Third update: Painting & Finishing - Bringing the Amiga 1000++ case to life
With all the parts glued, assembled and smoothed out, it was finally time for one of the most satisfying steps - painting and finishing (!not!). Getting the right look for this build meant taking a careful, layered approach to ensure a smooth, professional finish. Here’s how it went:
Before applying any color, I laid down two layers of primer, allowing each coat to dry for a couple of hours before lightly sanding with 1000-grit sandpaper. This step is crucial for creating an even surface and ensuring the paint adheres properly. Any imperfections left behind at this stage would only become more noticeable later, so patience was key.
For the main color, I went with RAL 1013 (Oyster White) acrylic paint, which closely matches the original Amiga 1000 aesthetic. I applied three thin, even layers, letting each coat dry before giving it a light 2000-grit sanding to keep the surface smooth.
With the base paint done, it was time for the details - water slide decals. These added the finishing touches, like the logo and the AMIGA label, to give the system that "factory-made" look. Applying them required precision, ensuring they were perfectly aligned. Back then, when I used printable decals for my prototype 3.2 I ran into several issues with the toner not adhering to the transfer paper. Thanks to BitWrangler I got it done this time. He suggested spraying the decals with clear coat first, before applying them to the model - this worked like a charm. *Thank you, BitWrangler
To protect the paint and decals, I applied two layers of clear coat, giving the surface a smooth, even sheen. Once fully cured, I did a final 3000-grit sanding to remove any minor texture defects and bring out an almost flawless finish. A satisfactory result, reflecting my current skillset and experience with room for improvements 😉.
As a small reward for myself and to keep myself motivated, I assembled the parts and took a beauty shot of the case.
The attachment A1000++ p4.8 - airbrush & decals.webp is no longer available
More updates soon as this build gets closer to completion!
