Reply 2820 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-04-30, 17:59:
BEEN_Nath_58 wrote on 2025-04-29, 17:11:
sharangad wrote on 2025-04-29, 12:36:
The fix in that thread worked, but not for all game threads, just the first 18 and only at the first switch to single threaded m […]
The fix in that thread worked, but not for all game threads, just the first 18 and only at the first switch to single threaded mode. I didn't realise system libraries like directsound used up so many threads.
Thanks @Been_Nath_58, this is a massive save.
RReady Alpha 29 April 2025 (Untested Alpha Release)
Team Apache Win11 24H2 fix.
https://nirvtek.com/downloads/RReady.Alpha.Te … 20250429.001.7z
MD5: 8e63dcdc883eaa769f3b83038ebfb88c
This should fix the campaign and credits videos stuttering as well.
The menu glitching is still there.
Glad that it helped. I will be seeking some help about the I76 situation soon.
Something funny happened. I was probably playing 1.082 I76 previously which used to crash on Redline. Now it was crashing on DirectDraw as well, on DxWnd without dgVoodoo2.
I put the files again, but installed 1.2 as well. Now the game neither crashes without dgVoodoo2, nor requires dgVoodoo2 for Redline
1.082? 1.2? Are these builds of the game? But that is weird behaviour. I've only tried the GOG version of this game.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 2822 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-04-30, 18:06:
Yes these are builds. The base game is probably 1.082. And 1.2 is a later patch. I don't know what GOG uses but if its 1.082 it may be the same issue.
I was talking to cracyc on it (the maintainer of OTVDM) and when they didn't find any error, that's when I proceeded to check again. They are using Windows 10, for record.
Reply 2823 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-04-30, 18:39:
But the GOG build used to work with just DxWnd and RReady. So maybe GOG rolled it back?
Reply 2824 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-04-30, 19:08:
I don't know if GOG build works, if it works it could be the newer version. If it doesn't it's the older one. I have the gog version too, I can check later how it behaves
Reply 2825 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-04-30, 20:45:
The GOG version used to work with just DxWnd, but with newer Windows updates (Jan-April 2025) it needed dgvoodoo as well. So maybe there's been a stealth Windows update.
Reply 2826 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-04-30, 21:20:
Maybe that's the same game as I was testing. I will need to analyse differences
Reply 2827 of 3431, by BEEN_Nath_58
GOG I76 has a file i76_1083.dll I assume its an "older" file.
Ironically the game now crashes natively here, but not with DxWnd. Now I am not sure where to blame. It looks like GOG is 1.2 which works with DxWnd but not natively
Reply 2828 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-05-01, 06:19:
Could Windows 11 be carrying out some dynamic/adaptive changes to how it runs legacy apps? So that it's entirely possible it runs the game differently each time?
Reply 2829 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-05-01, 07:00:
So to be sure, you have been testing I76 GOG version right? It still crashes in native DDraw, but it runs with DxWnd. Can you test that once more?
About dynamic changes, there is FaultTolerantHeap, but I doubt that's an issue here
Reply 2830 of 3431, by BEEN_Nath_58
Well 1.082 doesn't even support D3D, Glide or even RRedline so that's far off.
On DxWnd, now I need to manually set Handle Exceptions + Set NOPs so that the game runs with RReadline or even the normal D3D or DDraw modes. Can you try this change?
Reply 2831 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-05-01, 07:23:
I didn't see this post until now, I can't try i76 right now. I have "Windows Hypervisor Platform" turned on and stuck on a lot of things. It needs to be disabled, *I think*, to run i76.
But I think it should work. I'll check it out this afternoon.
Reply 2832 of 3431, by sharangad
sharangad wrote on 2025-05-02, 07:03:
i'76 works with those settings on Win11 24H2 April but also needs dgvoodo's MS(x86) folder's dlls. It doesn't run without it. it doesn't run at all after the April update without the new settings.
i'76 Nitro runs with those settings without dgvoodo with Windows Hypervisor Platform on and not at all without WHP with those settings, even if dgvoodoo is in place.
The AI cars have weird timing and don't move smoothly with WHP on.
Pre-configure updated versions with both high and regular DPI support are available here:
https://nirvtek.com/downloads/DxWnd.i76AndNit … MW2.20250502.7z
MD5: 4b12969611f8449f0b993cb2e897b4eb
Reply 2833 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-05-02, 11:11:
i'76 works with those settings on Win11 24H2 April but also needs dgvoodo's MS(x86) folder's dlls. It doesn't run without it. i […]
New settings: Handle exceptions + Set NOPs?
The game needs to run at low FPS, UCyborg recommended 20FPS
Reply 2834 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-05-02, 11:41:
Yup those two settings.
Adding maxfps=17 to rendition.cfg will set the right framerate. It needs to run at 17 fps.
Reply 2835 of 3431, by BEEN_Nath_58
Where did you get the 17fps value?
Reply 2836 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-05-02, 12:37:
Saw that online somewhere. Some sections of the game are unplayable at higher framerates.
Reply 2837 of 3431, by BEEN_Nath_58
sharangad wrote on 2025-05-02, 12:44:
People talk about different numbers though:
Re: So Windows 11 22H2 is super cautious (or super buggy)?
Reply 2838 of 3431, by sharangad
BEEN_Nath_58 wrote on 2025-05-02, 13:34:
Don't know what the magic number is, I think I saw it on one of the GOG forums that it needs to run at 17 fps. I don't think the developers actually said what the target framerate should be.
Reply 2839 of 3431, by sharangad
filipetolhuizen wrote on 2025-04-28, 03:43:
sharangad wrote on 2025-04-28, 03:08:
filipetolhuizen wrote on 2025-04-28, 02:38:
Anytime. I also tested it with Psygnosis Formula 1 and it's also working, although too fast in the menus and sluggish in races.
How sluggish is it? The framerate should vary between 30-60 fps.
Is that what you mean or is it worse? The other rredline games should be full speed, except for "die by the sword."
It stays at 144 in the menus but drops to 20-6 during the races.
Filipe, could you try this to see if F1 runs any better? Also try disabling Rendition AA for this game (for RRedline apps, it's a per game setting).
https://nirvtek.com/downloads/RReady.Alpha.Fo … est.20250510.7z
MD5: 12dd6eea3ced18846b605259944cb7ed
- Should correct an F1 texture sizing glitch as well.
- Team Apache video freeze fix on nvidia hardware.
