Reply 2700 of 3300, by tincup
- Oldbie
Side by side comparison of Mexico; almost identical with a few small things of note: both good performers - Practice full field starts in 50s and hits 60 leaving pit. Oddly, I'd say my hand built version has a hard to pin point "smoother" feel at times even with both running at 60 - really subtle. It seems to find that glassy smooth spot a little easier.
Popup is about the same, but the barriers in RR have a blue color at distance while in my hand fixed version they remain a flat gray. So the RR version is a bit more distracting at the horizon.
Fence/grandstand popup about same.
Track warning lights - in RR colors are visible at distance but my hand fixed color pops in only as you drive by. I tested the RR mip but the track didn't load - a cumulative mip effect? Overall though hard to find much difference.
OTOH there's an additional difference to the real CART layout. It uses the turn 4 cutoff to skip turns 5-6. So as Pavel said on ICR2.net it's def not the correct layout. But it's fun, looks good and pretty close.
