First post, by orac81
Hi, this a little 64 byte demo of mine I thought I might share here..
https://github.com/orac81/miniapples/raw/refs … in/magixfly.zip
MAGIXFLY.ZIP (9k)
The attachment magicfly_screen.png is no longer available
This is an old-school DOS/VGA graphics demo program.
It gives the (classic) effect of flying over a changing landscape.
The x86 assembler source code (MAGIXFLY.ASM) is included, and there are comments with suggestions for changes, if you want to experiment.
It can run on an 8086 (or later) PC with VGA under MSDOS/Freedos. An FPU is not needed.
For modern PCs, it will run on Linux/Windows in DOSBOX, or other emulators.
To run, boot DOS and type:
MAGIXFLY.COM <ENTER>
Hit ESC to exit the demo. Type CLS or MODE 80 to return to 80 col display.
All variables held in registers, which makes the code smaller/faster.
AX,DX,SI are temp calc regs.
DS (data seg) points to VGA screen (A000h)
BX = Pixel position for plotting.
CX = time (frame count)
DI - Y position (for fx calc)
BP = X position (for fx calc)
It uses the open source NETWORK x86 assembler, NASM, but can easily be adapted to others.
Build with: NAS2COM magixfly
or NASM -f bin magixfly.asm -o magixfly.com
The demo isnt wildly new/original, but does have a few little ideas of its own, and it all neatly fits into 63 bytes. Enjoy!
Reply 1 of 4, by zyzzle
Thanks for sharing. I love little neat demos like this. Keep them alive in 2025! Raw ASM is so efficient and lean. It puts modern programming bloated "obfuscations" to shame.
Reply 2 of 4, by orac81
Thanks!
I have added a Turbo-c version to that archive, with my TCTINY build utility/library for TurboC. With that, the C version of the same demo builds to only 144 Bytes, so it is possible to build small programs like that with a high level language. Here is the TC version:
/* MAGIXFLY.C  - Tiny MSDOS 3d flying effect demo in 144 bytes.
(by orac81)
Simple demo of ultra-small compilation using TurboC 3.
To compile: tctiny.bat tc3path magixfly
ie: tctiny \m\tc3\bin magixfly
(needs MASM and exe2bin, or TASM)
include "tctiny.c"
unsigned char far *pVdu;
unsigned int frame; /* Frame count */
void main()
register unsigned int x;
unsigned int y;
unsigned int calcy;
IO_VIDEOMODE (0x13); /* Set VGA video mode 13h 320x200x256 */
do {
pVdu = (char far *) ((long) 0xa0000000L);
for (y=10; y<210; y++) {
calcy = ((2560/y) + frame) ;
for (x=320; x; x --) {
*pVdu = (BYTE) (((((x<<4)/y) ^ calcy) + (frame >> 8)) & 31) ;
pVdu ++;
frame ++;
IO_GETKEY (x); /* See if ESC key hit */
} while (x == 0);
Here is the TCTINY lib with some more such demos..
https://github.com/orac81/miniapples/ra ... ctiny.zip
Reply 3 of 4, by zyzzle
Ha.. Of course, I don't include Turbo C in the list of those modern bloated obfuscations such as Java, Javascript, Rust, Python, etc, etc.
Reply 4 of 4, by orac81
I posted this up on pouet, and of course someone comes along and rejigs the code, so it now compiles to just 52 Bytes! Without the exit check it would be about 48 bytes.
The end tests for loopX/loopY are really ingenious.
But I bet no one can improve on this.. 🙂
; MAGIXFLY.ASM by orac81, improved by rrrola.
; 52 byte flying demo.
; es:di = pixel address, bx=time, bp=y, cx=x
OFFSETY equ 12
org 100h
mov al,19
int 10h ; Screen mode 19 - VGA 320x200x256 (Using default VGA palette)
push 0A000h
pop es
reloop:
mov bp,OFFSETY
loopY:
inc bp
mov ax,0A00h
cwd ; dx=0 (ax=2560)
div bp
add ax,bx
xchg ax,si
mov cx,320
loopX:
imul ax,cx,16
cwd ; dx=0 (ax<=5120)
div bp
xor ax,si
add al,bh
and al,31
stosb ; (es:di) = al
test di,di
loopnz loopX ; X--; if (X) goto loopX;
jnz loopY
; di=0 after the loop
inc bx
mov ah,1
int 16h
je reloop
ret
