First post, by pshipkov
A while ago upgraded this card Number Nine 9FX Motion 771 VL (S3 Vision968-P) from the standard 2 to 4 Mb of RAM.
I think i saw 4Mb reported by SpeedSys at the time, but recently i noticed that only 2 are reported again.
Now i am starting to doubt myself that i ever saw 4Mb.
The 2 additional megabytes are added on the back.
Double and triple checked that all pins are properly soldered properly.
Soldered capacitors of the same properties as the ones in the front - 110mF.
The two resistors R44 R45 in the upper left are also matched as in the front (R42 R43). Their "output" voltages are slightly above the 0.53V readings in the front ones. I have them at 0.55V.
Checked voltages all around - they match the ones from the chips on the front.
There is always a chance that at least one of the newly added chips failed, but i doubt it. Wonder if somebody has an idea of what may be wrong, before i get quick with the soldering tools and potentially add damage to the assembly along the way.
Thanks in advance.
