First post, by megatog615
I'm attempting to bypass this card's amplifier so it doesn't sound so terrible. At first I thought it would be straightforward, moving the resistors from R9 and R11 to R8 and R18 but that resulted in no audio output at all. I'm tempted to just desolder all of these SMD components around the amp chip and run a wire straight from pins 50 and 51 on the ES1868F to the output jack but I'd like a more elegant solution.
Reply 1 of 7, by Tiido
I'm pretty sure you also need to disconnect the outputs of the amp chip before things begin to work correctly. Pins 1 and 3 are the outputs.
Reply 2 of 7, by PcBytes
I'm kind of in the same boat but with a 1869F. The audio is horribly clipped no matter if Windows or DOS and I'd love to find a fix to that - even if it means disabling the amplifier.
Reply 3 of 7, by megatog615
Tiido wrote on 2025-03-17, 08:26:
I moved the resistors and cut pins 1 and 3 off the amplifier. I only get right-channel mono sound. Descent setup puts right and center on the right and nothing comes out on the left. Should I just cut the amplifier off entirely?
EDIT: Turns out the 22k ohm resistor on that line was dead. I've fixed it and I get stereo sound now. HOWEVER, I think a 22k resistor is too much; the volume takes a big hit. I think since the whole amp circuit is bypassed I can take the 2.2k or the 220 ohm resistors and use them instead. I'll make a new post with my findings.
PcBytes wrote on 2025-03-18, 17:59:
Are you sure your card doesn't have jumpers for that? If so you're in luck. Some of the 1868/1869 cards had jumpers to enable or bypass the amplifier. This cheap 1868F card of mine has the amp hard-wired.
Reply 4 of 7, by PcBytes
megatog615 wrote on 2025-04-04, 16:54:
I moved the resistors and cut pins 1 and 3 off the amplifier. I only get right-channel mono sound. Descent setup puts right and […]
Mine didn't have jumpers either.
Reply 5 of 7, by megatog615
Okay, through some quick testing I was able to figure out that the 2.2k resistors were the best for volume. Here's my (ugly) work. Ignore the lifted pad on R11, I don't know where that came from(he lied). I get stereo sound and the card is now poly-modded.
Reply 6 of 7, by megatog615
PcBytes wrote on 2025-04-04, 17:03:
What card is it?
Reply 7 of 7, by PcBytes
megatog615 wrote on 2025-04-04, 20:00:
What card is it?
A noname card w/ no jumpers (or any way of adding them anywhere either.)
