Reply 2660 of 2838, by sharangad
robertmo3 wrote on 2025-04-06, 06:57:
this screen is important https://www.intel.com/content/dam/support/us/ … 5486_image3.png […]
also you need to have hyper threading disabled for twice more performance in single core applications (also in emulators/virtualizators)
also you haven't confirmed if you have haxm installed from here: https://github.com/intel/haxm/releases/tag/v7.8.0
i7 2600 doesn't support the EPT extension of VT-x.
https://www.youtube.com/@sharangadayananda
Reply 2661 of 2838, by sharangad
I didn't know I needed to install HAXM. I thought QEMU had its own implementation of VT-x .
Also 😀 I don't recall your telling me to install HAXM. Maybe you did and I failed reading comprehension. That's also quite likely.
Reply 2662 of 2838, by robertmo3
robertmo3 wrote on 2025-04-04, 14:23:
"Windows Hypervisor Platfrom" has to be enabled for whpx to work […]
"Windows Hypervisor Platfrom" has to be disabled for haxm to work
haxm also needs to be installed first:
intel cpus work with whpx too (but whpx is slower)
Reply 2664 of 2838, by sharangad
robertmo3 wrote on 2025-04-06, 07:25:
sharangad wrote on 2025-04-06, 07:13:
according to this site it does:
https://www.intel.com/content/www/us/en/produ … ifications.html
OK I'll install haxm.
Reply 2666 of 2838, by sharangad
robertmo3 wrote on 2025-04-06, 08:19:
it's not that one it is this one https://icr2.net/forum/showthread.php?tid=601 … id=3928#pid3928 […]
sharangad wrote on 2025-04-06, 04:23:
it's not that one
it is this one
@tincup said it was dated 2014. This still seems a bit early.
Reply 2667 of 2838, by robertmo3
tincup wrote on 2025-04-05, 19:21:
I've just about completed testing of all the good tracks/cars I have - CART and IRL - 1980s thru 2000s. Not bad at all. Echoing my intitial assessment a bit more than half tracks need reducing and all carsets. Not concerning myself with formation lap/race start performan hit for now. Mainly interested in seeing how complete the colection is for RR, and overall I'd say it's great.
No luck getting Mexico addon track (Mexico City, big dat 1-24-2010) running - even reduced. It's heavy but runs fine in dos/windy.
Discovered that running under dosbox-staging can help a few reluctant car/track combos (mainly indy05/indy06). Boosting dosbox.conf MemSize=128 (from 64) got all versions of Indy running with the indy05/06 car sets for instance. So tweaking dosbox does have an effect in some edge cases.
Reply 2668 of 2838, by sharangad
robertmo3 wrote on 2025-04-06, 12:48:
Aargh! Reading comprehension failed again.
Reply 2669 of 2838, by sharangad
That Mexico City track works without reduction, straight off the dat. The MIPmaps take a while to load, a bit too long.
I tried it this morning. Since it worked I assumed it was the wrong track.
Reply 2670 of 2838, by tincup
hmmm ...I still get the "Problem Loading Track" error.
Quick question - I've been testing with the free alpha builds as I find it easy to make/tweak standalone installs for each season skipping the launcher. I bought the retail version. Can I just copy the new dosbox/staging folders into my installs? With the app installed now can I still keep configurations local (like dgvoodoo etc)? I prefer not to rely on the system-wide app. Also how do updates work now? I didn't see an option to download as a zip - it just self-installed.
EDIT: the 2 earlier versions of Mexico run, but they are sort of betas. Still can't open the third upgraded version (1-24-2010 dat). However since I have everything unpacked I've been manually "upgrading" the 2nd version with better grass etc by copying mips. - And yes, as Pavel mentioned it's not the correct CART layout - it lacks the turns at the back end that bypass the first part of the big 180. But it's not bad.
EDIT 2: the patched INDYCAR.exe seems to have pepped up FPS across the board which is great. Plus I increased conf memsize=512 per your rec (if I understood you right).
sharangad wrote on 2025-04-06, 13:16:
Reply 2671 of 2838, by sharangad
tincup wrote on 2025-04-06, 16:06:
hmmm ...I still get the "Problem Loading Track" error. […]
Thanks for buying a copy. For every store release there should be a matching Alpha release.
You can manually update the files. Just copy dosbox.exe, dosclient.exe, redline.dll and verite.dll and all the other dlls. For staging copy dosbox-staging.exe and the other files. Staging also needs all the files in the staging subdrectory. Staging belongs in the staging subfolder if you're running it through RLauncher.
If you're updating it manually, update the app from the store and copy the files across.
