DosFreak All System Specs 4-25-2025
Reply 60 of 67, by robertmo3
Seagate is now selling refurbished disk drives. It has set up an official storefront on eBay as a direct channel for consumers to access factory-certified hard drives as part of the Seagate Circularity Program. Seagate says it’s committed to enabling the secure reuse of storage devices and reducing hard drive shredding. Hard drive shredding entails breaking down a hard drive into tiny pieces so that data cannot be recovered. As rare earth materials contained in those parts cannot be reused, hard drive shredding harms the environment and is not sustainable.
https://www.ebay.com/sch/i.html?_dkr=1&iconV2 … ecerthdd&_oac=1
Reply 61 of 67, by DosFreak
Updated my main system.
Added B850M motherboard. (Replacing B650M)
Added AMD 9950x3d (Replacing 7950x)
Inverted the Sama IM01 case
The now bottom case fans were changed to intake
The rear fan was changed to exhaust
The CPU fans were changed to blow towards exhaust
The bottom intake fans blow upwards hitting the mobo, RAM, CPU fan intake and GPU.
I might have room to deshroud the GPU but I ran a test all night and GPU was steady at a constant 70c and the case is at my feet so noise isn't a thing so not much point.
MAIN SYSTEM
Case: SAMA IM01 $69.99 (Currently inverted)
Case feet: 4x Monosaudio 40x20mm Speaker Isolation Feet Speaker $15.50
PSU: Corsair SF750 750W $116.99
Motherboard: ASUS TUF Gaming B850M-PLUS WiFi AMD AM5 B850 mATX $240.89
Processor: AMD Ryzen 9 9950X3D 16-Core Processor$974.55
Processor cooler: Noctua NH-U12A $119.95
Memory: 1x G.SKILL Trident Z5 Neo Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) $259.99
SSD: 2x SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 $644.46
Fans:
REAR EXHAUST 1x Noctua NF-A9 PWM chromax.Black.swap, Premium Quiet Fan, 4-Pin (92mm, Black) $19.90
CPU TOWARDS EXHAUST 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
BOTTOM INTAKE 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
Video card: Geforce RTX 4080 16GB VENTUS 3X OC $1157.00
Monitor: LG 38GN95B 37.5" 3840x1600
Make your games work offline
Reply 63 of 67, by DosFreak
I'll look through the thread.
FYI I don't use projects created\forked by banned users. My sanity is highly important to me.
So that leaves only two projects I can't\won't touch. I won't list them but one of them is the one you posted.
Reply 64 of 67, by robertmo3
you can use whichever dosbox you want and whichever vmware/virtualbox/qemu/pureboottodos 😀
Reply 66 of 67, by DosFreak
Windows 11 24H2
DOSBox 0.74-3
core = dynamic
cycles = max
D1:
Microseconds one loop: 1.47
Drhystones/sec: 681576
VAX MIPS: 387.92
D2
Microseconds one loop: 1.49
Dhrystones/sec: 669456
VAX MIPS: 381.02
Reply 67 of 67, by DosFreak
Added Framework laptop to specs
Framework Laptop 13.5" w/ AMD Ryzen AI 300
Chipset: Ryzen AI 9 HX 370 w/Radeon 890M
Memory: Kingston FURY Impact 64GB 2x32GB 5600 MT/s
SSD: Samsung 990 PRO 4TB M.2 2280
