First post, by orac81
Hi, this a little 64 byte demo of mine I thought I might share here..
https://github.com/orac81/miniapples/raw/refs … in/magixfly.zip
MAGIXFLY.ZIP (9k)
The attachment magicfly_screen.png is no longer available
This is an old-school DOS/VGA graphics demo program.
It gives the (classic) effect of flying over a changing landscape.
The x86 assembler source code (MAGIXFLY.ASM) is included, and there are comments with suggestions for changes, if you want to experiment.
It can run on an 8086 (or later) PC with VGA under MSDOS/Freedos. An FPU is not needed.
For modern PCs, it will run on Linux/Windows in DOSBOX, or other emulators.
To run, boot DOS and type:
MAGIXFLY.COM <ENTER>
Hit ESC to exit the demo. Type CLS or MODE 80 to return to 80 col display.
All variables held in registers, which makes the code smaller/faster.
AX,DX,SI are temp calc regs.
DS (data seg) points to VGA screen (A000h)
BX = Pixel position for plotting.
CX = time (frame count)
DI - Y position (for fx calc)
BP = X position (for fx calc)
It uses the open source NETWORK x86 assembler, NASM, but can easily be adapted to others.
Build with: NAS2COM magixfly
or NASM -f bin magixfly.asm -o magixfly.com
The demo isnt wildly new/original, but does have a few little ideas of its own, and it all neatly fits into 63 bytes. Enjoy!
Reply 1 of 10, by zyzzle
Thanks for sharing. I love little neat demos like this. Keep them alive in 2025! Raw ASM is so efficient and lean. It puts modern programming bloated "obfuscations" to shame.
Reply 2 of 10, by orac81
Thanks!
I have added a Turbo-c version to that archive, with my TCTINY build utility/library for TurboC. With that, the C version of the same demo builds to only 144 Bytes, so it is possible to build small programs like that with a high level language. Here is the TC version:
/* MAGIXFLY.C  - Tiny MSDOS 3d flying effect demo in 144 bytes.
(by orac81)
Simple demo of ultra-small compilation using TurboC 3.
To compile: tctiny.bat tc3path magixfly
ie: tctiny \m\tc3\bin magixfly
(needs MASM and exe2bin, or TASM)
include "tctiny.c"
unsigned char far *pVdu;
unsigned int frame; /* Frame count */
void main()
register unsigned int x;
unsigned int y;
unsigned int calcy;
IO_VIDEOMODE (0x13); /* Set VGA video mode 13h 320x200x256 */
do {
pVdu = (char far *) ((long) 0xa0000000L);
for (y=10; y<210; y++) {
calcy = ((2560/y) + frame) ;
for (x=320; x; x --) {
*pVdu = (BYTE) (((((x<<4)/y) ^ calcy) + (frame >> 8)) & 31) ;
pVdu ++;
frame ++;
IO_GETKEY (x); /* See if ESC key hit */
} while (x == 0);
Here is the TCTINY lib with some more such demos..
https://github.com/orac81/miniapples/ra ... ctiny.zip
Reply 3 of 10, by zyzzle
Ha.. Of course, I don't include Turbo C in the list of those modern bloated obfuscations such as Java, Javascript, Rust, Python, etc, etc.
Reply 4 of 10, by orac81
I posted this up on pouet, and of course someone comes along and rejigs the code, so it now compiles to just 52 Bytes! Without the exit check it would be about 48 bytes.
The end tests for loopX/loopY are really ingenious.
But I bet no one can improve on this.. 🙂
; MAGIXFLY.ASM by orac81, improved by rrrola.
; 52 byte flying demo.
; es:di = pixel address, bx=time, bp=y, cx=x
OFFSETY equ 12
org 100h
mov al,19
int 10h ; Screen mode 19 - VGA 320x200x256 (Using default VGA palette)
push 0A000h
pop es
reloop:
mov bp,OFFSETY
loopY:
inc bp
mov ax,0A00h
cwd ; dx=0 (ax=2560)
div bp
add ax,bx
xchg ax,si
mov cx,320
loopX:
imul ax,cx,16
cwd ; dx=0 (ax<=5120)
div bp
xor ax,si
add al,bh
and al,31
stosb ; (es:di) = al
test di,di
loopnz loopX ; X--; if (X) goto loopX;
jnz loopY
; di=0 after the loop
inc bx
mov ah,1
int 16h
je reloop
ret
Reply 5 of 10, by Max Headroom
Just for kicks I converted your demo to Bruce's C compiler and AS86 assembler from its package. It works! Files attached.
Somehow I even saved one more byte! 😀
Reply 6 of 10, by orac81
MH: Thanks for that! Some of the early DOS C compilers were really efficient, and can be tweaked for small code by hacking the default libs. I was going to try Pacific C, and Whitesmiths C, which had a rep for speed:
https://github.com/hansake/Whitesmiths-C-compiler
I updated magixfly, (same link) making it 8086 compatible, now 54 bytes, also added CGA version.
Also added cgaplasma:
https://github.com/orac81/miniapples/raw/refs … ain/cgaplas.zip
Reply 7 of 10, by gerry
this is cool, especially the ports between c compilers of the time, i'd bet it works well in masm or tasm too, directly or inline.
I like the explicit use of registers, it's the kind of thing that used to go on in z80 and other old 8 and 16 bit computer demo programming too
I used to love all these demos and so on back in the early internet when enthusiasts would do things in asm c, pascal and qb to see what is possible, how far systems could be pushed and so on
These demos inspired others and sometimes even led to games and game engine ideas
Reply 8 of 10, by Grzyb
Traditionally, there were three categories of demos:
- full size
- 64 KB
- 4 KB
Later, there came the 256-Byte species.
Now, are we witnessing the birth of yet another category?
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 9 of 10, by Max Headroom
Have a look here, Grzibby. 😉
Reply 10 of 10, by Max Headroom
orac81 wrote on 2025-05-07, 12:16:
If you like earlier C compilers probably Sphinx C-- may also be interesting to you. It already has nice built-in graphics capabilities.