If you're updating it through RLauncher.exe, update it from the Microsoft Store, run rlauncher, launch Dosbox-Rendition, close it then run dosbox-staging-rendition, close it and that's it. RLauncher copies the files across to the execution folder every time an app's launched. It's a bit cumbersome, but it exists because earlier builds of the app had a habit of dying unexpectedly and locking the files, which meant the machine would have to be rebooted to run it again.
If you run it through RLauncher and the files are locked, it'll renamed all the files and then copy the files across before launching.
The config for the wrapper itself is in rendition.cfg, which should be in the same folder as dosbox.exe (or staging). Dosbox-rendition.config and dosbox-staging.config are the arein %localappdata%\temp and is (unless overriden by the command line passed on dosbox launch) are global and unaffected by updates. Some settings may change from version to version, but will only be done if there's a clear improvement in doing that for nearly all systems.
Could you share your copy of the later Mexico City track? The version I tried (https://icr2.net/forum/showthread.php?tid=601 … id=3928#pid3928) appears to work. With the current store release (1.0.40 if you look in settings\apps) memsize is forced to 512 MB and ignored. I've got versions which lock 1.5 GB of RAM and patched versions of ICR2 which can use 1.2 GB of texture heap (system RAM). Larger values don't seem to be possible. With a larger texture heap, ICR2 does in fact allow much larger textures to be used at slower frame rates, ridiculously slow frame rates .
Reply 2672 of 2838, by sharangad
Yeah it doesn't work. I think I messed up copying the track across.
I have no idea what's wrong with this one.
Reply 2674 of 2838, by sharangad
Dhrystone 2 benchmark QEMU i7 2600 with HAXM (Win10):
Microseconds for one run through Dhrystone:0.74
Dhrystones per Second: 1360544
VAX MIPS rating = 774.36
Windows Hypervisor Platform on my Win10/i7 2600:
Time for loop iteration 0.33 ms
Dhrystones 3065134
VAX MIPS 1744.xx
i7 12600 VMWare WIn98 under Win10:
Microseconds 1 loop:          0.32
Dhrystones / second: 3100775
VAX MIPS rating: 1764.81
WHP/VMWare appears to be faster for this old CPU.
Intel HAXM appears to be discontinued.
Reply 2676 of 2838, by tincup
sharangad wrote on 2025-04-06, 23:05:
Thanks for buying a copy. For every store release there should be a matching Alpha release...
No thank you. And no watermark now haha. I basically got it down after I figured out how/where files were being installed and sorted it out. For some reason working with the alpha was easier for me - but now it's done. Thanks for the upgrade notes - saved for reference.
From the start my setup has been a separate folder for each season. In the folder there's a game subfolder, and an RReady dosbox subfolder. Dosbox launch .bats in the season folder all relative pathed so I can move/rename the season folder without issue. For upgrading I've been making a new RREADY subfolder and swapping out each install.
ICR2R1995 (Season folder)
- ICR2R (the complete came/tracks/cars etc)
- RREADY (dosbox/your stuff/conf/cfg)
dosbox.bat
dosbox-staging.bat
20 in all...
What I'm finding now is that reducing some carsets is not strictly necessary - but still makes sense for decent FPS. So all the work was actually worth it. I may revist tracks with noticeable terrain popping and see if they can be returned to unreduced. But it's so carset sentitive I'm inclined to let good enough alone.
Reply 2677 of 2838, by sharangad
And Mexico City is go:
This track wouldn't reduce with
tredit <path to unpack dat dat> -reduce -convert <output folder>
It needed this version of TREdit:
https://nirvtek.com/downloads/TREdit.20250406.001.7z
MD5: bb57f14e880ffe665168b9b5106f88c6
used with the command line:
TREdit.exe <path to unpacked dat> -reduce -maxmips <maximum number of mipmaps per texture> -convert <output path>
e.g.
TREdit.exe c:\temp\mexicodat -reduce -maxmips 5 -convert c:\temp\mexicoreduce
(Apologies to Vogon tincup, I should have figure this out sooner)
Mexico City (Max 5 mip maps per texture) Now Rendition Ready:
https://nirvtek.com/downloads/MEXICO.5Mips.RenditionReady.7z
MD5: 9280297856f9d6b1856a7ecb2608c2b8
Vid:
https://youtu.be/5NTrM-Fn8xY
Reply 2678 of 2838, by robertmo3
what about qemu whpx on 2600?
just enable whp, reboot and try
Reply 2679 of 2838, by sharangad
robertmo3 wrote on 2025-04-07, 04:42:
That worked. I posted the score. It's similar to the vmware result. The Intel specific path, haxm, is slow.
The ryzen only works with the last option, emulated mode, not even with whpx.
