Updated my main system.
Added B850M motherboard. (Replacing B650M)
Added AMD 9950x3d (Replacing 7950x)
Inverted the Sama IM01 case
The now bottom case fans were changed to intake
The rear fan was changed to exhaust
The CPU fans were changed to blow towards exhaust
The bottom intake fans blow upwards hitting the mobo, RAM, CPU fan intake and GPU.
I might have room to deshroud the GPU but I ran a test all night and GPU was steady at a constant 70c and the case is at my feet so noise isn't a thing so not much point.
MAIN SYSTEM
Case: SAMA IM01 $69.99 (Currently inverted)
Case feet: 4x Monosaudio 40x20mm Speaker Isolation Feet Speaker $15.50
PSU: Corsair SF750 750W $116.99
Motherboard: ASUS TUF Gaming B850M-PLUS WiFi AMD AM5 B850 mATX $240.89
Processor: AMD Ryzen 9 9950X3D 16-Core Processor$974.55
Processor cooler: Noctua NH-U12A $119.95
Memory: 1x G.SKILL Trident Z5 Neo Series AMD EXPO 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) $259.99
SSD: 2x SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 $644.46
Fans:
REAR EXHAUST 1x Noctua NF-A9 PWM chromax.Black.swap, Premium Quiet Fan, 4-Pin (92mm, Black) $19.90
CPU TOWARDS EXHAUST 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
BOTTOM INTAKE 2x Noctua NF-A12x25 PWM chromax.black.swap, Premium Quiet Fan, 4-Pin (120mm, Black) $65.80
Video card: Geforce RTX 4080 16GB VENTUS 3X OC $1157.00
Monitor: LG 38GN95B 37.5" 3840x1600
