly cmos bad when it is out of power, the battery is new...
Reply 847 of 860, by Zoomer
Well, then the battery is probably dead 😀
I mean, these CR2032s have a tendency to be dead even before their packaging is open.
And the BIOS screen does indeed update slow on some PCIe cards. But that's due to the fact that these are newer cards. There are some older PCIe GPUs that work fine in the bios mode.
It's not only bios btw. The Windows Vista/7 pre-boot screen (if multibooting or choosing a boot mode) will also be slow.
However, everything's fine in all the DOS modes with such a card. Weird.
MB: Asus P3B-F 1.03 (2x ISA)
CPU: PIII-S 1.4GHz/VIA C3 800MHz
RAM: 256MB PC133
Video: GeForce 4600Ti/Voodoo 5 5500/Voodoo 3 3500 for DOS Glide
Audio: SB16 OPL3 + Audigy Platinum Ex
OS: Windows 98
Reply 848 of 860, by Apollonios
i imagine it was more stable with the core 2 duo, is it a problem with the quad?. The board is behaving very strangely, i will put it away for now, as i also have other projects here. It could be anything, the board itself (dry contactors) or even the power supply. I just don't have the space and time for the project. But I'll come back to it and report back!
Reply 851 of 860, by ruthan
Karbist wrote on 2025-01-22, 06:20:
If this special bios is just a cpu micro code update for xeon cpus, why don't you do it yourself? asrock has ami bios which is t […]
If this special bios is just a cpu micro code update for xeon cpus, why don't you do it yourself? asrock has ami bios which is the easiest to modify.
these are the 2 micro codes for quad core xeon cpus (C0,E0 stepping)
https://github.com/platomav/CPUMicrocodes/blo … RD_8FE1A203.bin
https://github.com/platomav/CPUMicrocodes/blo … RD_A3107D75.bin
load the bios in mmtools 3.22 go to cpu patch tab, load the micro code, click apply.
It took also of time, but i finally tried it with Xeon X5355 with this board and som ASUS P5Q board (bios mod above worked great, thx), good it that its booting, but it detect wa multiplier 7.5 (because FSB 1600 instead of 800) -so it runs max like 300*7.5 - 2250 MHz,
its much slower than Q6600 and Pentium E5800 as 3.5 GHz in single thread and it could probably push it to near to 4GHz.
Question is could be multiplier unlocked and push it higher than 7.5 through some bios mode? Otherwise Xeons could be good only for 1600 MHz FSB board..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 852 of 860, by complain77
hi there, recently got 4core-dual-vsta. I have installed Windows ME with Via 4in1 4.56. Catalyst 6.2 for My X850 GTO with unlocked VP a PP (16/6). Cpu is E6700. IAM surprised by very low 3dmark 2001se score, only 20288, as opposed to my Asus P5PE-VM, which gives on same config little under thirty thousand points🥲
Reply 853 of 860, by The Serpent Rider
Issues with VIA AGP driver implementation on Win 9x. You'll get better score with PCIe X800.
VIA zero bytes AGP memory bug | Navigation thread
Reply 854 of 860, by Apollonios
which modern, quiet and inexpensive power supply can you recommend for the board for a quad + a 580 gtx?
Reply 855 of 860, by complain77
you are in bad thread man maybe because its more general hw question, but you must remember that this particular board has 20 pin atx power connector, so you must use power supply which support this (some ps have only 24pin non detachable one). I use for example Corsair VX550, which has two pcie 8 pins if i remember corectly.
Reply 856 of 860, by wwdenis
Hey everyone.
Regarding 775Dual-VSTA with 4GB DDR2, do I need a special BIOS?
I see in the thread success reports with with 4CoreDual-SATA2 but few with the 775Dual.
Thanks!
Reply 857 of 860, by ApostolCV
wwdenis wrote on 2025-05-25, 01:50:
Hey everyone. Regarding 775Dual-VSTA with 4GB DDR2, do I need a special BIOS? I see in the thread success reports with with 4Co […]
Hey everyone.
Thanks!
, yes. You need a mod BIOS for 4GB (3.25GB) support.
Not necessary feature but if looking for troubles then you can xD.
Reply 858 of 860, by wwdenis
ApostolCV wrote on 2025-05-25, 11:18:
Hey everyone.
Thanks!
Done. Thanks!
Windows 7 x64 recgonized 3,12GB
I have a 4GB DDR2 stick and an ATI X850 PE AGP installed.
Unfortunately with 2 sticks (8GB) the computer freezes at the boot screen (I am even surprise that it shows something)
I miss the trouble when I was with my gf.
My father (in South America) usually says: "You do not need to marry to look for trouble. Just buy an used car."
He did not know trying to run Windows 98 all way to Windows 10 in the same MB would be way worse than fixing an old 1969 VW Beetle 🤣
