Reply 640 of 1090, by vsharun
jamesfmackenzie wrote on 2025-04-08, 22:18:What a fantastic result! 😎🏆
Do you think the adapters will be sold on eBay too? I have a Supermicro motherboard ready to go!
I encourage my friend to do so. Close to the summer I suppose.
I also may recommend you stick with this Z87M-Pro4 board because of overclocking, PCI availability and lack of IRQ conflicts: both 5 and 7 are available - this maybe PITA with other boards. And as a dialup fan with lot of modems, this board has a COM header.
With this board soldering point for LDRQ1 quite apparent. I have also Gigabyte and Asrock B85M's (D3H rev 1.x and Pro4) with PCI slots with LDRQ1 also soldered and proven works. They both support K CPUs overclocking.
Those boards are quite available and attractive for 30-50$ w/o and w/CPU, so I bought another two $10 w/CPU H61 MSIs (2xPCIe 1x, no PCI), both works with adapter and DOA Asus B86M-E .
Check boardview for LDRQ1 availability before you buy.
In most cases if the board you evaluating has SuperIO of some sort, there will be high chance LDRQ1 availability, if not - very low. This is not binary rule, but very close to. I spent almost a week evaluating boards and looking for/in boardviews and the conclusion was as stated.
