Reply 220 of 407, by keropi
- l33t++
Joseph_Joestar wrote on 2025-04-15, 15:53:Phil just released a video review of the MK1869. He covers the card in great detail, though I do have small note regarding his experiences when using the native AudioDrive mode in Tomb Raider and Descent.
As Phil correctly observed, digital audio becomes more filtered when using the AudioDrive mode in the aforementioned games. However, this issue only occurs in games which use the HMI Sound System (both Tomb Raider and Descent do) and is likely caused by a bug in HMI's own drivers. In contrast, if you select the native AudioDrive mode in games which use the Miles Sound System (e.g. Heroes of Might and Magic 2) you will get crystal clear 16-bit digital audio, with no excessive filtering. Just thought I'd clarify that.
thanks for this bit of info Joseph_Joestar
what other secrets are you hiding? 😁
